Intake manifold condensation causing cold start rattle / shudders
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by RubioM, May 17, 2026.
  1. RubioM
    RubioM New Member
    Netherlands
    TLDR summary below.
    Hi fellow Prius owners,
    I have some issues with my Prius, and I'm having a hard time getting it resolved. It's a 3rd gen from 2009 (2010 model year), with about 230k km (143k mi).
    First the symptoms. Since a few years I've had intermittent cold start rattles. It's usually only a few knocks that go away in less than a second. In a handful of cases the knocking has persisted for 5-10 seconds. In addition to this, the car occasionally shudders while accelerating in a turn, with the ICE at medium RPM. These shudders happen especially after a long highway drive. When I take the exit, come to a stop at the light and then turn left or right. The car shudders when I accelerate through the turn, which lasts a few seconds. I also get the feeling that in general, the engine is a bit rougher and louder than before, but maybe I'm just hyper alert to any unusual engine noises. I have not lost any coolant.
    I've mentioned this at the dealer numerous times, but they just perform the Toyota prescribed maintenance and check for codes. They said the cooling system is not pressurized so there is no evidence of HG problems. They also denied that the Prius 3 is notorious for EGR and head gasket issues, which felt a bit like gaslighting to me as there is plenty of evidence to the contrary on the internet.
    Two years ago, I completely cleaned my EGR system: EGR valve, pipe, cooler, intake manifold, throttle body & PCV valve. This seemed to resolve the issues for a few weeks before they returned. The car never had a check engine light or codes. I still suspected a HG leak so about a year ago I performed a block test (blue liquid) which turned out negative.
    Since about 6 months the shudders have gotten a bit worse and they also happened during highway driving. I took it to a HG specialist, who exclusively fixes Toyota hybrid head gaskets. He checked the cylinders with a borescope, with a pressurized coolant system, and found no evidence for a leak. In fact, he said the engine looks to be in excellent condition. However, he did take off the intake manifold and there was a lot of water in the pipe leading up to the EGR ports, at least a few teaspoons full. He said this was probably condensation from the exhaust gases coming through the EGR system. The engine shudders during turns probably result from water sloshing around in the intake manifold due to centrifugal force, which causes it to block EGR ports or to enter the cylinders leading to misfires.
    He cleaned and dried the intake manifold and sent me on my way. In the following weeks I had no cold start rattle or shudders, but then they returned, just as they did after my EGR cleaning.
    I should mention that my highway driving is usually very calm, taking it easy behind some trucks in the slow lane :). The HG mechanic thought that might have something to do with extra condensation buildup. He said he had never seen it that bad.
    TLDR:
    To summarize, it seems the cold start rattle and engine shudders are due to EGR condensation buildup in the intake manifold, leading to misfires. This seems like a plausible explanation. However, I still don't understand why this is getting worse over time. Is there anything I can do to prevent condensation buildup? Could the condensation perhaps point to an underlying problem with the engine?
    Grateful for any ideas/suggestions.
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,113
    6,970
    Texas Hill Country
    Run the egr block flow test. If this does not fix it you have a hg leak.
    egr block flow test
    PS: The Summary should be the first paragraph.
  3. ChapmanF
    19,025
    Well, water gonna condense. Exhaust has water, about a gallon (once condensed to liquid) per gallon of gasoline burned. I poured some out of my manifold EGR passages when I took my manifold off for cleaning, and didn't think it surprising.
    The only well-known rattling syndrome related to that is one that the earliest gen 3 owners were already reporting with their brand-new cars in late 2009: rattle on a cold start when the last prior use of the car was brief and didn't warm the engine up.
    The water in the exhaust starts as vapor, and should not be condensing in those passages except when they are cold. It seems there usually won't be enough water condensed in those passages to get snorted on the next start, unless the engine never had time to warm up on the previous use.
    When everything is warmed up, EGR flow probably tends to re-vaporize and carry away much of the water that has collected there. Maybe, for some reason, that's not happening for you. Maybe your EGR flow is inadequate, or your EGR cooler is working too well? :)
    What numbers are you seeing from the EGR flow self-test?
