Another New (?) Lithium Conversion w/ Master BMS from Yesa
Discussion in 'Gen 2 Prius Technical Discussion' started by Pd30242, Jun 11, 2026 at 2:55 PM.
  1. Pd30242
    Pd30242 Junior Member
    27
    Chicago
    52,661
    @mudder might know something. I wouldn't trust any msg's word without proof
  3. Tombukt2
    13,724
    2,483
    Well that's what they all try and convey but seemingly this is very problematic . It has a battery in it an HV battery . No matter it's voltage and Killowatts and all that . Building a battery takes some doing . Or more doing than being done . Not sure .
  4. mudder
    mudder Active Member
    290
    397
    Chattanooga, TN
    I haven't reviewed this product. I will review it if/when someone sends me one.
    My recommendation is to ask the manufacturer if it has a per-cell BMS with supervisory control.
  5. Tombukt2
    13,724
    2,483
    I can imagine in the reply you're going to get in my head too.
  6. rjparker
    10,836
    6,802
    They are clearly attacking the last company who tried to retrofit lithium in place of niMh. Primarily stating the Toyota bms will overcharge aftermarket lithium modules and create reliability and safety issues.
    The marketing shows their new "master bms" measuring from one end of the assembly to the other end.
    The facebook "file" description states "It monitors pack voltage/current in real-time and intervenes (e.g., disconnecting or limiting) to prevent the vehicle's charger from pushing lithium cells beyond safe limits".
    The "Master BMS" mounts on top of the modules with thermal paste between.
    Nothing references individual module or cell monitoring.
    #6 rjparker, Jun 11, 2026 at 10:23 PM
    Brian1954 likes this.
