What is the BEST youtube video for Prius AC leak/recharge?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Jun 4, 2026.
  1. priuslyfe
    priuslyfe Member
    343
    70
    Pretty sure I have a leak in my 2007 AC because blowing warm air. I've watched many videos on recharging but all seem a little bit different from each other. Is there a best one to watch? For some reason I get sent to the youtubers whose camera skills give me vertigo tbh.
    - Some advice is that's common to "top it off" with refrigerant and others say don't do that? Which one.
    - If I use a R134a and leak detector/dye to recharge should the AC system be evacuated first? Is it necessary to attach a vacuum pump to a set of manifold gauges? I have seen both that its necessary and its not necessary
    - Where is the most likely place that a Prius AC may be leaking with 250K miles?
    - Are there any signs of leak locations PRIOR to testing it with dye? Either in the interior or in the engine compartment for Prius' specifically?
  2. PriusCamper
    PriusCamper Senior Member
    13,422
    5,420
    Pacific Northwest, USA
    It's a variable pressure system so the people who refill based on pressure are at risk of causing damage... Seems the people who top off just a little don't have much problem. But its properly done by evacuating entire system and then putting in a specific weight of lubricant and specific weight of refrigerant.
  3. priuslyfe
    priuslyfe Member
    343
    70
    isn't the ND oil lubricant only necessary if the compressor is affected? I can't remember someone mentioning adding lubricant otherwise.
  4. PriusCamper
    13,422
    5,420
    I've not done this job before but I suspect there is more flexibility on being a bit off on lubricant compared to being off on refrigerant...
    Looks like prices are coming down on equipment though and a repair shop can get one with a library of settings for most vehicles for as low as $1K but most still selling for $4K.
    As for us shade tree mechanics lowest price point would be one of these and then putting your tank on a scale to measure it: https://www.vevor.com/s/3,4-HP-portable-recovery-AC
    #4 PriusCamper, Jun 4, 2026
  5. Leadfoot J. McCoalroller
    8,278
    7,784
    Pennsylvania
    2018 Prius c
    The AC system in the prius is pretty delicately balanced and wants a precise amount of refrigerant to deliver real results. Save topping off for the last summer trip before you sell/crush the car.
    If you're just trying to get it to leak so you can spot the leak, you probably don't need to pull a vacuum. Save that for after you've really fixed it and you're doing the real charge.
    Condenser. They take rock hits, people back into them, and sometimes they just corrode. Beware cheap aftermarket condensers; there are some really crummy counterfeits out there that cost little to buy but your system will have much less cooling capacity, especially on the hottest days.
    When the refrigerant leaks out it won't leave marks, but when it pushes the ND11 oil out with it that will leave a mark and the oily spot will attract dirt quickly. So you're looking for oily dirty spots on the AC plumbing.
    Remember, it's a finicky balance. You want to use a very accurate scale to weigh the refrigerant as you feed it in for the final fill- try to get within a few grams for full performance.
    priuslyfe and PriusCamper like this.
  6. priuslyfe
    priuslyfe Member
    343
    70
    Thank you for the comprehensive reply.
    you bring up a great point. If a car has 250K.... what amount of diligence and dedication should you allocate to this job?
    this guy has a good channel, so hopefully this video might be helpful as I'm just starting to watch it....
    #6 priuslyfe, Jun 4, 2026
  7. rjparker
    11,040
    6,920
    While the condenser can be a leak spot and a leak there is relatively easy to see because of leaking refrigerant oil, the under dash evaporator is an even more common gen2 ac leak location.
    The evaporator leak is a major job so most people simply top it off on an old Prius. This is risky on a high voltage compressor. The whole system is less than one 16 oz can. Do not use r134a with sealers or refrigerant oil! The high voltage in the compressor can be shorted. Do not overcharge.
    Purge the line from the can to the fitting to eliminate air and then slowly add while watching the sight glass to clear. AC on. Do not overfill; stop when the bubbles clear.
    priuslyfe likes this.
  8. priuslyfe
    priuslyfe Member
    343
    70
    this is another dilemma...I presume that the leak, however big or small, will be difficult to fix (for me at least as I have no-experience with these matters). if your car has 250K miles whats the problem with using the sealer/stop-leak?
    I'll probably be the last owner of this Prius. Like my other Prius'.
  9. Hayslayer
    Hayslayer Active Member
    529
    320
    If your car is just suffering from a slow degradation of the AC system over a period of years, it's usually just due system seepage of a 19 year old system.. Use the above graph to add a bit of pure 134a. If it's really low, there may not even be the appearance of bubbles when the system is running, until after you add enough refrigerant to get adequate liquid in the system.
