Gen 3 popping noise at acceleration
Discussion in 'Gen 3 Prius Main Forum' started by Nirosorin, May 12, 2026.
  1. Nirosorin
    Nirosorin Junior Member
    31
    Hey, guys,
    I have this weird sound coming from front right side, at every acceleration and sometimes during braking. It's like every time the forces change direction for the front right wheel, there's this sound.
    I've recently had the wheel bearing replaced on that side, and also sway bar links, tie rod ends and inner ends replaced for both sides.
    What you hear in the clip is what it is most times. If I'm really gentle with the acceleration, I can make it appear later, it's like if it passes a certain torque, then the whatever it is shifts and creates the sound.
    #1 Nirosorin, May 12, 2026
  2. PriusCamper
    PriusCamper Senior Member
    13,428
    5,421
    Pacific Northwest, USA
    Sound like you haven't look into the drive shaft yet. Can you have someone drive as you walk alongside and listen? Maybe that's it? If it were me and that was the problem I'd live with it until there were multiple reasons for getting in there and replacing them.
  3. Nirosorin
    31
    Well I have sort of excluded both brake assembly the CV axle because this popping happens in both braking and accelerating, meaning the breaks are in neutral state when accelerating and the CV axle is in almost neutral state when breaking, so none of these two culprits could be causing the noise.
  4. CR94
    CR94 Senior Member
    2,823
    1,238
    Northwestern S.C.
    The direction of significant torque on the CV joints reverses every time you accelerate or regeneratively brake.
  5. Nirosorin
    31
    Would it make the noise when braking in Neutral? Because it does.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,049
    6,924
    Texas Hill Country
    Excessive brakes while braking will quickly break the brakes.
    Which is what you are doing by coasting in neutral. No regen braking and no regen recharging.
    Assuming the drive axle cv joints are good without checking them is equally bad. It is true Toyota cv joints rarely fail but people sometimes replace axles with poor quality aftermarket or the cv boot tear losing grease.
    PriusCamper likes this.
  7. PriusCamper
    13,428
    5,421
    Sounds like by your logic excluding that as the source of the problem may of been premature?
  8. PriusCamper
    13,428
    5,421
    Yes, compared to old Subaru and VW axles/CV Toyota are so much better, but still not perfect.
  9. Nirosorin
    31
    Thanks for the answer, guys.
    But before posting I did check with a certified mechanic all joints, lifted the car up and checked for play everywhere.
    Seems like we either didn't put enough force in the lever to find the play, or it is not there, in the wheel assembly.
    And to reply to some messages here, I only used braking in neutral to test this issue.
    Just returned from a over 500 miles trip and the noise is still there, the same as before, no change.
  10. rjparker
    11,049
    6,924
    Texas Hill Country
    Clearly someone missed something, certified ASE or not. I would go to a dealer or specialized front end shop.
    Don't let assume make an axx of- u and me.
    #10 rjparker, May 15, 2026
