Gen2 not starting, engine not being rotated, just a bump.
Discussion in 'Gen 2 Prius Technical Discussion' started by Axelbeltan, May 31, 2026.
  1. Axelbeltan
    Axelbeltan New Member
    Las vegas
    Removed the tranny to replace the dampener plate. Reinstalled the tranny and now it won't start. The traction battery was replaced, now I am getting a p0a0f with a p3193, but I have fuel pressure and a full tank of fuel, but the fuel gage is showing empty, 1 bar flashing. I replaced a ground strap that was rotted off. It ran fine before I took it apart. Now it just bumps and doesn't roll the engine over at all.
  2. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    I don't ever remember any bumping usually when that thing starts to turn over the mass it rolls around a few times then stops . Like a real smooth big heavy starter with no lag it just cuts in .
  3. ChapmanF
    19,054
    Can you post a video? Maybe try to have the camera showing the crank pulley in front as the sound picks up the bump?
