Another New (?) Lithium Conversion w/ Master BMS from Yesa
Discussion in 'Gen 2 Prius Technical Discussion' started by Pd30242, Jun 11, 2026.
  1. Pd30242
    Pd30242 Junior Member
    30
    Chicago
    52,750
    @mudder might know something. I wouldn't trust any msg's word without proof
  3. Tombukt2
    13,788
    2,497
    Well that's what they all try and convey but seemingly this is very problematic . It has a battery in it an HV battery . No matter it's voltage and Killowatts and all that . Building a battery takes some doing . Or more doing than being done . Not sure .
  4. mudder
    mudder Active Member
    295
    401
    Chattanooga, TN
    I haven't reviewed this product. I will review it if/when someone sends me one.
    My recommendation is to ask the manufacturer if it has a per-cell BMS with supervisory control.
  5. Tombukt2
    13,788
    2,497
    I can imagine in the reply you're going to get in my head too.
  6. rjparker
    10,958
    6,874
    They are clearly attacking the last company who tried to retrofit lithium in place of niMh. Primarily stating the Toyota bms will overcharge aftermarket lithium modules and create reliability and safety issues.
    The marketing shows their new "master bms" measuring from one end of the assembly to the other end.
    The facebook "file" description states "It monitors pack voltage/current in real-time and intervenes (e.g., disconnecting or limiting) to prevent the vehicle's charger from pushing lithium cells beyond safe limits".
    The "Master BMS" mounts on top of the modules with thermal paste between.
    Nothing references individual module or cell monitoring.
    #6 rjparker, Jun 11, 2026
    Brian1954 likes this.
  7. Tombukt2
    13,788
    2,497
    Sounds great to me and it's real easy to type that crap out on a computer and print it actually making it happen in your car you're trying to drive has been elusive the whole life of the model 20 years close enuff to it . And for the prices they want to charge for me to be the guinea pig no thank you I'll continue on with the nickel ..
  8. mudder
    295
    401
    Chattanooga, TN
    Please elaborate to help me understand what you're saying.
    In my opinion, the topology you describe – combined with the picture you posted from their Facebook – could not possibly provide the per-cell supervisory control required to safely operate lithium cells in a vehicle originally designed for NiMH.
    For legal reasons, I cannot definitely state that as fact without physically examining the product.
    However, in my opinion, this is not a safe pack for NiMH vehicles.
    I would ask the manufacturer "How does the pictured topology disconnect or limit the vehicle's OEM electronics from over-charging/discharging the cells? " If the 'BMS' were placed in series with either (or both) HVDC cables, then maybe it could fault open as needed. However, that safety topology would assert the CEL whenever it activated, which isn't a great user experience.
  9. douglasjre
    douglasjre Senior Member
    2,245
    750
    Null, NL
    Hold me back it's a Facebook marketplace listing. Pass me to popcorn
  10. rjparker
    10,958
    6,874
    That's right but people will fall for it and send money. It even happens here on Priuschat.
    douglasjre likes this.
