A/C compressor wiring harness / connector
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nichos, Jul 31, 2018.
  1. nichos
    nichos Junior Member
    Norway
    Hello.
    So my A/C has not been working for around 3 years now, and I finally got around to have it checked. I followed the repair manual and found the connector from the compressor (the 12v one, not the HV) had one pin missing. I checked the wiring connector and sure enough the pin is stuck inside. I have tried everything to get the pin out but its really stuck in there.
    So I'm going to need to replace the compressor (allready have a second hand one in my garage) and the wiring. The problem is that my local toyota dealer does not sell the wiring or just the connector( for soldering the new wiring connector). All junkyards only sell all the wiring togheter with an engine.
    The toyota dealership also does not sell the nd11 oil needed for the compressor.
    Does anyone know where I can get a hold of a connector or the wiring for the A/C compressor and where I can buy the nd11 or equivalent oil?
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    I'm going to suggest a simple fix that Toyota would Never endorse. Peel back the tape on both ends of the connection, find the right wires (the ones going to both sides of the broken pin), and solder a jumper wire between them. You don't even need to cut either cable, just remove some insulation to expose the metal wire an inch of two from each end of the plug and make your splices.
    If you want to get fancy, put a little bullet plug in the middle of the jumper so you can disconnect it later. Regardless, make sure your jumper wire is at least as thick as the original, solder it properly, and cover the splices with good electrical tape. You just saved $1000.
    #2 Pluggo, Aug 1, 2018
    fotomoto likes this.
  3. ChapmanF
    18,919
    Isn't one "end" of the 12 volt control connection the compressor itself? Peel back the cast aluminum on that side?
    Sometimes the issue at a dealer is nobody at the parts counter knowing how to look up the parts you want or wanting to take the time to learn. Have you tried going in with the housing shell and repair terminal part numbers (from the wiring diagram) and asking for those?
    It is still possible to strike out, as the wiring diagram does warn that not all the numbered parts are available separately. But it takes the maybe-I-just-don't-wanna-look-it-up parts person out of the loop.
    -Chap
  4. yeldogt
    yeldogt Active Member
    810
    313
    NE
    there is no way to crack the connector on the compressor -- get to the contact and solder something to it ? I would do anything possible to reconnect to teh existing compressor before I opened up the system
  5. Pluggo
    608
    534
    Mmm, not a good idea. :(
  6. nichos
    Norway
    Thank you all for your input.
    The connector is indeed a part of the compressor and cannot be fixed.
    I'm thinking that the female part that goes into the compressor connector can't be a unique one of connector. Do you guys know of any other connector that looks the same? Then it would be easy to solder in the new one and plug in to the compressor.
    Thanks for your feedback so far :)
  7. ChapmanF
    18,919
    So, in this other post over here, I go through how to find that information in the wiring diagram. Once you get to an image like this one (note this isn't A/C, just a different example):
    you see there is a link up in the corner, Wire Harness Repair. Click that, and the details of the actual terminal are shown (here, for confusion, is a different random example).
    That's telling you this (example, not yours) terminal would be a 0.64 mm size designation, in the second (II) family of that size, and of a non-waterproof style. (When you find your compressor terminal, it will surely be a waterproof style).
    You can compare those specs to other connectors in the car looking for terminals to cannibalize, but it's usually easier to go to the dealer and ask for (in this example) part number 82998-24290 and have them sell you the exact terminal, already crimped onto (in this example) a 160 mm pigtail of wire that you can crimp to your harness (in this example, you could use the 82999-12020 blue crimp sleeve).
    -Chap
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
  9. nichos
    Norway
    Those are the cables for the high voltage system, i need the ones for the 12v system. The oil link was usefull thank you.
    ChapmanF, thank you very much for your help, I found the part number and everything. My dealer found these parts and quoted me 130 USD for the terminal, all 6 wires, 6 waterplugs and 6 sleeves.
    Additionally they said I could mount my other compressor myself and drive the car without turning on the A/C to them and they will fill with gas and oil for 250 USD.
    So in total it will cost me 380 USD to fix my wiring and fill with gas and oil. I think the wire parts were quite expensive, but I can't do without them.
    For anyone else wondering here are the parts nr for everything
    Terminal 90980-12303
    Watersealing plugs 90980-09871 (need 6 of these)
    Wires 82998-24250 (need 6 of these)
    Sleeves 82999-12020 (also need 6 of these)
    Thanks to all for your help, parts will arrive on monday next week.
  10. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    The more I look at this, the more curious I get. Can you post a photo up?
