My 2012 Prius V with 172,000 miles started having the oil light comes on even when the oil is full?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tina L Moore, May 20, 2026.
  1. Tina L Moore
    Tina L Moore New Member
    Lombard, IL
    What can be wrong and does it hurt the car to drive it with the oil light on and the oils is full while I wait for my appointment.
  2. rjparker
    10,877
    6,829
    I would not drive it anywhere.
    There are a couple possibilities;
    1. Actual low oil pressure with several potential causes but all severely damaging to the engine
    or
    2. Something is wrong with the oil pressure switch which is relatively inexpensive to fix and would not be damaging to the engine.
  3. ChapmanF
    18,889
    Are you seeing the light on all the time, or a lot, like easy to catch it that way? Or just blinking on now and then?
    If easy to catch, like on all the time, you could try pulling the wire connector right off the oil pressure switch, and secure it so it isn't touching any metal, and let the engine start up, and see if the warning light is still on. If it's on even when the wire isn't connected to the pressure switch, you've likely just got a wiring problem.
    If you have an ohmmeter, you could use that for confirmation, just clipping it between the oil switch terminal and grounded metal. It should show continuity when the engine is stopped. You want it to show no-continuity pretty much right away after the engine starts up. If that's what you see, then you could be pretty sure the right engine oil things are happening, and a wiring issue is the thing to track down.
    Tina L Moore likes this.
  4. Mendel Leisk
    42,192
    Clogged oil filter??
  5. wafwat
    wafwat Junior Member
    31
    Gulfport, MS
    2016 Prius v wagon
    There is no mention if this started after an oil change or not. If so, this my be relevant...
  6. ChapmanF
    18,889
    For anyone without the 18 minutes to watch it, that's a video about how people sometimes replace the car's original plastic cartridge oil filter housing with a metal version, and sometimes the metal version is made to fit more than one engine family by swapping its center standpipe, which is, therefore, removable. If the standpipe comes out with the filter cartridge during an oil change without anyone noticing, and the new cartridge gets installed without the standpipe present, loss of oil pressure and engine destruction can ensue.
    The recommendation in the video is to stick with the original plastic housing and it won't give any trouble as long as it isn't overtightened and oil gets changed reasonably often. I'm at 211k or so on my original plastic housing and I can confirm it's doing the job just fine.
    The video might not have much to say about Tina's situation, unless what's on the car happens to be one of those metal aftermarket housings, and would be kind of a freak situation even if it is.
    Tina L Moore and wafwat like this.
  7. Tina L Moore
    Lombard, IL
    Thank you, I took it to the dealership and they said I burn oil and that everything else is ok and just keep checking the oil level every 1500 miles and add oil if I need it. The service man also said I can drive it that way for another 5 years… do you agree with him? If so that would be a great relief to me.
  8. rjparker
    10,877
    6,829
    They can be bad oil burners. It only has about 4 quarts so if the oil light came on it was almost empty.
    An excessive oil burner can use a quart every 1000 miles - so it would be a good idea to check every other fillup.
    You may hear about oil additives and flushes. They don't work on this level of oil consumption.
    Make 5 years? Maybe if you don't drive much.
    #8 rjparker, May 24, 2026
  9. ChapmanF
    18,889
    Keep in mind that this Prius generation hasn't got any oil level warning light.
    The only oil warning light in this car is a loss of oil pressure warning light, otherwise known as the engine is destroying itself now light.
    The oil pressure might be lost because the oil level has dropped so low that it is below the oil pump pickup. Or something might be blocking the pump or filter. Or there is a hole in an oil gallery somewhere. Hugely worn bearings. That kind of thing.
    From post #1, it seems like you eliminated low oil level from being the cause. Level a little bit low can't be the cause anyway, but only level so low it's below the pump pickup.
    The only way this warning light can be on and not be an emergency is if it is false: if the oil pressure switch is signaling low pressure even when the pressure is fine, or there's a short in the wiring leading to the switch.
    If the light is on and isn't false, no, you can't drive it 5 years that way.
