No immobilizer chip in FOB
Discussion in 'Gen 2 Prius Technical Discussion' started by foreverPriusCar, May 11, 2026.
  1. foreverPriusCar
    foreverPriusCar New Member
    florida
    So I purchased a used 06 Prius w/smart key but the previous owner lost or didn't transfer the immobilizer chip to a new fob shell. Car still starts, unlocks, locks etc with the smart key but it will not start with the key in the key slot. From what I've read, I can use Techstream to reset just the immobilizer codes to reprogram a blank key, right? If I can get the immobilizer chip reprogrammed I can program spare key fobs myself.
    Please let me know if I'm incorrect in this assumption.
    Plan:
    - Get techstream with minivci cable
    - Get seed code to calculate pin
    - Reset/clear Immo codes
    - Pair car and new fob
    - Move immo chip to old fob
    - Run through process to program additional fobs with creader elite
    TIA!
    EDIT: I'm working on making this the last car I'll own.
  2. Tombukt2
    13,742
    2,486
    This has changed a lot in last 90 days . Look at this thing called tlk1 2 or 3 read them carefully . Because lost transponder chip you will have to go to obd365 and buy a blank coffin the transponder chip .. then have it burned by a locksmith . I don't think tech software can burn a chip . Or write a chip 9 could be wrong . But tech has no transceiver. Or way to send radio waves to the chip to burn the numbers in . Tools like londsor k518 for all keys lost scenario in the electronic end of all of it . This has nothing to do with the blade .
    BiomedO1 and foreverPriusCar like this.
  3. BiomedO1
    4,434
    2,332
    Left Coast
    The electronic key and the physical key are two completely separate things. I believe you need to have the primary key, in order to program another access key. If you don't have the primary key; you'll need to access through a fully registered, updated, validated, certified Techstream. That lock-out is obvious; to prevent easy car thief.
    The dealership is your best bet; though some locksmiths has those electronic tools - but I can't see them being able to afford the licensing and access rights; without doing a whole bunch of them every month.
    Good Luck.....
    xw20_driver and foreverPriusCar like this.
  4. foreverPriusCar
    florida
    That's literally what I say to myself after reading other thread about a similar situation. Same dejected, disappointed tone. lol
    I've contacted a locksmith; 250 for new keys AKL. Still waiting back on dealer for their price.
  5. foreverPriusCar
    florida
    Wow, the TLK3 sounds promising. I know the KM100 no longer has AKL Toyota compatibility in the US. I might try that
  6. Tombukt2
    13,742
    2,486
    Toyota ALK requires no licensing or any of that stuff it's a standard anyone can buy tools and access easily now . For like 59 bucks . 8 have several . Look at tlk 1 just for fun theirs a video watch it . This is one method .
    foreverPriusCar likes this.
  7. ChapmanF
    18,870
    I always thought those little immobilizer chips were managed the same way as original TPMS transmitters: you don't 'burn' anything into the chips; each one you buy just has a unique code already burned in, and you teach the car to recognize that (which Techstream can do).
    BiomedO1 likes this.
  8. Tombukt2
    13,742
    2,486
    If you look on sites like obd365.com you will see bags of the coffins . They may come as you say but they can apparently be rev burned the programmed with tools like tlk1 which can relearn fubar factory remotes if it's all they're. with the missing coffin now a 30.in connector to OBD2 is needed in our old cars that immo box is under dash pad. In newer cars you just open pass. Door pull plate off insert 30 pin to OBD2. Now the I'mmo box will be ready to get original chip id. Do he can burn or program a complete remote with that data . To work system he can test data first from the setup he using once confirmed working but or program remote ..
  9. BiomedO1
    4,434
    2,332
    Left Coast
    I haven't done a Prius yet; but I do know on other cars - You'll need the primary key to add another fob; otherwise the ECU won't let you program another access key. The primary key proves that you own the car; only then will it accept another fob. Absent the primary key; a registered dealership scan-tool will allow access after a few physical and electronic verification.
    xw20_driver likes this.
  10. Tombukt2
    13,742
    2,486
    All keys lost scenario . You read immo days wirelessly from the start button antennae the info pops up on screen w hex codes n all . You verify w vvdi key tool that info received opens doors readies car etc . Then burn a fob or two. The alk scenario automatically kills off all old remotes ever in existence for said vehicle so if you find a key again it will not work .
  11. Tombukt2
    13,742
    2,486
    I think for our cars it's the tlk one needed. Realize also the 30 pin cable does not come with tlk . I access the immo box on Prius this old wirelessly to not remove dash top.