    Found it after a bit of looking. Sure seems like a lot of wires for an AC compressor. Modern technology I suppose. Other vehicles with the connector:
    Toyota FJ Cruiser 2007-2014 6 Cyl 4.0L
    Toyota Land Cruiser 2008-2017 8 Cyl 5.7L
    Toyota Prius 2010-2015 4 Cyl 1.8L
    Toyota Sequoia 2008-2017 8Cyl 4.6L, 8 Cyl 4.7L, 8 Cyl 5.7L
    Toyota Sienna 2011-2017 4 Cyl 2.7L, 6 Cyl 3.5L
    Toyota Tundra 2007-2017 6 Cyl 4.0L, 8 Cyl 4.6L, 8 Cyl 4.7L, 8 Cyl 5.7L
    #10 TMR-JWAP, Aug 2, 2018
  11. ChapmanF
    18,919
    Well, your profile says you're driving a Gen 2. Your compressor just has a dumb 3-phase motor and three orange wires from a motor-controller/inverter that is built into the car's main inverter box.
    A Gen 3 takes the motor control and compressor inverter circuitry out of the main box and into the compressor itself. The orange cables to the Gen 3 compressor are just straight power feed. It gets CAN bus commands over the low voltage connector and controls its own motor accordingly, and reports back its own status. Main inverter price goes down, compressor price goes up.
    I would consider removing from the existing connector housing all of the terminals (or as many as will come out, observing the instructions in the diagram for how to release them), and evaluate their condition. Any that are good enough, I might simply click into the new housing in the proper positions, rather than cutting them all off and making six splices just because you can.
    The prices they charge for their 160 mm repair wire segments never fail to make me shake my head.
    -Chap
    #11 ChapmanF, Aug 2, 2018
  12. nichos
    Norway
    Ah thats a nice little list of compatible cars, if only our local salvageyards allowed people to walk around by themselves like in the good old days. Now we have to go inside their office and order the part we need and they only look at their computer, not even bothering checking the cars they have in their lot. Oh well, old times.
    I can take a picture when I start the repair, currently everything is put back together (with non functioning ac) because its my daily driver.
    In short there are two connectors on the compressor, one for high voltage from battery (orange color) and one from the 12v system. The 12v male terminal on the compressor is non replaceable and one of the 6 pins have come off and is currently stuck inside the female connector from the wiring harness(12v). This means I have to replace the compressor and the female connector.
    Main issue was that my local dealer "couldn't" find the parts i needed until I supplied them with a part number which I found with the help of chapmanf further up. Then they magically found the part in question, but they even said that according to their computer, this part is not on my car.
  13. refusedone
    refusedone Junior Member
    40
    los angeles
    IMG_4957.jpeg IMG_4958.jpeg IMG_4959.jpeg IMG_4960.jpeg IMG_4961.jpeg IMG_4962.jpeg IMG_4963.jpeg Hello, I wanted to post my experience on this topic. I had an issue with the pins being broken on the ac compressor. I could have gotten another one, but my curiosity got the best of me and I wanted to see if it was possible to fix the connector…I was hoping it was as simple as some wires inside I could connect to a new harness. Turns out it was a circuit board, I removed the top of the 12V side (the oddly shaped bolt heads were simply hex afterall), removed the solder and pins, and soldered in a new 6 pin connector. Then I sealed it up with high temp silicone and it works!
    Anyway, just wanted to share in case this may help anyone…
    CR94, StarCaller and bisco like this.
  14. refusedone
    40
    los angeles
    Not advice, just sharing my experience. If you do try at your own risk, be sure to disconnect all power to compressor and allow capacitors to discharge
  15. rjparker
    10,939
    6,861
    Nice work. What did you use to suck up the solder? Did you do all this with the board still in the housing?
  16. refusedone
    40
    los angeles
    I used the device you can see in the 1st and 3rd pics, small hand suction device from HF. Yes, removed the top cover & had access to the front and back sides with the circuit board still attached to the lid.
  17. ChapmanF
    18,919
    Just getting my bearings here ... I assume the part sticking out to the lower left in the photo is the connector for the incoming high-voltage DC, and the three circles in a row at the top center are sockets that connect to the three motor phase windings by just slipping over three internal contact pins? So, after removing the bolts, this assembly just lifted straight up off those pins?
    Is the space below this assembly open to refrigerant, such that imperfect sealing of this part when bolted back down would be a refrigerant leak?
    Or does this part bolt down onto a still-closed top compressor surface, with just the three phase winding pins sticking up?
    Are those traces of thermal interface paste I see around that flat central area, where it might be clamped against a flat compressor surface that's cooled by returning refrigerant? If so, what kind of paste did you use when reinstalling it?
  18. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,558
    2,598
    Taylors, SC
    I don't have any issue with the connector on my car's compressor,
    I did, however, unplugged the connector and filled the connection with dielectric grease,
    The position if the connection is an apparent moisture trap which promotes corrosion over time.
  19. refusedone
    40
    los angeles
    Yes you’re correct, the twelve volt PCB side is separate from the refrigerant/high voltage side. So the three pins connect the low and high voltage sides, no exchange between the two aside from electrical via the three pins. I used the same paste that it came with, did not add more. Yes, lower left is the high voltage connector.
