Hello all - I hope you can help with a dilemma I'm having with my 2014 Prius Plug-In. I bought the car used three years ago with 133K miles on it. It ran fine until I started experiencing engine issues. I replaced the engine in February and right after I replaced it I started noticing I slight "whirring" noise, especially when I coasted in drive and "b" mode. I especially hear it when I'm driving over 50 mph. I've been told by at least two sources it is the transmission, and one transmission shop told me it could run like this forever, or could go out at any time. I'm sure someone besides me have had this issue, and am hoping I can get some idea what my next step would be. FYI, the car currently has 260K. Thanks for your time! Mike in Tacoma
post this in the appropriate gen 3 forum for more eyes, the drive train is the same, and there aren't many pip owners around anymore.
who did the work? what engine did you replace it with? I wonder if it could be the clutch. have you replaced the tranny fluid?
I disagree. Do not create duplicate threads for the same problem for the car. Information is then scattered across two different threads, which becomes very confusing.
Many people browse this PriusChat forum and look at "recent posts". They will see this thread just like you and I did.
Thanks for the reply. It was done by a reputable shop - used engine. He said that the transmission fluid was pretty dirty. They replaced it but it seems like it’s still dirty after some driving l. That’s why they think it’s a transmission was told I could either keep driving it and nothing would ever happen or it could go out at any time I’ve had it looked at a couple different shops, but I still have my suspicions
oof I’ve been checking this thread- not sure if I should repost? Wheel bearing sounds like a possibility but I’m no expert- please note that this sound was noticeable after the engine was replaced. Unsure if coincidence.
Don't use B mode as it will create noise on its own and has no legit purpose. Wheel bearing noise is most likely. These bearings will not get loose; they just make a noise that gets louder as you speed up. Normally with the engine running the noise is drowned out above 55. A decent mechanic would know the sound. You could get this diagnosed for free from a good independent suspension shop. Another possibility is the drive axle cv joints. There is nothing different in these parts from a non hybrid. Brake noise is also possible. Most transmission shops know nothing about a Prius eCvt transaxle which has no clutches, hydraulics or torque converter. They almost never fail. However I would ask the shop who swapped your engine if they changed the transaxle at the same time. Hopefully they did not. Sometimes it makes sense to have it diagnosed by a dealer and then seek advice on how to repair it.
B mode is kind of expected to come with a whirring noise, because it can make more use of the engine for slowing the car than D mode does. So you could just be hearing the engine doing what it's supposed to. But you're presumably using B mode about as often as you did before the engine swap, and you're saying the sound is more noticeable now? There could be various explanations for that.... Maybe the replacement engine just sounds a little different. Maybe the way the shop tightened down the engine mounts is transmitting a little more sound to the cabin. Maybe B mode is making a little more use of the engine than before, because of aging of the battery or seasonal temperature changes or something. Can you record the sound?
B mode will definitely make a lot of engine noise, it presumably spins up the engine to a high RPM and allows the combination of MG1 and MG2 to assist with engine braking (similar to compression braking in a geared transmission / downshifting). I personally would say drive it unless it's making some sort of extreme noise, who knows - it could be the work that was done, tolerances, engine mounts like ChapmanF said, or even the fact that this engine is functioning normally and the other one was not. On every Prius I've driven, B mode made a lot of noise, and that should be normal.
It spins the engine up only to whatever RPM it needs to for the amount it's decelerating the car. On a low grade or when the battery is still accepting some regen too, it may only run the engine up to 1800 or 2000 RPM and make a low hum not everybody even hears. On a moderate grade, or after the battery hits full charge and only engine braking is left, it'll drive the RPM higher. On a steeper descent with the battery at full charge, it might hit 4500 RPM or so, which some people describe as 'wailing' or the like (but still seems like a kind of moderate engine sound to me).
so I basically had three shops non-dealer tell me that’s the transmission. I might have a dealer look at it too. The shop I had to look at today told me that it was pretty dirty (the transmission fluid) and it had metallic particles in it a if that makes any sense.
that’s a really good idea. I’ll do that today and I’ll let you all know. I use the B mode as appropriate to charge the battery when I’m slowing down at a stop. No, I didn’t notice the sound until I got my engine replaced.
you’re correct the b mode does make more noise. I’m very familiar with that sound is. This is my fourth Prius and though I’m not a gearhead I’m pretty familiar on how it should run and sound which is usually very quiet. I appreciate the input. For a dead forum I’m getting a lot of good advice thanks.
