MFD with Gremlins
Discussion in 'Gen 2 Prius Audio and Electronics' started by SilentKiller, May 11, 2026 at 7:04 PM.
  1. SilentKiller
    SilentKiller New Member
    17
    St Cloud, Fl
    As part of the restoration of my my new 2008, I had to replace the MFD because my original had a burnt screen.
    So I received my new one and I noticed recently that at random times on start up the clock loses time. Meaning, after I start it up I notice the clock has lost and hour, sometimes two. Well today, aside from losing a chunk of time, 4 hours and minutes, my screen that shows the tank avg mpgs and mileage also reset to 0.
    When you combine that with my fuel gauge not working, this is becoming a real hoot to drive.
    Thankfully I use fuelio and can "guess" how many miles I can go between fill ups.
    Has this ever happened to anyone else? In the meantime I'm going to start taking my old screen apart to see if I can switch screens. Any help is appreciated.
  2. dolj
    dolj Senior Member
    8,606
    4,366
    Wellington, New Zealand
    These are signs that the 12 V power supply is being interrupted somewhere along the way from the battery in the back. Checking that the terminals and clamps are clean and securely fastened to the battery is a good step. Make sure to back the terminal nuts right off and pry the clamp open so it sits at the bottom of the ledge of the terminal post. Pay particular attention to make sure you do not lever the terminal clamps up when tightening. I find using a socket or a closed wrench helps with this. Also, check that the negative battery cable at the end where it connects to the car is also clean and tight.
