Gen2 not starting, engine not being rotated, just a bump.
Discussion in 'Gen 2 Prius Technical Discussion' started by Axelbeltan, May 31, 2026 at 12:10 PM.
  1. Axelbeltan
    Axelbeltan New Member
    Today
    Las vegas
    Removed the tranny to replace the dampener plate. Reinstalled the tranny and now it won't start. The traction battery was replaced, now I am getting a p0a0f with a p3193, but I have fuel pressure and a full tank of fuel, but the fuel gage is showing empty, 1 bar flashing. I replaced a ground strap that was rotted off. It ran fine before I took it apart. Now it just bumps and doesn't roll the engine over at all.
  2. Tombukt2
    13,690
    2,478
    I don't ever remember any bumping usually when that thing starts to turn over the mass it rolls around a few times then stops . Like a real smooth big heavy starter with no lag it just cuts in .
  3. ChapmanF
    18,807
    Can you post a video? Maybe try to have the camera showing the crank pulley in front as the sound picks up the bump?
