My 2017. I'm the second owner and I don't know how many EV miles it was possible to drive when the car was new. Now depending on the outside temperature it is from 20 to 30 miles. On average 25.
Regular, not Prime. From securitas company and Wheels seller. I bought 2019 Prius in 2020 at Golden Gate Adesa with 198k miles and a head gasket has failed and the CR 3.5 all OK.. 200k miles in a year and a half! fixed it and still runs like this
If you look at the Hwy_boy’s most recent reply to their pinned comment on the above YouTube video, they have a 2019 Prius prime with 522,000 miles on it as of nine days ago. The YouTube video is of the Car Care Nut inspecting it about a year ago with 341,000 miles on it. I think I remember Hwy_boy mentioning they have only done scheduled maintenance and transmission fluid drain and fill every 80,000 to 100,000 miles.
I’m at 145k miles on my 2020 prime. Only issue so far is the stupid smart 12v battery is a puny worthless piece of crap, and car won’t start after sitting at the airport for a week. But, I have a portable jump pack there in the car so that’s a relatively minor inconvenience. I bought it used in 2022 with 109k miles and a solid maintenance history. It’s running great and has averaged 63.7mpg over the 36k miles I’ve put on in 18 months. I also have a 2017 prime w 140k miles. Same thing; only issue so far has been 12v battery. So far I’ve only done oil changes every 5k-10k miles, and throttle plate cleaning every now and then. The 2017 seems due for new spark plugs bc of rough start when the engine kicks in cold. I have maintained four different prii for over 500k of driving thanks to the folks here at PriusChat ! we were chasing the California HOV lane stickers. Each one could’ve run to a million miles or more. Looks like we’re still waiting to see what issues the first gen 2017-2022 prime will have…?
Hwy_boy just re Hwy_boy just recently sold his 2019 prius prime with ~ 620K miles on it due to headgasket issues. He drove mostly highway miles and barely ever plugged it in. .
Did he monitor his ECT or ever change his electronic coolant pump? They're know to get lazy and/or intermittent around 150K miles of 'normal' driving. Probably should start monitoring or preemptively replace it around 300K all highway driving, rather than rely on the dummy lamp. Just my two-cents.....
I believe he changed the water pump at about 490,000 miles, but only after it through a code, not preemptively.
So he could've been running hot for a good long while without knowing it - since it's mostly highway driving. Pop goes the head gasket. I plan on installing one of those HUD units and program an alarm - before I break 100K miles; so I can hopefully side step this issue.
Interesting. What coolant temperature would you set the alarm for and would this alarm you before any codes or check engine light?
The Prius doesn't store overtemps or trigger the CEL. I believe water pump over-rev or under-rev may trigger a CEL or if the pump is totally dead, full open or close circuit. Just a lonely flashing or solid temperature lamp. If you drop back below the threshold, the lamp will extinguish. I find it amusing when people say that the lamp only came on for a second then disappeared when they release the accelerator pedal, so they think everything is A-Ok... I drive in the Sierras a lot so I know I'm stressing and heating up the engine on those long climbs. I understand the cars normal operating temperature is 185F-205F, so I thinking of setting the alarm at 210F. If the alarm goes off on hard climbs; I'll know to back-off. The OEM lamp triggers around 248+F. So you could be running hot 245F all day long, day-in and day-out; not knowing that your chipping away and headed for a head gasket failure. All of my other cars had a temperature gauge; don't know why these don't....
Good to know. Most of my miles are in reasonably flat populated areas, but I am doing a road trip to Yosemite in May. I will definately plug my OBD scanner for the trip to monitor the coolant temp. Unfortunately, most car manufacturers have eliminated the coolant temp display gauge on the dash in their newer models.
I feel like I'm slacking with only 151K miles in 107 months of owning my '17 Prime. Mechanically and battery-wise, it seems as good as new. Some scrapes and dings, occasional clicking noises from the inlet air door, that's about it. An ex girlfriend who I helped get a deal on a '17, 3 months after I got mine, recently sold hers. After discount, rebate, state EV incentive, and Federal tax credit, the car had cost her $16K new. Somehow, I had gotten her a $500 better deal than on mine. Maybe the second negotiation session was a charm. Anyway, she recently sold it with 162K miles on it, for $10K, with numerous scrapes and dings. She was quite happy with having owned it for under $0.04/mile depreciation, while also getting reimbursed a lot of business mileage. So, she actually made money owning the car (if you ignore operating costs, and maybe even if you don't ignore them), as I had predicted when I convinced her to stop using a minivan for commuting and business miles.
Just back from my road trip to Yosemite. The coolant got up to 208.9 degrees F going up the grapevine in 91 degree F weather, so I turned off the AC for a bit and slowed down below 55 mph behind a truck till it went back down. I took the 41 from Fresno to Yosemite instead of the Tioga pass, so the trip wan't too hard on the cooling system apart from the grapevine in the afternoon. This was in my 2013 prius C with 173,000 miles. I am trying to limit the miles on my prime until I hit 150,000 inorder to keep that HV battery warranty as close to 10 years as possible. An alarm would be nice, so you don't ever have to take your eyes off the road.
