Pin size for L7
Discussion in 'Gen 3 Prius Accessories and Modifications' started by RonP, May 17, 2026.
  1. RonP
    RonP New Member
    SC
    I’m trying to find the pins to add to the L7 BCM connector. I have tried AI to find them, that was a nightmare. I have purchased every size pin, except the ones that fit. I’m trying to hookup the light sensor on the dash, I have ran the wires just need to pin it to the BCM. I have already bought the stalk with the auto function, pinned its connector, but it also connects to L7. So if anyone know the connectors female pin, please let me know.
  2. ChapmanF
    19,020
    Yeah, those are the little 0.5 mm non-waterproof ones with "no information for this terminal" because they're not in Toyota's distribution. The real ones look like this:
    and the ones I made look like this:
    where the 0.7 mm thing is a random end I clipped off some electronic component some time, and I used it as a form to wrap some wire-wrap wire around eight or nine times. You can read about it ➡here⬅.
    RonP likes this.
  3. RonP
    RonP New Member
    SC
    It took me a wile but I found the actual pins that fit, they are 17-1827855-2CT-ND I got them from the DigiKey website
  4. ChapmanF
    19,020
