Buying a prius for the ecvt?
Discussion in 'Newbie Forum' started by last20, May 29, 2026 at 11:22 PM.
  1. last20
    last20 New Member
    Wednesday
    Iowa
    2022 Prius Prime
    Is buying a used prius bc it's equipped with a bullet proof ecvt the wrong reason? I could also add that the prius doubles as a emergency rolling generator and power camping trip too..
    I guess other major components could leave you stranded, but I thought the trans was usually the most expensive and weakest link. Then enter the cvt, which I wont rant about, but I own three manual's because they are cheaper and more reliable, not bc I like shifting.
    So yeah, I don't get out allot. I'm retired and thinking I'd get out more if I had a car that drove itself down the highway like a tesla.. Which the 2016-2022 prius can, and can perform even better with the comma openpilot..
    Anyway.. Should I keep looking for a manual civic, since Toyota screwed us when they went with a internal slave design?
    Thanks!
    52,598
    welcome!
    depends on how old and miles. yes, the trans is the most bullet proof part of the car, and cheap to replace because the salvage yards have an abundance.
    but an old(er) prius is weak on some expensive parts like the hybrid battery and brake actuator.
    especially if you aren't hybrid savvy and a serious diy'er with all the tools and skills.
    all the best!
    last20 likes this.
  3. last20
    last20 New Member
    Wednesday
    Iowa
    2022 Prius Prime
    Thanks Bisco..
    Can the seller condition his failing traction battery enough to sell? Sounds like I better invest in a scanner to be able to check how long ago codes were cleared.. And I'm reading cars from the salt belt and north might have better batteries than southern cars..
  4. bisco
    52,598
    any battery that has been reconditioned has a limited life. the problem is that there's no way to know how limited. people buy them to save money over oem, or sometimes to sell their prius. they come in a wide range of quality and price.
    northern batteries might do a little better overall, but not much. rust would be more of a concern, and some southern cars have been refurbished flood cars.
