Rat's nest?!
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, May 15, 2026.
  1. nudriver
    nudriver Member
    283
    32
    los angeles
    Leaving the 2012 outside and rarely drive it. Went to check oil and saw this ugly *ss crap. Is this a rat's nest? I took a shovel and pushed it off where it lay on top of the engine oil cap. Questions:
    1. What damage can it have done, other than rats chewing wires? Car seems to run fine.
    2. Can anyone tell how old this nest could be?
    3. Will it cause damage that I pushed it off to the side?
    4. What should I be asking a mechanic to do that won't cost an arm and a leg?
    Separate question:
    1. How long can oil sit in a car that's rarely driven? It was changed in late December and still enough in there and fairly golden in color. I live in Los Angeles, so hot days are coming.
    BTW how do I attach an image?
  2. PriusCamper
    PriusCamper Senior Member
    13,336
    5,395
    Pacific Northwest, USA
    NiMH battery chemistry is ideal for constant use and expensive/problematic with rare to irregular use. Why are you holding on to a car you don't really need? How much would you sell it for?
  3. Mendel Leisk
    42,192
    Have him look over the engine bay, looking for chewed wiring, whatever. Good to check the cabin filter area too (requires glove box removal). Wouldn’t hurt to check engine air filter and associated plastic as well, they might set up residence in there as well.
    If there’s evidence in the cabin filter area it’d be best to remove wipers, associated linkage/motor, and the underlying metal cowl, this’ll expose the cabin filter egress: check the area and mesh the opening with 1/4” spacing, galvanized steel mesh, secured with sheet metal screws.
    What are you using to post, phone or computer?
    the hands-down simplest is to copy the image, then paste. For example on my iphone, took a screenshot, cropped it, chose copy, then tapped in the following space, and pasted:
    If you’ve got a saved image, you can tap/click this button:
    then navigate to and select an image, which attaches the image. You can leave it thus, it’ll appear as a link at bottom of your post, or embed in the post, either full or thumbnail:
    #3 Mendel Leisk, May 15, 2026
  4. nudriver
    nudriver Member
    283
    32
    los angeles
    Here you go. What do you think?
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,553
    2,594
    Taylors, SC
    Get a cabin air filter with a wire screen. The reusable K&N model is a good option.
    Put a stainless steel screen on the air intake.
    #5 Georgina Rudkus, May 15, 2026
    nudriver likes this.
  6. BiomedO1
    4,443
    2,341
    Left Coast
    IMHO; that needs to be cleaned out and the engine compartment and cabin filter inspected.
    You should probably sell it, if your not following OEM storage procedures for that car. Your basically slowly killing the traction battery pack by idling the car like that. Hybrids require some specialized care; unlike ICE only cars.
    https://assets.sia.toyota.com/publications/en/om-s/OM47704U/pdf/OM47704U.pdf
  7. Mendel Leisk
    42,192
    I think it looks like a rats nest, hood insulation part of the material. As others have said (myself included), that's likely just the tip of the iceberg; you need to do stuff.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    1,323
    938
    Monument, Colorado USA
    Rats and mice carry a lot of stuff, (hantavirus, salmonellosis, etc.) so make sure you we gloves and a mask when removing that thing. (I'd use a broom and my wet vac to get it all out of there) Then, wash your hands and arms VERY well.
    Open up your glove box and then open the cabin filter area and inspect for rodent signs in there. (Wear the mask) Might have to also clean all of that area out and replace the filter.)
    Put a bunch of rat/mice traps around where you park.....don't want them coming back.
    An easy check to see if they've chewed any wires are to look for a Check Engine light when running it but, of course, want to get a good light in there and inspect.
  9. nudriver
    nudriver Member
    283
    32
    los angeles
    What you wrote is scary. I didn't touch anything. I got a shovel and pushed it off the oil cap to see what it was. I just pushed it aside. How would one contract anything?
  10. nudriver
    nudriver Member
    283
    32
    los angeles
    Mechanic's looking at it now. I was wondering why the layer of material under my hood was peeling for years with yellow insulation showing. So those bastards are peeling that off for their nests?!
  11. nudriver
    nudriver Member
    283
    32
    los angeles
    No sale.
  12. nudriver
    nudriver Member
    283
    32
    los angeles
    Was saving it for my son to take to college.
    PriusCamper likes this.
  13. Georgina Rudkus
    3,553
    2,594
    Taylors, SC
    I sprayed all the components including all the wiring with a light petroleum based rustproofing compound when I got my 2012 Prius v.
    Rodents hate petroleum based oils and will not chew on anything coated with it.
    Every 6 months, I would spray the engine compartment and all like entry points with rodent repellant with peppermint oil.
    Recently, several cars in the neighborhood experienced rodent damage.
    I sprayed with repellent and resprayed with petroleum oil undercoating to insure better protection.
    Another entry point are the rear air exhaust vents under the rear of the car.
    I pried out the plastic vents, fastened wire screens to them with zip ties and pushed them back.
    Never had any rodent intrusion.
  14. Mendel Leisk
    42,192
    Yes, likely rodents. There may be more in behind the glove box.
  15. Georgina Rudkus
    3,553
    2,594
    Taylors, SC
    Here are photos of how I attached the rodent exclusion screens to my rear air exhaust screens.
    The screens are cut from inexpensive expanded steel mesh gutter guards sold at Lowe's or Home Depot.
    #15 Georgina Rudkus, May 16, 2026
    CR94 likes this.
  16. Mendel Leisk
    42,192
    #16 Mendel Leisk, May 16, 2026
  17. nudriver
    nudriver Member
    283
    32
    los angeles
    Another what?
  18. Mendel Leisk
    42,192
    was being clever; it's a link.
  19. nudriver
    nudriver Member
    283
    32
    los angeles
    Is there a reason why they would be in my Prius and not my other electric and hybrid cars that I also park outside? Also, how effective do you think this might be?
    Mighty Mint Peppermint Oil Rodent Repellent Spray for Vehicles – Natural Mouse & Rat Control for Car Engines, RVs, Trucks & Boats – Plant-Based, Extra-Strong Formula – 16 oz
  20. nudriver
    nudriver Member
    283
    32
    los angeles
