TPMS light confusion
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by splitter, May 27, 2026 at 7:26 PM.
Tags:
  1. splitter
    splitter Junior Member
    NY
    Hi everyone!
    I have a confusion about the TPMS light.
    Two TPMS sensors have gone on my wife's 2006 Prius - the TPMS light flashed on start then eventually settled on solid.
    I bought 4 Denso "OEM fit" sensors from RockAuto hoping to save a bit of money (DENSO 5500103) and have booked in at a local shop to have them fitted. They seemed a little confused about whether they would need to "program" them or not (they are pre-programmed I believe).
    To save some time and confusion, I decided to add the new sensor IDs to the car via TechStream before the new sensors are fitted.
    After doing this, the TPMS light has turned off. The sensors are still in the box, not installed. I drove round for 15 or so minutes, and the light did not come back on.
    I'm very confused about this. I would have thought that with the new sensor IDs on the car, the TPMS light would again be on since they can't be showing any pressure.
    Have I misunderstood something about this procedure?
    Bonus question: Anyone familiar with whether these particular sensors need to be "activated", e.g. tpms tool trigger, rapid deflate/inflate cycle?
  2. JC91006
    JC91006 Senior Member
    16,888
    8,625
    If you put in new sensor codes, you can confuse the computer for about half an hour, if your drive exceeds that, your light will come back on
    PriusCamper likes this.
  3. rjparker
    10,744
    6,741
    They don't need to be activated. They have motion detectors to turn them on.
  4. Mendel Leisk
    42,090
    The car needs to be programmed to recognize the new sensors, hopefully possible with what you’ve got. Both prepurchasing the sensors and the “confused” shop does not bode well. It’d be preferable to go with a shop that’ll do “turnkey”, knows their stuff and supplies/guarantees the sensors.
  5. splitter
    NY
    My understanding with the "OEM" Denso sensors is that they don't need to be programmed. Instead, you just need to install and activate them (or maybe not...) and then add their IDs to the TPMS ECU via TechStream. I can do the latter step. I need the shop to install them (and possible activate them).
    On a related note, I drove around for nearly 40 minutes this morning and the TPMS light has still not come back on. I also turned the car off / on multiple times to try to force a reset. I find this very confusing. The IDs saved in the car's ECU are the new sensor IDs which are still in the box on the passenger seat. So the TPMS light should be on. Either it takes forever for the car to recheck the sensors, or I've stumbled across a way to disable the TPMS light, perhaps along the lines of this thread: Techstream and TPMS - ClubLexus - Lexus Forum Discussion
  6. JC91006
    16,888
    8,625
    I've had this same feeling when I changed the sensor ID. Trust me, it'll come back on. If it were only that easy to disable a TPMS light, we would forget about using sensors altogether
  7. PrimalPrius
    PrimalPrius Member
    135
    America
    A fairly easy DIY. Tighten a 2" cargo strap around the perimeter of the tire, set some 2x lumber on the floor so that it touches the tire but not the rim and jump on the rim to break the bead. Use a fishing line or string when removing the old sensor and installing the new one. A tool like this makes that step easier: More Information for PERFORMANCE TOOL 60501.
    To reseat the bead just adding air often works for me. Remove valve stem before air if it won't seat with the valve stem in place.