  12. BiomedO1
    4,434
    2,332
    Left Coast
    I really don't want to get into an argument here; but if it was that easy - What prevents a thief from electronically re-keying your car and taking it out of your driveway????? An early car may have worked that way, but everyone I've run into requires at least one fully functioning fob to verify ownership - otherwise it's drag it to the dealership.
  13. rjparker
    10,851
    6,819
    My understanding is when you don't have a working fob, it requires a licensed locksmith listed as a current member of the NASTF Vehicle "Security Professional" Registry.
    On top of that, the traditional Techstream won't work in the clear all old situation, you have to buy a "Security Professional" access from Toyota TIS, minimum $80 for 2 days and download the completely new GTS+ Global Techstream+ software.
    Of course, its much easier if you are simply adding a fob when you have a working fob. Which is a good reason not to rely on one working fob which might be lost or could fail.
    It's not clear to me if the security is the same on a gen2 but it is likely.
    I know one locksmith near me can do it but he had to get the new Toyota software.
    If you have more than one dealer, price shop.
  14. ChapmanF
    18,870
    Yeah, the "standard" and "professional diagnostic" subscriptions are offered to all comers whose money is green, but the "security professional" subscription is the one where they check your NASTF membership.
  15. BiomedO1
    4,434
    2,332
    Left Coast
    Yep; it's all comes down to traceability and accountability. Whomever reprograms, adds, subtracts key fobs will leave an electronic finger print - so if stolen cars are recovered with the same electronic finger print on the immobilizer; that person is going to have a lot of explaining.
    I knew this one really stupid technician that gave his credentials to other people in the office to use. When I found out; I fell over laughing. This other idiot in the shop, didn't know what his was doing, wasn't trained, doesn't read theory of operations - was using his credentials to login; on critical systems. What happens when something deviates from set parameters and there's an incident?:(o_O:eek::whistle: I had to lay all that out for that stupid technician; because the other idiot will just claim ignorance and say; "I don't have access rights to that".
    The lawyers will be looking at fingerprints.......:sleep:
  16. Tombukt2
    13,742
    2,486
    Absolutely nothing sir that is the problem that's whatthr clowns were doing in the video that locked down industry . Now my tools have to come from the UK to avoid the USA lock and nonsense Ive bought since lockdown. You are exactly right it is that easy and anybody can go steal your car I promise you if they want to invest in tooling etc very easy . Like code grabbing in the 80's. That's why now the industry has agreed to standards brick m mortar store level of insurance etc . The workaround is by from other countries they sell unlocked USA capable devices .
  17. dolj
    dolj Senior Member
    8,630
    4,384
    Wellington, New Zealand
    That is an incorrect assumption, on the Gen 2. The Primary/Secondary thing was on the Gen 1. On the Gen 2, you only need one fully functioning fob to add another new fob. Without a fully functioning fob, you are in an 'all keys lost' scenario, which is exponentially more costly.
    These assumptions are just wrong. Maybe wait until you have the experience or knowledge before chiming in. Wrong assumptions help exactly no one.
    Brian1954 likes this.
  18. foreverPriusCar
    florida
    Okay, so what I suspected was correct. I don't need a full systems reset of the Immobilizer and the Smart Key I just needed to get a new immo chip programed. What I did was pick up a key smart key compatible FOB online. Then I picked up the xHorse VVDI Mini OBD-FT ($75 shipped) downloaded the xHorse app on android. With the Mini OBD-FT I was able to reset and program a new immobilizer chip. After that I swapped my working smart key PCB into the shell with the immo chip. From there I ran the chicken dance to program another new smart key's immo chip, and then finished out the chicken dance to program the smart key. This resulted in two working keys that unlock and start in proximity as well as start the Prius with the FOB in the slot with the immobilizer. No need for a $250+ service call from the locksmith or a $500+ drive to the dealer. I'm working on setting up a 3d printed key blade duplicator with a dremel so I can cut the new FOB blades to match the key FOB texture and make a valet key.
    EDIT: The Mini OBD-FT is supposed to be able to reset the Smart Key Box as well but I kept getting communications errors. I emailed xHorse to see what the issue is so if ever I need to create new keys because I lost them all, I can.
    #18 foreverPriusCar, May 18, 2026
    dolj and Brian1954 like this.
  19. Tombukt2
    13,742
    2,486
    Yep exactly this is another route .
  20. dolj
    dolj Senior Member
    8,630
    4,384
    One tiny clarification, it is not a valet key, it is your fallback if you should be in a situation where the fob battery is flat, and so remote and proximity no longer work.
    Together with the "immo chip", it allows you to unlock the car and start it, even though the fob battery is flat.