  4. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    Mine used to do that occasionally, but mysteriously hasn't done it at all in several years now. (That's not counting the milder version that lasts only about 1 second or less.)
    Perhaps the troublesome condensation is from the PCV system, not EGR?
  5. ChapmanF
    19,025
    PCV enters the main manifold passages, down lowish, I think.
    What makes the condensed EGR water so eminently snortable is that it's sitting in these little narrow passages barely an inch below the intake ports.
    When the ports develop vacuum, the air in the dead-end (while EGR valve is closed) EGR pipe and passages, still at atmospheric pressure, expands right away and spurts the water out of the little openings.
    Whatever liquid is down in the big open main manifold area that goes down like a foot below the ports, I don't think is at much risk of getting snorted.
  6. Mendel Leisk
    42,349
    Both condensation and head gasket coolant leaks can put unexpected liquid in the combustion chambers, cause cold-start shakes. Running the engine for just a few seconds the previous day can cause the former, “belated” EGR cleaning can lead to the latter.
    “block test” tester checks for carbon monoxide in coolant, which is not what typically happens with 3rd gen Prius, at least not in the early stages. Your mechanic’s borescope inspection with coolant pressurized IS a good diagnostic, but considering the frequency and severity of symptoms, and your miles, it could be head gasket just starting to leak coolant, relatively hard to spot.
  7. RubioM
    RubioM New Member
    Netherlands
    Thank you all for your suggestions!
    I'm pretty sure the HG is not leaking at this time. The mechanic who looked at it with a borescope was pretty confident and he's seen a lot of blown HGs. He had absolutely no incentive to make a false-negative diagnosis.
    He showed me the borescope images and there was also no evidence of steam-cleaned pistons or cylinder heads. He also thought the miles were a bit low for a blown HG. Said he typically sees Prius V headgaskets blown around this mileage. Regular gen3's quite a bit higher. Of course, it could still be a beginning HG leak, but considering I've been having symptoms for years now, you would expect some evidence to be visible with the borescope.
    The EGR ports in the intake manifold were still pretty clean from the cleaning I did two years ago. Even at that time they were only partially clogged. He checked my PCV valve and it was working properly. Yes, the intake manifold had that disgusting sludge below the throttle body, but I agree with ChapmanF that there's a low chance that would make it all the way up to the engine intakes.
    So the main thing was all that condensation water in the upper EGR channel. It was pretty evident that it was condensation water, since it was completely clear, unlike the sludge at the bottom of the intake manifold. I agree with ChapmanF that this water is easily snorted into the engine since it's sitting so close to the intake ports. The fact that I'm getting these shudders during accelerating turns also suggests that the water is forced to one side of the EGR channel and is then snorted into either cylinder 1 or 4.
    The question remains why I'm getting so much condensation. I have no idea. Perhaps it's my driving habits, although I would expect many hypermilers to have this problem. My next step is to get the water out of there again and run it with a few tanks of premium ethanol-free gas to see if that makes a difference. I don't have Techstream so I can't do the EGR flow test, but I might consider doing that in the future. I'm pretty sure the EGR is still quite clean, considering how clean the intake manifold ports were, But I'll check the EGR pipe and valve just in case.
    I'm also thinking of doing the EGR-delete for a while to see if that clears symptoms.
    Will update if I find out more.
  8. rjparker
    11,113
    6,970
    Texas Hill Country
    The engines are identical.
    Not many hypermilers these days.
    The egr block flow test does not require a scanner or Techstream. It can rule out an egr valve that is sticking open causing stumbling.
    Egr delete is typically removing the egr connector. This will not block egr flow if the valve is leaking.
  9. RubioM
    RubioM New Member
    Netherlands
    Yes they are. The mechanic said the workload on the Prius V engines tends to be higher. That's how he explained their head gaskets failing earlier.
    Thanks for the suggestion. I will investigate this possibility. If the valve is stuck open that may also explain the extra condensation buildup.
  10. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    You don't have to have Techstream to read results of the car's automated EGR flow self-test. Any basic scanner will do, as long as it can access Mode 6 data.
  11. rjparker
    11,113
    6,970
    Texas Hill Country
    Not really. The difference is a higher numerical final drive ratio that allows a few hundred pounds more cargo and causes lower mpg.
