Hey, guys, I have this weird sound coming from front right side, at every acceleration and sometimes during braking. It's like every time the forces change direction for the front right wheel, there's this sound. I've recently had the wheel bearing replaced on that side, and also sway bar links, tie rod ends and inner ends replaced for both sides. What you hear in the clip is what it is most times. If I'm really gentle with the acceleration, I can make it appear later, it's like if it passes a certain torque, then the whatever it is shifts and creates the sound.
Sound like you haven't look into the drive shaft yet. Can you have someone drive as you walk alongside and listen? Maybe that's it? If it were me and that was the problem I'd live with it until there were multiple reasons for getting in there and replacing them.
Well I have sort of excluded both brake assembly the CV axle because this popping happens in both braking and accelerating, meaning the breaks are in neutral state when accelerating and the CV axle is in almost neutral state when breaking, so none of these two culprits could be causing the noise.
The direction of significant torque on the CV joints reverses every time you accelerate or regeneratively brake.
Excessive brakes while braking will quickly break the brakes. Which is what you are doing by coasting in neutral. No regen braking and no regen recharging. Assuming the drive axle cv joints are good without checking them is equally bad. It is true Toyota cv joints rarely fail but people sometimes replace axles with poor quality aftermarket or the cv boot tear losing grease.
Thanks for the answer, guys. But before posting I did check with a certified mechanic all joints, lifted the car up and checked for play everywhere. Seems like we either didn't put enough force in the lever to find the play, or it is not there, in the wheel assembly. And to reply to some messages here, I only used braking in neutral to test this issue. Just returned from a over 500 miles trip and the noise is still there, the same as before, no change.
Clearly someone missed something, certified ASE or not. I would go to a dealer or specialized front end shop. Don't let assume make an axx of- u and me.