  10. rjparker
    11,040
    6,920
    The problem is sealer can burn out the compressor. A top off will usually last a year per charge. If not it will be empty in a week and will need a repair, typically a condenser or evaporator.
  11. pasadena_commut
    pasadena_commut Senior Member
    3,033
    942
    Southern California
    The leak in our evaporator wasn't slow. Just before we had that part replaced in a week it would lose enough refrigerant to stop working. Not wanting to burn out the compressor we stopped using the A/C as soon as the it showed signs of failing.
  12. priuslyfe
    priuslyfe Member
    343
    70
    is it pretty much always the evaporator?
    I've visually looked up and down for a potential problem area and can't find one. I have a feeling its the evaporator as well. Gonna try to do a leak test over the weekend to find out for sure.
  13. Leadfoot J. McCoalroller
    8,278
    7,784
    Pennsylvania
    2018 Prius c
    If it is the evaporator you might look to see if any of your leaktest dye has come out the evaporator drain tube- the one that normally dribbles water out. That's next to the front right footwell, under the car.
    System sealer is bad a few ways around. Again, the system is very carefully balanced, built to use the minimum amount of refrigerant to deliver performance through the normal service life of the car. Changing the interior volume of the system (space taken up by sealers) is going to upset that balance. The sealers can possibly have chemical reactions with the (different from most cars) ND11 oil. And lastly there can be electrical reactions with the electric compressor.
    The bad news is that with a finicky system like that, the way to make it work at all is to make it work right, and that can be a big bill on an old car.
  14. priuslyfe
    priuslyfe Member
    343
    70
    UPDATE:
    I think the best advice for this particular AC business is to not get caught up watching Prius AC issue youtube videos. Most of the general ACyoutube explain the hows and whys much better. Usually I search only for Prius youtubes but not all are made as well as some of the generalized auto youtube content.
  15. rjparker
    11,040
    6,920
    Most of the gen3 and newer Prii have pretty bullet proof ac systems. Gen2 has a reputation for slow evaporator leaks after 15 years.
    Evaporators are most likely to leak due to the condensation and thermal cycling caused by hot parts when off which quickly approach freezing when starting up.
    Uv dye works for many spots but there is no line of sight for the evaporator. It takes a quality refrigerant or ultrasonic leak detector to detect an evaporator leak, when off but pressurized using the supply vents.
    Tom Lech's videos are short but he is an expert and even drives a Prius. In this recent video he is using an Accutrak Ultrasonic tester to hear the leaks in an evaporator. $1200 and up for this quality model.
    Don't over think this. Carefully add clean refrigerant until the sight glass clears. Cold air capable of cooling a very hot cabin in 5 minutes should be the result if the compressor is still good (normally bullet proof in a gen2 unless...).
    If it lasts 3-6 months you know its a slow leak. Rinse and repeat when needed.
  16. priuslyfe
    priuslyfe Member
    343
    70
    Thanks for the comprehensive answer.
    I rented a leak detecting kit today however none of the staff at the auto-store knew how to use it. I've only come across videos that use other tools. Would you happen to know how to use this. I don't want to mess this up as its my first time messing with the AC in any car. I also bought an ounce of UV R134a dye.
  17. rjparker
    11,040
    6,920
    I would put some r134a in there first. See how it works. If it works leave it alone.
    You have to have refrigerant in it before injecting dye. The refrigerant pressurizes the system, allows the compressor to run and mixes with the dye. Both are added on the low side.
    It sounds like you have never added refrigerant into a system. Refrigerant can be dangerous if it freeze burns your hand or worse yet, your face.
    Add refrigerant on the low side. Purge charging hose first. AC on.
    Add refrigerant until the bubbles clear.
    Don't add dye unless the ac is working.
    Dye Instructions - follow the instructions to purge air in the injector hose, then follow instructions to inject dye. Dye can make a big mess so wear old clothes and hand and face protection.
    #17 rjparker, Jun 5, 2026
  18. priuslyfe
    priuslyfe Member
    343
    70
    other than putting the nozzle on the cold-end, not sure how to add the dye. I thought it was a hand-pump (the silver thing). It's not.
    how to use if you happen to know how?
    thanks.
  19. rjparker
    11,040
    6,920
    Start with A1 then go to B1 on the instructions. Your picture is not very clear so you will have to read them.
  20. priuslyfe
    priuslyfe Member
    343
    70
    yeah i read the instructions (the auto-store manager also read it). neither of us could really understand how to fill it (the silver injector) as there are no holes and it doesn't seem to be able to screwed apart (he tried at least).