    #9 ChapmanF, May 24, 2026
  10. rjparker
    10,877
    6,829
    I think we might have a case of oil streaking on the dipstick mistaken for full.
    If the dealer added oil and the light stays off now, it was oil consumption.
  11. Mendel Leisk
    42,192
    What can help: pull and wipe the dipstick, wait 5 minutes (gives oil pulled up the dipstick guide tube time to run back down), then do the check. The side of dipstick facing front of car tends to be clearer.
  12. Tina L Moore
    Lombard, IL
    Ok thank you
  13. Tina L Moore
    Lombard, IL
    I took it to the dealership where I bought it and the light was on when I left and the next day it was off and so far has stayed off… I will have my mechanic do what you suggested once I get an appointment- they are honest and so I have to usually wait 2 weeks for an oil change.
  14. rjparker
    10,877
    6,829
    If you wonder why it's easy to smear the dipstick oil level, here is the twist and turns it goes through when pulling it out.
    BiomedO1 and Air_Boss like this.
  15. BiomedO1
    4,443
    2,341
    Left Coast
    1. You really shouldn't be driving a car with your oil lamp lit - It will destroy your engine; if it's NOT a false alarm. A car in that failure mode should be towed to avoid further damage.
    2. You never really addressed what the "mechanic" actually found or did to remedy the issue.
    I agree; a car that burns oil needs it's oil level checked at EVERY fill-up; until you get an idea of the rate of oil burn. You should start looking for a replacement car too. Depending on the rate of the oil burn, it's likely to kill your CAT sooner rather than later. No big deal if your not registered in a CARB state.
    Good Luck.......
    FWIW; My old GMC has a slow power steering leak from old, dry, hardened seals. Well I kinda over-filled it in preparations for a camping trip into the Sierras. Three quarters way up the mountain and 30 miles from civilization, my oil lamp lit-up and the ECU placed everything into limp mode. I instinctively switched OFF the engine and coasted onto the shoulder. I knew everything was topped-off, because of the early morning check and didn't add engine oil, so couldn't have left the oil fill cap off. Found the oil sending switch, directly below the power steering pump sump - soaked with power steering fluid. Sigh of relief - Cleaned it off and restarted. Everything good again...... The power steering fluid, bridged the oil sender, making the ECU think there was a low oil pressure issue.
  16. Tina L Moore
    Lombard, IL
    Here is an update:
    When my gas went to half full the oil light went out …. The dealer asked me if I had added oil and how much, I said, I did and half quart. He said everything was green, I burn oil just check it every 1000 miles. Later that week a friend told me that her car was doing the same thing- she took it to her mechanics of 30 years and they asked her where she buys her gas. She said Costco- they said many people have been having the same issues and they buy their gas at Costco!! Her mechanics told her to get fuel injection cleaner and put in 2 oz and fill the car with Shell gasoline. That solved the oil light issue. I also get my gas from Costco and so I did what she did and the oil light has not come back on since. The mechanics told my friend that Costco is watering down their gas ….
    I would appreciate comments from the community as this seems to have solved the problem and I actually didn’t have to add any oil which is why the service mechanic at the dealership asked me how much I put in.
    Thanks in advance for your feedback !
  17. Tina L Moore
    Lombard, IL
    Ok the oil light came on again-
  18. rjparker
    10,877
    6,829
    It certainly is not caused by gasoline regardless of brand. The mechanic who suggested that must be rather uneducated.
    You need to check your oil level first. Being down a quart is not enough to turn on the oil pressure light.
    Going back to the dealer again makes sense. Ask if they actually did anything the last time. Ask them to change the oil and filter.
    This resolution of this problem is important to the life of your engine.
    #18 rjparker, Jun 8, 2026
    BiomedO1 likes this.
  19. rjparker
    10,877
    6,829
    One more sanity check:
    1. This is the light you are seeing, correct?
    2. Did the dealer actually charge you for anything or did a service advisor just talk to you and then said everything was fine?
    #19 rjparker, Jun 9, 2026
    BiomedO1 and Brian1954 like this.
  20. Tina L Moore
    Lombard, IL
