Intake manifold condensation causing cold start rattle / shudders
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RubioM, May 17, 2026 at 5:10 PM.
  1. RubioM
    RubioM New Member
    Today
    Netherlands
    TLDR summary below.
    Hi fellow Prius owners,
    I have some issues with my Prius, and I'm having a hard time getting it resolved. It's a 3rd gen from 2009 (2010 model year), with about 230k km (143k mi).
    First the symptoms. Since a few years I've had intermittent cold start rattles. It's usually only a few knocks that go away in less than a second. In a handful of cases the knocking has persisted for 5-10 seconds. In addition to this, the car occasionally shudders while accelerating in a turn, with the ICE at medium RPM. These shudders happen especially after a long highway drive. When I take the exit, come to a stop at the light and then turn left or right. The car shudders when I accelerate through the turn, which lasts a few seconds. I also get the feeling that in general, the engine is a bit rougher and louder than before, but maybe I'm just hyper alert to any unusual engine noises. I have not lost any coolant.
    I've mentioned this at the dealer numerous times, but they just perform the Toyota prescribed maintenance and check for codes. They said the cooling system is not pressurized so there is no evidence of HG problems. They also denied that the Prius 3 is notorious for EGR and head gasket issues, which felt a bit like gaslighting to me as there is plenty of evidence to the contrary on the internet.
    Two years ago, I completely cleaned my EGR system: EGR valve, pipe, cooler, intake manifold, throttle body & PCV valve. This seemed to resolve the issues for a few weeks before they returned. The car never had a check engine light or codes. I still suspected a HG leak so about a year ago I performed a block test (blue liquid) which turned out negative.
    Since about 6 months the shudders have gotten a bit worse and they also happened during highway driving. I took it to a HG specialist, who exclusively fixes Toyota hybrid head gaskets. He checked the cylinders with a borescope, with a pressurized coolant system, and found no evidence for a leak. In fact, he said the engine looks to be in excellent condition. However, he did take off the intake manifold and there was a lot of water in the pipe leading up to the EGR ports, at least a few teaspoons full. He said this was probably condensation from the exhaust gases coming through the EGR system. The engine shudders during turns probably result from water sloshing around in the intake manifold due to centrifugal force, which causes it to block EGR ports or to enter the cylinders leading to misfires.
    He cleaned and dried the intake manifold and sent me on my way. In the following weeks I had no cold start rattle or shudders, but then they returned, just as they did after my EGR cleaning.
    I should mention that my highway driving is usually very calm, taking it easy behind some trucks in the slow lane :). The HG mechanic thought that might have something to do with extra condensation buildup. He said he had never seen it that bad.
    TLDR:
    To summarize, it seems the cold start rattle and engine shudders are due to EGR condensation buildup in the intake manifold, leading to misfires. This seems like a plausible explanation. However, I still don't understand why this is getting worse over time. Is there anything I can do to prevent condensation buildup? Could the condensation perhaps point to an underlying problem with the engine?
    Grateful for any ideas/suggestions.
  2. rjparker
    10,706
    6,723
    Run the egr block flow test. If this does not fix it you have a hg leak.
    egr block flow test
    PS: The Summary should be the first paragraph.
  3. ChapmanF
    18,734
    Well, water gonna condense. Exhaust has water, about a gallon (once condensed to liquid) per gallon of gasoline burned. I poured some out of my manifold EGR passages when I took my manifold off for cleaning, and didn't think it surprising.
    The only well-known rattling syndrome related to that is one that the earliest gen 3 owners were already reporting with their brand-new cars in late 2009: rattle on a cold start when the last prior use of the car was brief and didn't warm the engine up.
    The water in the exhaust starts as vapor, and should not be condensing in those passages except when they are cold. It seems there usually won't be enough water condensed in those passages to get snorted on the next start, unless the engine never had time to warm up on the previous use.
    When everything is warmed up, EGR flow probably tends to re-vaporize and carry away much of the water that has collected there. Maybe, for some reason, that's not happening for you. Maybe your EGR flow is inadequate, or your EGR cooler is working too well? :)
    What numbers are you seeing from the EGR flow self-test?
  4. CR94
    CR94 Senior Member
    2,775
    1,215
    Northwestern S.C.
    Mine used to do that occasionally, but mysteriously hasn't done it at all in several years now. (That's not counting the milder version that lasts only about 1 second or less.)
    Perhaps the troublesome condensation is from the PCV system, not EGR?
  5. ChapmanF
    18,734
    PCV enters the main manifold passages, down lowish, I think.
    What makes the condensed EGR water so eminently snortable is that it's sitting in these little narrow passages barely an inch below the intake ports.
    When the ports develop vacuum, the air in the dead-end (while EGR valve is closed) EGR pipe and passages, still at atmospheric pressure, expands right away and spurts the water out of the little openings.
    Whatever liquid is down in the big open main manifold area that goes down like a foot below the ports, I don't think is at much risk of getting snorted.
