2007 Prius ABS help
Discussion in 'Gen 2 Prius Main Forum' started by AmandaC, Jun 8, 2025.
Tags:
  1. AmandaC
    AmandaC Junior Member
    17
    Washington DC
    I have a 2007 Prius almost 200k miles(I've had since 2011). Last year I had the ABS pump (on the invoice they called it a ABS control unit) replaced and I got a used part (still $1300) because I had recently lost my job. A few weeks ago my check engine light came on - I took it for an oil change at an oil change place and when they gave me the car back the ABS lights were all on.
    The check engine light was the Mass Air Flow sensor. They said it was coming up that the ABS pump needed to be replaced again. This place specializes in asian cars and basically costs the same as a dealership so I am going to take it somewhere closer to me because I didn't love how they handled the brake situation both of these times. I literally started crying after they told me that - I had already spent almost $3k that I didn't really have on it almost a year ago. They also told me that I could just keep driving it without getting it fixed and that alot of people do that. It drove fine for a couple of weeks but this weekend I had to press down on the brake pretty hard to get it to stop which is super scary to me. I don't like the feeling of being scared every time I drive and I'm not in a place to get another car right this second either so I'm just going to take it somewhere else to see if it can be done cheap er than $3000. The current place wants $2000 just for the part.
    Is it possible the oil change place did something or was that just a coincidence? If the used parts are so unreliable for this - they should not even be offering it. They only warranty used parts for 90 days. Also does anyone have any recommendations for me here?
    Also I am located close to Washington DC if anyone in this group is also in the DMV. Thanks Everyone.
  2. ChapmanF
    19,044
    We don't need to know what they said it was coming up, we need to know what the actual trouble codes are. There are on the order of a couple hundred that can make those lights come on, and a lot of them have nothing to do with replacing that part.
    If you don't have the actual trouble codes from the shop, you can get them yourself with a good scan tool. If you don't have one of those, you can get the codes yourself this way: Blink (a/k/a Flash) Codes – How to. | PriusChat
    So post the codes here, and then we can say more.
  3. AmandaC
    17
    Washington DC
    Thank You! They did not give me any. Is the DIY way easy? I'm not a car person so I don't DIY anything on my car except like the windshield wipers.
  4. Tombukt2
    13,868
    2,521
    No you personally will not be diy this now you may have a partner that is capable I don't know you. Wal Mart tools and s few things . But not going they're yet . Don't be scared Prius stops how long it takes is the thing now . Wash DC and MD burbs is pretty slow going we gotta house off Honeywell ln 20814. You've got some thinking to do .needs desires etc . What do you do use car for work ?
  5. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    That sounds like the full retail price (and then some) they are quoting you. You can buy it with a significant discount that would be closer to the wholesale price.
    For example, Olathe Toyota will sell you the part for their Sale Price of $1,134.00. This is (recommended) retail $1,519.88 minus a 25.4% discount of $385.88.
    BUT let's not jump the gun, if you can post the codes, as advised by ChapmanF in post #2, to see if you even need to replace that part.
    #5 dolj, Jun 9, 2025
  6. AmandaC
    17
    Washington DC
    Thanks! This place helped me figured out a problem that both my regular mechanic then and a dealership couldn't (something completed different) a couple of years ago so I kept taking it to them but the prices are super expensive. One review even said they quoted more than the dealership. I found the same part last year on the Toyota part website for alot cheaper and was able to get them to cut off like $200. They claim they can't get the parts at that price. Anyway - I'm going to get a second opinion and ask them to tell me what codes are coming up.
    What I didn't like this past time is they gave me the car back and all the ABS lights were still on(they never said a word about it even though I told them when I called) and then told me those lights were already on when I brought the car in. Like what? In addition to the prices.
  7. Tombukt2
    13,868
    2,521
    Why some folks scared of these type vehicles.lights can just pop off anytime . I mean we're close to twenty years old . So that's pretty good in itself . That's Corolla family reliability.
  8. ChapmanF
    19,044
    If you hold a proper license for bending a paperclip and you can count to holes 4 and 13 in a socket with two rows of eight holes, and count some light blinks, you can probably do the DIY way of getting the trouble codes. Everything is always harder the first time you do it and easier after that. Whether something is 'easy' or not is often relative to whatever you'd have to be doing instead. Going and paying a shop to get the codes instead is sometimes easier, and sometimes not (like in cases where the car isn't mobile, or where saving up the needed amount to pay the shop isn't 'easy').
    Maybe Tom was thinking of DIYing the actual repair (which could be challenging work, depending on what is really needed, which is what getting the codes is for). I hope he wasn't thinking just of reading the codes. If I were going to say "I don't know you" then I also wouldn't assume you need to ask your "partner" for help counting light blinks.
  9. Tombukt2
    13,868
    2,521
    Yes the fixing .
  10. Classic Car Guy
    Classic Car Guy Active Member
    506
    136
    Northwest, USA
    My car is doing an on and off ABS warning situation with 175k miles.
    Does anyone knows if they made a conversion of ABS to direct brake manifold? They sell an electric brake booster to help.
  11. Tombukt2
    13,868
    2,521
    You're just getting the warning and while the warning is happening do you notice any difference in breaking pedal at all . I've had two gen2 that drove about 2 years with lites on .
  12. Tombukt2
    13,868
    2,521
    To sort that type of conversion out and sort the parts out and separate all the systems and make it work would cost more than the 800 part
  13. rjparker
    11,125
    6,981
    No conversion system and no rebuilts. That brake actuator is an integral part of the hybrid system. Even if you jerry rigged a Corolla master cylinder in its place, you would have no regen and the car would quickly go to limp node if it ran at all.
    Much less new price
    https://parts.olathetoyota.com/oem-parts/toyota-actuator-assembly-brake-400344647?srsltid=AfmBOoqE7ZaleyBHd594UEzKNgIQsyBx04mGudF3uZCMqtroUKvWnp_i
    #13 rjparker, Jun 7, 2026
  14. Classic Car Guy
    506
    136
    Northwest, USA
    That's the exact symptom "intermittently". In the morning the ABS light is on with the conventional hydraulic feel. Once it heats up and I re-start its back to normal.
    I just don't want to put a used part in it, or pay $3,500 for an ABS manifold. That's why I was looking at other options if it comes to that part.
  15. dolj
    dolj Senior Member
    8,652
    4,404
    How are you paying $3500, and what is this 'manifold' you speak of?
  16. rjparker
    11,125
    6,981
    From link above. Some dealers may have free shipping as well.
    #16 rjparker, Jun 9, 2026
  17. Classic Car Guy
    506
    136
    Northwest, USA
  18. Classic Car Guy
    506
    136
    Northwest, USA
    I thought I also need to buy the skid control unit?
  19. dolj
    dolj Senior Member
    8,652
    4,404
    The skid control ECU is not generally required. You only need to replace the Actuator Assembly and the associated resistor that comes with it, although many say they don't install the new resistor, as it is in a hard (but not impossible) location behind the dash. You would only replace the skid ECU if you have a problem that implicates it as the problem.
  20. Classic Car Guy
    506
    136
    Northwest, USA
    Hopefully after I replace this, I wouldn't have to go to a transmission / dynamo problem next.... [​IMG]
    So far the car is running good as far as the previous jobs like hybrid battery.
    The ABS trouble light is didn't show up today.
