2007 Prius ABS help
Discussion in 'Gen 2 Prius Main Forum' started by AmandaC, Jun 8, 2025.
Tags:
  1. rjparker
    10,825
    6,799
    No its not a good price. Look at post 16.
    Toyota provides kits with reduced prices when a tsb has been written
    Or you can get the standard part number with free shipping
    #21 rjparker, Jun 10, 2026 at 12:02 AM
  2. Classic Car Guy
    Classic Car Guy Active Member
    498
    134
    Northwest, USA
    Thanks for the follow-up and heads up.
    The promo code wouldn't apply. I must be doing something wrong...
  3. rjparker
    10,825
    6,799
    Buy from the dealer listed
    Classic Car Guy likes this.
  4. Classic Car Guy
    498
    134
    Northwest, USA
    Forgot to ask. what brake fluid do you guys use on 2007 with abs?
  5. Classic Car Guy
    498
    134
    Northwest, USA
    These are the parts I replaced back 75,000 miles ago. Being bought as a used car at that time. I just totally replaced everything I could think of in the cooling system that "may fail" at that time. I want to replace some of these parts again soon. on the 3 electric pumps, I know I need to replace the inverter valve soon. I notice that the original toyota inverter pump went up double from the last time I replaced it. I was looking online and there are alot of replacements that are lower price. Are any of those reliable if you guys ever tried it.?
    What about the rest of the 2 pumps with the (<<<<<<) line shown? Do I need to replaced them at this time too?
    Previous Job Done on 2007 Prius
    Date: 01-28-2019
    Mileage 100623
    Remove and replace the following parts for 100k maintenance
    Flush entire engine cooling system
    Refill with Toyota pink coolant
    Bleed air out of cooling system
    16401-20353 Toyota Radiator Cap
    90916-03093 Toyota Thermostat
    16325-62010 Toyota Thermostat Gasket
    16321-21010 Toyota Thermostat Housing
    16670-21010 Toyota Heater Control Valve <<<<<<
    16290-21011 Toyota Heat Storage PUMP ASSY <<<<<<
    04000-32528 Toyota ELECTRIC INVERTER PUMP
    89427-47010 Radiator Thermo Fan Switch
    16100-29157-83 Water Pump
    16271-21021 Water Pump Gasket
    90916-02570 Serpentine Belt
    Aftermarket Idler Pulley with Bearing
    90915-YZZF2-5 Toyota Oil Filters
    00272SLLC2 2-Gallons Toyota 50/50 Pre-Diluted Super Long Life Antifreeze/Coolant
    Inspect motor mount, engine oil, top all fluid levels, joint, tire pressure
    #25 Classic Car Guy, Jun 11, 2026 at 9:11 AM
