What else should be replaced when replacing the water pump?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, May 5, 2026 at 9:52 PM.
  1. gatorback
    gatorback Junior Member
    60
    A 2010 (16 y.o) Prius with 95K miles was inherited and I would like to prevent any damage. As I understand it the water pump should be replaced because of its age?
    If that is correct, what other parts should I replace while I am in there?
  2. CR94
    CR94 Senior Member
    2,769
    1,213
    Northwestern S.C.
    My impression is that coolant pump failures at such low mileage are rare, assuming it hasn't been coping with overheated coolant.
    When the pumps have to be replaced, people often replace the coolant thermostat at the same time, because it's easy then. However, I've yet to hear of an original thermostat actually failing at any mileage.
    gatorback likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,198
    5,343
    Pacific Northwest, USA
    I still don't understand why Gen3 owners have been so passive about engine destroying ability of this valve failure via class action lawsuits? Head gasket failure due to a stuck valve boosting engine temperature is a smoking gun... Guess its not common enough for outrage of significance?
    #3 PriusCamper, May 6, 2026 at 12:08 AM
  4. Mendel Leisk
    42,044
    Which valve? Maybe pre-edit?
    ^ got this alert too, Priuschat snafu?
  5. PriusCamper
    13,198
    5,343
    I got confused when reading this first time around and thought OP was mentioning a different valve, rather than just the EGR valve itself. Once I realized it, I edited you and Chapman out of me asking for help, but notification was already sent.
    Point being this is the first thread I've seen that specifically said valve was jammed and forcing engine temperature higher. As in cause and effect, which is much less vague than how others have presented EGR issues in the past.
  6. ChapmanF
    18,708
    Looks like maybe you mixed up this thread with the other recent one where the exhaust heat recirculation system was being discussed. That system has the little wax-thermostat actuator down on the exhaust pipe that waggles an exhaust valve, controlling whether the exhaust goes straight through the pipe, or has to go through the EHRS heat exchanger and heat up the coolant. If the valve gets stuck in the latter position, it heats up the coolant more than intended.
    In that other thread, rjparker posted graphs of the two temperature sensor readings, one at the engine water outlet, and one at the coolant return from the EHRS exchanger. The graphs show that your signal of the sticking valve is likely to be a temperature-warning light because of the EHRS temperature reading, while the engine temperature reading stays relatively tame. So you get notification of the EHRS issue and, ideally, go unstick it. I'm not sure how much excitement should be attached.
    Mendel Leisk and PriusCamper like this.
  7. gatorback
    60
    An LLM query returned a practical “long-life Gen 3 Prius protection” bundle:
    1. Engine water pump
    2. Thermostat + gasket
    3. Serpentine belt
    4. Fresh Toyota SLLC coolant
    5. Inspect/replace aging hoses as needed
    6. PCV valve
    7. Full EGR/intake cleaning
    8. Transaxle fluid drain/fill
    9. Inspect inverter pump operation
    10. Spark plugs (optional but reasonable)
    That combination addresses most of the common aging/failure paths on a low-mileage but older Gen 3 Prius. I'd appreciate any helpful comments from senior forum members.
  8. PriusCamper
    13,198
    5,343
    Perfect example of the LLM problem solved via a select all for reply... As in it lacks critical oversight / quality control. For example, there's no Serpentine belt in a Gen3 Prius. There's also only one or two things on that list that are relevant... Or as my personal AI was explaining to me earlier this evening:
    "AI reaches for rhetorical scaffolding the way a nervous speaker reaches for filler words. Brevity is harder because it requires knowing what to omit, which requires genuine judgment about what the reader already knows and what actually needs saying. AI tends to over-explain because it can't fully model that gap." --Claude
    #8 PriusCamper, May 8, 2026 at 2:20 AM
  9. rjparker
    10,664
    6,695
    Actually it addresses none of the most common failure paths.
    Head gasket failure - design flaw
    Excessive Oil Burning - design flaw
    Inverter failure - design flaw
    Brake Booster Assembly -design flaw
    Hybrid battery - expected around 150k or higher
    Each was repaired free if they failed within certain timeframes and mileages.
    Improved parts include head gasket, pistons, rings, inverter power electronics and perhaps brake booster since repeat problems on the last item is rare.
    Sure you should do regular maintenance on fluids and spark plugs. Generally fluids twice as frequently as the maintenance schedule recommends. Plugs are ok as recommended around 100k. I believe oil and coolant are key. If its not burning any observable oil in 5k miles you want to keep it that way. Change the brake fluid every 50k.
    I have never changed my water pump in 350k miles. But I do have a temperature display with an early audible alarm.
    P10 display $35
    Change the fluids. Save for a new hybrid battery.
    #9 rjparker, May 8, 2026 at 7:16 AM
    Brian1954 likes this.
  10. Mendel Leisk
    42,044
    I’d add periodic, in-depth brake inspection, and brake fluid replacement.