  12. cdherman
    cdherman Member
    68
    27
    Kansas City
    It is quite damp in the Netherlands, a lot of the time, in my memory. Damp and cool were the air conditions that were most conducive to the startup knock from condensation (as well as being started a short period of time, insufficiency to warm the engine).
    One other thought -- are you sure you do not have a coolant leak? Into the EGR cooler? Which then flows down the EGR and into the EGR manifold pathways. Are your coolant levels ROCK solid, or slowly falling? If they are slowly falling, you have a leak somewhere and given your symptoms, I'd bet its the EGR cooler.
    Brian1954 likes this.
  13. ChapmanF
    19,025
    I don't think I would expect much. The round rule that burning a gallon of gasoline produces about a liquid gallon's worth of water doesn't seem to change much when you blend in some ethanol.
    The simple approach Gemini shows me starts with a simplifying treatment of gasoline as if it were nothing but octane (C₈H₁₈), enough H to make 9 moles of H₂O when 1 mole of octane combines with the right amount of oxygen.
    Then it repeats that reasoning for ethanol (C₂H₅OH), which has enough hydrogen to get 3 mol of water from burning 1 mol of ethanol. Which might look like ethanol-blended gasoline should not turn into as much water as straight gasoline. But that neglects the greater density of ethanol: there's more of it in the same volume, and the math still works out to pretty much 1 gallon of water made by burning 1 gallon of fuel.
    You're never going to see water not be in the exhaust—it's one of the chief results of the fuel-burning reaction.
    The thing is just that all the water is vapor when it leaves the cylinder, and usually mostly stays vapor most of the way out the exhaust pipe once everything is warmed up.
    If an unusual amount of it is condensing in the manifold for some reason, that would make me wonder whether something about your driving just isn't getting that pathway as warm as it would normally get.
  14. RubioM
    RubioM New Member
    Netherlands
    Thanks, I used my Bluetooth OBD2 dongle and Car Scanner app and it worked fine to get the EGR flow monitor. I didn't write the exact value down but it was a little over 21 KPa, which, judging from other threads about this monitor, seems to be consistent with a pretty clean EGR system. Of course this does not rule out the stuck-open scenario that rjparker suggested.
    Yes, we definitely get a lot of cool and damp weather here and I seem to recall the startup knocking is a bit worse on cold & damp days. The shudders after long highway drives don't seem to be affected by this (see below).
    Interesting idea, but my coolant levels have been rock solid for years, just below the full mark on the overflow tank.
    Yes, I have been suspecting my driving habits as well. However, I would expect condensation to be worst with short drives, especially pushing a cold engine with high RPM. This is not how I drive at all. I always take it easy on acceleration until the engine is properly warmed up and my trips are 15 minutes minimum and usually more like 45-90 mins.
    What's a bit unusual about my driving is that I tend to take it real easy, mostly cruising behind trucks in the right lane at ~90 km/h. And it's often right after these long, easy highway drives that the engine shudders are the worst. I take the highway exit, slow down or stop at the traffic light and when I accelerate through the turn and the ICE kicks in, the car shudders for about 3 seconds. Both left and right turns result in shudders.
    So maybe there is something about long drives at low RPM (around 1200) that causes increased condensation in the ERG system?
    I still think the EGR block suggested by rjparker would be valuable to rule out EGR stuck-open problems. However, I would have to block the EGR for a coupe of long highway drives to see if the shudders disappear and I'm a bit hesitant to block the EGR for such a long time. Some sources say it can cause engine problems such as detonation and overheating. Maybe I should combine an EGR block with unplugging the EGR valve? This will tell the ECU the EGR is inoperative and it will adjust to prevent detonation/overheating.
    #14 RubioM, May 24, 2026
    CR94 likes this.
  15. ChapmanF
    19,025
    To some extent it may, because of the way that self-test is done. The number is the difference between two readings of the manifold pressure, one with the valve closed, one with the valve open some determined amount.
    I'd expect the difference in readings to be smaller if the valve-closed reading is taken with the valve not fully closed.
    RubioM likes this.
