Connected Services and Toyota Selling Your Telemetry
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by lohikaarme, May 30, 2026 at 3:18 PM.
  1. lohikaarme
    lohikaarme Active Member
    361
    347
    NY
    2023 Prius
    Limited AWD-e
    Other things come to mind. When I disconnected the DCM, I did not disconnect the battery. I did have the key away from the car. Maybe if all else fails, reconnect the DCM, see if that restores the compass, then shut down the car and disconnect the DCM again and see if it sticks?
  2. VelvetFoot
    VelvetFoot Senior Member
    1,376
    529
    New York State
    2026 Prius
    I think it's getting closer. It seems like it's 90 degrees out of whack.
    I might take another drive after dinner, maybe do some circles counterclockwise this time.
    Driving around with the diagnostic screen on showed:
    -One, maybe two, yellow squares (Date/Time), and then disappear, but enough to snag the date/time and provide it to the dash
    -No blue squares (Position). No Lat/Lon in diagnostic screen. Which is as it should be. :)
    If it is indeed recalibrating itself, it would be nice if it could be sped up.
    What speeds it up probably is the Lat/Lon info from the head unit, which is likely unavailable because there is no hardwired GPS antenna signal getting to the head unit. Although, the head unit can still sporadically pick up the time component without an antenna.
    That's my theory.
  3. VelvetFoot
    1,376
    529
    New York State
    2026 Prius
    I've given up for now.
    I'd probably break some plastic if I went in to experiment, so I'll leave well enough alone, for the time being.
  4. VelvetFoot
    1,376
    529
    New York State
    2026 Prius
    Went back in. Restored to original. Compass works perfectly. DTC cleared. Since Toyota connect was waived, I'm gonna stick. Future trade is also a consideration.
    Anyone want the autoharness.com harness for postage?
