This is Why Stop Leak Should be Banned
Discussion in 'Gen 3 Prius Main Forum' started by jimolson, May 16, 2026.
Tags:
  1. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    My brother and I work on Gen 3 Priuses acquired from disenchanted owners. The seller of this one said the vehicle "runs just fine...no problems".
    Of course it rattled like a spray paint can with a blown head gasket, as most Gen 3's purchased from FB Marketplace do.
    Replaced the motor with a different one rebuilt by the esteemed Scotty Partin, a trained Toyota hybrid tech in Rockholds, KY.
    But after installing Scotty's rebuilt motor the vehicle still overheated on up-sloped highways, despite having a new thermostat and water pump in it.
    The problem was revealed to be the stop leak additive poured in the cooling system by vehicle's former owner. It plugged the bottom half of the radiator.
    My thanks to Scotty for his help on the project. He would not have known about the stop leak problem because he never saw the vehicle or its blown engine.
    Surprisingly the vehicle's heater still functions like a blast furnace, though I imagine that its water passages are pretty gunked up.
    BTW, Gen 3 dashboard's engine overtemp icon illuminates at 250 degrees F. But a cheap OBDII tester running in the front seat can help you stay below 210F by driving the vehicle slowly home on a cold day.
    I cringed that Toyota set the temp threshold so high to turn on the overtemp light.
    #1 jimolson, May 16, 2026
  2. Tombukt2
    13,860
    2,519
    Yeah that's very common it'll even INFlate up out filler neck . Really wild looking stuff usually. Pulling rad and presxur flushing all else . Sad
  3. PriusCamper
    PriusCamper Senior Member
    13,463
    5,431
    Pacific Northwest, USA
    In other words, if you don't know vehicle history of a gen3 and you're swapping or rebuilding the engine you need to decide it you're replacing the radiator or not...
    I wonder if there's a flow rate test to determine if radiator is viable? Anyone have an suggestions?
  4. bisco
    52,854
    generally, by the time the over heating light comes on, the engine is blown
    PrimeDan likes this.
  5. rjparker
    11,099
    6,966
    It is very likely the flow into the reservoir tank will be higher when the radiator is partially clogged. This flow can be observed and could be measured.
    Radiator and reservoir flow starts when the thermostat opens. Before then, only flow through the thermostat bypass port to the engine occurs.
    The reservoir flow parallels the radiator but does not go through the cooling channels of the radiator.
    The flow restriction caused by the radiator micro channels creates pressure differential driving flow into and out of the reservoir.
    CR94 likes this.
  6. Mendel Leisk
    42,345
    One stop-leak manufacturer recommended a flush with 50/50 white vinegar and water, might help.
    I totally agree: stop-leak products should be banned. They're ostensibly to eke a few more miles out of a head gasket, but a ploy too easy to use when selling to unsuspecting buyers. :mad:
    Hey, maybe Toyota should market a stop-leak product, specifically for 3rd gens... :whistle:
  7. PriusCamper
    13,463
    5,431
    Has anyone found a way to modify their Prius so you get a warning at a lower temperature?
  8. bisco
    52,854
    not that I recall, but as o/p mentions, a cheap old reader works fine
  9. rjparker
    11,099
    6,966
    Sometimes I think you just unblocked me
    $35 P10 with user set audible alarm on temp. Probably posted 15 times here.
    PrimeDan, xw20_driver and Brian1954 like this.
  10. BiomedO1
    4,597
    2,411
    Left Coast
    Use an IR temperature gun to shoot different areas of the radiator. Deviations should be small, clogged area deviations are larger. This is a lot faster than pulling the radiator to flow test it.
    You can also pull the lower radiator hose to inspect for jelly like gunk...... There should be NO contamination.
  11. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    I added an IR imaging camera to my toolset a while back. Just a small little thing that plugs into my phone. I don't think I'll ever need it to show radiator blockage, but I did test it on my warmed-up car. The HVAC condensor is first in line, viewing through the hood latch access port. With A/C and both radiator fans running, the temperature was very uniform across the condensor. I imagine reduced airflow due to obstructions (bugs, etc.) would appear warmer. It would be difficult to image the ICE radiator though, since it is behind the HVAC radiator.
  12. BiomedO1
    4,597
    2,411
    Left Coast
    You shoot the IR gun from the engine side. Shooting the AC condenser doesn't tell you anything other that it's condensing.o_O
  13. Rmay635703
    Rmay635703 Senior Member
    2,701
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Head gaskets have been a problem since 1919, surprised we still haven’t solved it
  14. PriusCamper
    13,463
    5,431
    As saying goes about a picture being worth a thousand words... A thermal image camera is going to give way more information than an IR gun that can only give one data point at a time.
    AzWxGuy likes this.
  15. wheelsup
    wheelsup Member
    109
    24
    Raleigh, NC
    I did a quick look of your past postings and can't find a build thread, any link to it? Does that hook into an OBD2? That's pretty cool. I'd like to do something similar myself with some other info as well if possible.
  16. rjparker
    11,099
    6,966
    The P10 plugs into the obd2 connector which is constantly powered. So you set it up to sleep after 180 seconds of no rpm and reduced voltage.
    I use it to display coolant temperature which for a Prius is the standard block sensor. It is set for an early 220f audible alarm. I also set a 78 mph speed alarm.
    There are display options such as two or more parameters.
    See attached
    #16 rjparker, May 22, 2026
    wheelsup likes this.
  17. PriusCamper
    13,463
    5,431
    Toyota solved it over the past 40 years by selling vehicles that could consistently get way past 300K without a need for a new head gasket. Then in 2010 Toyota got the stupidest idea ever of putting a bigger engine in a Prius and it took them till 2016 to fix all the shorter engine lifespan problems that it created.
  18. rjparker
    11,099
    6,966
    Gen3 was value engineered by Toyota to reduce costs and maintain the price point under deadline pressures.
    The gen3 engine was not specific to Prius from 2010-15. It continued in North America through 2017 in the Prius v and worldwide through 2021. The later engines with revised pistons, rings, intakes, egr valves and ecm software run fine without excessive oil burning.
    All these parts are available for older engines. All these parts except the ecm software come with recent JDM $1200 engines.
  19. Leadfoot J. McCoalroller
    8,288
    7,802
    Pennsylvania
    2018 Prius c
    In this day and age the easiest thing is a photo with a FLIR camera. One quick look and you'll see distinct hot and cold regions of the radiator.
    Those cameras used to be terribly expensive, but some models are now under $100 and dropping.
    PriusCamper likes this.
  20. rjparker
    11,099
    6,966
    The problem with ir on a Prius is the front is covered with the ac condenser and the rear is covered by the radiator fan assemblies.
