MFD with Gremlins
Discussion in 'Gen 2 Prius Audio and Electronics' started by SilentKiller, May 11, 2026.
  1. SilentKiller
    SilentKiller New Member
    St Cloud, Fl
    As part of the restoration of my my new 2008, I had to replace the MFD because my original had a burnt screen.
    So I received my new one and I noticed recently that at random times on start up the clock loses time. Meaning, after I start it up I notice the clock has lost and hour, sometimes two. Well today, aside from losing a chunk of time, 4 hours and minutes, my screen that shows the tank avg mpgs and mileage also reset to 0.
    When you combine that with my fuel gauge not working, this is becoming a real hoot to drive.
    Thankfully I use fuelio and can "guess" how many miles I can go between fill ups.
    Has this ever happened to anyone else? In the meantime I'm going to start taking my old screen apart to see if I can switch screens. Any help is appreciated.
  2. dolj
    dolj Senior Member
    8,657
    4,406
    Wellington, New Zealand
    These are signs that the 12 V power supply is being interrupted somewhere along the way from the battery in the back. Checking that the terminals and clamps are clean and securely fastened to the battery is a good step. Make sure to back the terminal nuts right off and pry the clamp open so it sits right down on the terminal post's ledge. Pay particular attention to make sure you do not lever the terminal clamps up when tightening. I find using a socket or a closed wrench helps with this. Also, check that the negative battery cable at the end where it connects to the car is also clean and tight.
    #2 dolj, May 12, 2026
  3. SilentKiller
    St Cloud, Fl
    You beat me to the punch .. lol
    Thank you
    I am going to check all connections tonight, but it may be the 12v battery itself, this morning I woke up to my radio stations wiped out. It's a funny little car, really sensitive to power and ground state changes ..
    I managed to capture this screenshot from Dr Prius last night as well which pointed me in that direction.
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,356
    984
    Monument, Colorado USA
    Yep, with a 2008, I'd check all grounds on the 12-volt side. Did it spend any time up in rustyland? My Dad had an F-150 up in Maine in the 80's-90's and started having tons of electrical gremlins from the salty roads rusting out everything. (Ended up just junking it, we found brake fluid starting to leak and were all rusted out...NOT good!)
  5. SilentKiller
    St Cloud, Fl
    No this is a Florida car, that being said, there is suspicious "rust" inside the car specifically in the trunk area. My guess is a bad hatch gasket. It is cracked in several places, but I have also had the battery out of the car several times. So I could have caused this, however, it could be the beginning of a failing battery. The good news is I have a good Optima Red top AGM, in a car that I do not drive regularly, so I am going to swap them out and bench charge the Prius battery to help give it a boost.
    I'll keep you all posted.
    Thanks
    ColoradoBoo likes this.
  6. SilentKiller
    St Cloud, Fl
    I wanted to update you on the condition, fixed, sort of .. lol
    The problem is the battery terminal. The battery is a year old, so in and of itself its good. When I last installed it I tightened the terminal as much as safely possible. What I didn't do was check the connection. Even tight the terminal moved on the post, thereby causing moments of non connectivity and all the gremlins I was complaining about. My old school answer, I introduced a SS screw wedged between the post and terminal. Very secure and no more gremlins.
  7. ChapmanF
    19,061
    Counterintuitive as it may seem, a history of overtightening a battery clamp is a very common way of eventually stretching it out so it's no longer tight even when you crank it down till the ends meet.
