Connected Services and Toyota Selling Your Telemetry
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by lohikaarme, May 30, 2026.
  1. lohikaarme
    lohikaarme Active Member
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    Other things come to mind. When I disconnected the DCM, I did not disconnect the battery. I did have the key away from the car. Maybe if all else fails, reconnect the DCM, see if that restores the compass, then shut down the car and disconnect the DCM again and see if it sticks?
  2. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    I think it's getting closer. It seems like it's 90 degrees out of whack.
    I might take another drive after dinner, maybe do some circles counterclockwise this time.
    Driving around with the diagnostic screen on showed:
    -One, maybe two, yellow squares (Date/Time), and then disappear, but enough to snag the date/time and provide it to the dash
    -No blue squares (Position). No Lat/Lon in diagnostic screen. Which is as it should be. :)
    If it is indeed recalibrating itself, it would be nice if it could be sped up.
    What speeds it up probably is the Lat/Lon info from the head unit, which is likely unavailable because there is no hardwired GPS antenna signal getting to the head unit. Although, the head unit can still sporadically pick up the time component without an antenna.
    That's my theory.
  3. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    I've given up for now.
    I'd probably break some plastic if I went in to experiment, so I'll leave well enough alone, for the time being.
  4. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    Went back in. Restored to original. Compass works perfectly. DTC cleared. Since Toyota connect was waived, I'm gonna stick. Future trade is also a consideration.
    Anyone want the autoharness.com harness for postage?
  5. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    My harness is arriving Monday. After driving for a few days the only issue I see is that sometimes apple maps/google maps/waze does not track properly but then it will suddenly snap into place. IF the phone is connected via USBC then it works perfectly every time. I guess it tries to use the car GPS first if it is wireless carplay. I am not going back to connecting the DCM. It is worth it to just plug the usb cable in for me... Especially after seeing the LexisNexus stuff.
    My hope is that this thread serves as future reference for anyone looking to do this. It will have the howto, the pros and the cons.
    Here is the letter I received from LexisNexus today. Minimal redactions where it makes sense. I looked into their site using the provided password to download the 62 pages of information they had on me!
    phasechange likes this.
  6. soft_r
    soft_r Active Member
    198
    167
    Beverly Hills
    2024 Prius
    Glad to see other people are taking their privacy and security seriously. Good for all of you. (y)
  7. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    Got the harness early. Everything back together. Bluetooth speaker works. My compass still aligns, not sure if that will ever change but I never use the compass. "my map is my compass!!" - - wireless car play map syncing could be questionable, no issues when plugged in which is how I intend to run it. LexusNexus data provided, delete request being processed, do not sell request complete and connected services disconnected. The DCM is still in the car just not plugged in. If I ever go to sell, it is simple enough to restore as per my instructions. I would say the mission is accomplished at this point.
    Georgina Rudkus and VelvetFoot like this.
  8. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    Continuing to log the process. I noticed that even with the phone plugged in, Apple\Google maps\Waze tried to use the car GPS by default. After driving for a few minutes it will suddenly snap to the right location and there will be no issues tracking from that point onward. I suspect it is defaulting to car GPS.
    I am also wondering about that DCM. I have a theory but I do not know how to test it because the whole problem is that you just dont know what the car is transmitting. There are 3 FAKRA antenna connections that connect to the DCM and then out to the white singular connector that goes off somewhere deep into the car (these are coaxial connections so probably to antennas buried somewhere). The connectors are labeled on the DCM WBG and in turn, the colors of the connectors are White, Blue and Gray.
    Because I cannot leave well-enough alone, I decided to mess around some more. The rigged DCM on the center console
    Through some trial and error I isolated the GRAY FAKRA cable to be what is interfacing with the GNSS.
    The setup is to have only the gray FAKRA cable connected to the DCM, leave the white and blue FAKRA cables disconnected. The black square plug, white square plug and long flat gray plug are also connected to the DCM. The 3 FAKRA cables come together into the singular white connector (part number 86101-4E060). and that connector I have plugged into the antenna connectors (but only the gray one is making it through the pigtail to the DCM).
    So now I am wondering if the gray FAKRA is exclusively to receive GNSS data and if the white and blue cables are to wifi\cellular antenna and if disabling the car phoning home is only a matter of disconnecting the white and blue cables.
    Anyone have any thoughts on this? I cannot find any documentation on the connections. If the GNSS antenna is not able to transmit telemetry then this is way grogu. This is the way.
    #68 lohikaarme, Jun 6, 2026
    soft_r and phasechange like this.
  9. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    Oh, and I noticed, when you disconnect the connectors under the console and reconnect them, the car will ALWAYS throw an error the Parking brake is malfunctioning for 2 starts and then it will go away.
  10. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    AI overlords
  11. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
    And leaving all other connections as-is?
    I think the cell signal could jump the gap, per some other thread on some other forum, as I recall.
  12. Prodigyplace
    12,710
    11,848
    Central Virginia
    Many insurance companies are using Lexis Nexis to generate an insurance risk rating without stating why. I got my data and they apparently think my son and I am the same person. He had a minor accident a few years ago covered by his insurance accident forgiveness. Now, my insurance rates are a mess until (if) i can get them to untangle this mess. His name is also my middle name and we live at the same address. State law has restricted much of his public information but he obviously had a different SSN and drivers license.
  13. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    Yes this is the exact reason I am trying to find a way around the DCM sending your data regardless of what you want. Insurance companies are not going to care about who is driving, they are going to look at the telemetry of the car - as that is the risk they are insuring against - and irrespective of who is driving, they are going to determine the owner's rates based on how the car is being driven. The last time I renewed my policy with Geico, I had to delcare all the drivers that lived in the location the vehicle as housed, and I had to specify explicitly if they were allowed to operate my vehicle. Now once that happens, then I guess it is really free game to just look at how the car is being driven and determine rates without it mattering who was behind the wheel.
    Prodigyplace likes this.
  14. Mendel Leisk
    42,293
    Makes sense, and you can't really fault them for it.
    Google's saying our 2010 only reports crash data, relatively tight-lipped, and the pervasiveness has been escalating, with 4th and 5th gens.
  15. Prodigyplace
    12,710
    11,848
    Central Virginia
    That data did not come from the DCM though although my son has active Toyota subscriptions on his RAV4 Prime.
    I know the telemetry on my 2025 Camry is definitely error prone. Speed sign recognition is incomplete and inaccurate at times due to some signs not recognized. If you subscribe to navigation it is worse, depending on its database.As Toyota tries to move towards more self driving, many sensors in TSS 3.0 are woefully inaccurate, sometimes detecting imminent collision when there is none.
  16. soft_r
    198
    167
    Beverly Hills
    2024 Prius
    You should check out the Tacoma forums on this subject since you're in deep. disabling DCM / telematics in 2025 Taco | 2024 Tacoma Forum (4th Gen) News, Specs, Models - 2.4L, Hybrid, TRD Pro, Trailhunter, Off-Road, Sport, SR5 -- Tacoma4G.com and Simpler solution for disabling the DCM telematics - Silencing Antennas | Tacoma World
    They went so far as to trying to make a faraday cage for it but found that it could still transmit, as well as using terminators for the antenna connections to reduce the range.
  17. lohikaarme
    371
    361
    OH
    2024 Prius
    Limited AWD-e
    yeah to really do it right and still have the thing plugged in I guess it would need to be opened and have the esim desoldered
