Doesn't this make you feel like a mushroom?
Discussion in 'Knowledge Base Articles Discussion' started by Paul Gregory, May 20, 2026.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,287
    604
    Alberta
    2024 Prius Prime
    XSE
    Agreed. Eat healthy and exercise.
  2. fuzzy1
    10,632
    I didn't claim "that this was only made possible by cutting back on UV shielding." Those are your words. Though it certainly seems plausible that that is at least a portion of the tradeoff.
    As a tradeoff, I am gaining enormously from the greatly increased tread life, and losing nothing to the reduced UV protection, as my tires still get scrapped for tread loss before UV degradation becomes an issue.
  3. Paul Gregory
    2,287
    604
    Alberta
    2024 Prius Prime
    XSE
    Then thank you for correcting the record.
  4. bisco
    52,611
    so, drive without tyres, or don't drive at all? seems like rocket science to me
  5. hill
    8,985
    Not knowing carbon Tire compounds from Shinola, went and did a Grok search real quick. AI seems to think virtually same amounts of carbon are used on the tire side walls - where it's most likely to be affected by UV & it's primarily the tread that gets the fancy schmancy compounds that increase traction, improved rolling resistance Etc. Besides, average driving equaling 12,000 Mi a year means tires are pretty much getting ready to be replaced at the ½ decade mark anyway.
  6. bisco
    52,611
    what tyres are you running?
  7. Paul Gregory
    2,287
    604
    Alberta
    2024 Prius Prime
    XSE
    It seems like looney-toons to me.
  8. Leadfoot J. McCoalroller
    8,202
    7,707
    Pennsylvania
    2018 Prius c
    As if "holding air" is the only thing a tire needs to do. :rolleyes:
    hill and fuzzy1 like this.
  9. bisco
    52,611
    interesting answer, thank you
  10. Paul Gregory
    2,287
    604
    Alberta
    2024 Prius Prime
    XSE
    Having the common sense to know why, is important
  11. bisco
    52,611
    sounds more like engineering sense, hardly common
  12. Paul Gregory
    2,287
    604
    Alberta
    2024 Prius Prime
    XSE
    I'm just glad I'm not you,
    is all.
  13. ChapmanF
    18,820
    For the record, I also am glad Paul is not bisco.
  14. bisco
    52,611
    me 2, think how I feel being me
  15. bisco
    52,611
    that'd be like a double whammy :oops:
