TPMS light confusion
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by splitter, May 27, 2026.
Tags:
  1. splitter
    splitter Junior Member
    NY
    Hi everyone!
    I have a confusion about the TPMS light.
    Two TPMS sensors have gone on my wife's 2006 Prius - the TPMS light flashed on start then eventually settled on solid.
    I bought 4 Denso "OEM fit" sensors from RockAuto hoping to save a bit of money (DENSO 5500103) and have booked in at a local shop to have them fitted. They seemed a little confused about whether they would need to "program" them or not (they are pre-programmed I believe).
    To save some time and confusion, I decided to add the new sensor IDs to the car via TechStream before the new sensors are fitted.
    After doing this, the TPMS light has turned off. The sensors are still in the box, not installed. I drove round for 15 or so minutes, and the light did not come back on.
    I'm very confused about this. I would have thought that with the new sensor IDs on the car, the TPMS light would again be on since they can't be showing any pressure.
    Have I misunderstood something about this procedure?
    Bonus question: Anyone familiar with whether these particular sensors need to be "activated", e.g. tpms tool trigger, rapid deflate/inflate cycle?
  2. JC91006
    JC91006 Senior Member
    16,926
    8,637
    If you put in new sensor codes, you can confuse the computer for about half an hour, if your drive exceeds that, your light will come back on
    PriusCamper likes this.
  3. rjparker
    10,901
    6,841
    They don't need to be activated. They have motion detectors to turn them on.
  4. Mendel Leisk
    42,205
    The car needs to be programmed to recognize the new sensors, hopefully possible with what you’ve got. Both prepurchasing the sensors and the “confused” shop does not bode well. It’d be preferable to go with a shop that’ll do “turnkey”, knows their stuff and supplies/guarantees the sensors.
  5. splitter
    NY
    My understanding with the "OEM" Denso sensors is that they don't need to be programmed. Instead, you just need to install and activate them (or maybe not...) and then add their IDs to the TPMS ECU via TechStream. I can do the latter step. I need the shop to install them (and possible activate them).
    On a related note, I drove around for nearly 40 minutes this morning and the TPMS light has still not come back on. I also turned the car off / on multiple times to try to force a reset. I find this very confusing. The IDs saved in the car's ECU are the new sensor IDs which are still in the box on the passenger seat. So the TPMS light should be on. Either it takes forever for the car to recheck the sensors, or I've stumbled across a way to disable the TPMS light, perhaps along the lines of this thread: Techstream and TPMS - ClubLexus - Lexus Forum Discussion
  6. JC91006
    16,926
    8,637
    I've had this same feeling when I changed the sensor ID. Trust me, it'll come back on. If it were only that easy to disable a TPMS light, we would forget about using sensors altogether
  7. PrimalPrius
    PrimalPrius Member
    138
    America
    A fairly easy DIY. Tighten a 2" cargo strap around the perimeter of the tire, set some 2x lumber on the floor so that it touches the tire but not the rim and jump on the rim to break the bead. Use a fishing line or string when removing the old sensor and installing the new one. A tool like this makes that step easier: More Information for PERFORMANCE TOOL 60501.
    To reseat the bead just adding air often works for me. Remove valve stem before air if tire won't seat with the valve stem in place.
    Edit: If there is a big weight difference between previous and new sensor and old, it could have an effect on tire balance that can be noticed.
    #7 PrimalPrius, May 28, 2026
  8. rjparker
    10,901
    6,841
    Most likely the id programming in the car's ecu is done (as you indicated much earlier), the sensor motion detectors turn them on (activate not the proper word) and "possibly" you set the tpms alarm point at zero.
    #8 rjparker, May 28, 2026
  9. splitter
    NY
    Thanks, this is useful!
    Just in case, I reset the TPMS by jumpering 4 and 13 on the OBDII port for 30 seconds (diag mode appeared on MFD). I then re-registered the new sensor IDs. I drove around for a while but still no TPMS light - maybe it will just take a while to pop up.
    I've attached a screenshot of the TPMS data after the reset and re-registration.
    I'm booked in to get the sensors installed tomorrow. I was hoping to have the TPMS light present so it going off would indicate all sensors have been "turned on". I think I'll go ahead with the install, and then have to check afterwards whether the ECU is communicating with them.
  10. rjparker
    10,901
    6,841
    TPMS alarm initiation is normally done with the switch under the drivers dash. See owners manual.
    Take a picture of the ids before install, have them installed and then drive about 5 minutes or less.
    The id on this one is
  11. ChapmanF
    18,899
    Caution for anyone looking at the photo in #8 and thinking "Oh! So ID1 is rear passenger, ID2 is rear driver side, and so on!"
    Nope! The IDs don't go with particular corners. They're just four arbitrary slots to register your transmitter IDs in. You can make notes like in that photo to remember which one you put in which corner, but if you do, you have to remember to update the notes (correctly!) each time you rotate the tires.
    Also, if you have work done at a tire shop, they'll often use a tool that reads all the transmitter IDs and programs the car's ECU with them. They might do it for convenience without you asking. It can result in you having the exact same 4 transmitter IDs registered that you came in with, but not in the same numbered ID slots, so your notes will be thrown off again.
  12. rjparker
    10,901
    6,841
    You can also release some air out of working sensors while scanning to see which is which.
    Techstream also shows battery status. ID4 was low.
    In my case I was doing two and wanted to know where they were prior to going to the tire shop.
  13. fragglestickcar
    95
    New York
    I didn't have tools at the time, so used the scissor jack to debead, put in the tpms (didn't need any fishing wire for that), and went to gas station for air thinking bead would just pop back on. Nope. Had to shell out $10 to the pepboys guy to use the tire machine.
  14. splitter
    NY
    Quick update. Shop had no problem - they installed the new sensors, inflated then deflated (as per instructions in the box) and triggered them with a generic tpms tool to check they were active.
    They were reporting pressures/temperatures when I picked the car up.
    Also, I somehow forgot that my Autel AP200 can register the sensors IDs too, which is much less painful than going via tech stream.
    Thanks for the help!
    Brian1954 likes this.
  15. PrimalPrius
    PrimalPrius Member
    138
    America
    I tell people about the wire/fishing line because this one guy claimed that he dropped his sensor inside the tire and supposedly was unable to get it out and had to go to the shop anyways, but not until after digging out his spare tire LOL.
    Did you remove the valve core to get decent airflow?
    #15 PrimalPrius, May 30, 2026
  16. fragglestickcar
    95
    New York
    Pretty sure I did. But I mean, I don't see how a few more square millimeters makes a difference with the gaping space at the rim. Plenty of YouTube videos showing the lighter fluid pop-on.
  17. ChapmanF
    18,899
    The guys at my local Discount Tire seem to succeed reliably using a capacious hose from their shop air source. I think they upsized the diameter of that hose and made sure the piping had few restrictions on that path, so the valve core probably is the most significant flow restriction when they're doing that.
  18. rjparker
    10,901
    6,841
    Exactly
