Dealer stripped oil-pan drain hole—need advice
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Gokhan, Jun 14, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,707
    2,658
    Paramount CA
    I have been taking my 2021 Prius Prime Limited to West Coast Toyota of Long Beach since it was new. I have never taken it anywhere else or done any oil changes myself. During the oil change on Friday, the technician flagged that an oversized drain plug had been installed, had leaked, and recommended a $1,000 replacement for the oil pan. Obviously, the damage was caused during one of the previous oil changes at this dealer.
    So, the dealer should replace the oil pan for free, right, since they are the ones who messed it up? Also, could it get worse afterward and leak from the pan if they do a poor job? Below are the instructions from the OEM repair manual.
    Gen 4 Prius Prime oil pan (and other engine components) replacement
  2. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    That sucks. Good luck.
  3. Winston Smith
    Winston Smith Active Member
    456
    328
    OH
    2024 Prius
    LE AWD-e
    Your state has robust consumer protection laws that include payment of attoney's fees as a penalty for violation. You might want to talk to a CA attorney before reviewing options with the dealer.
    If you don't get compliance from the dealer, you might also take it up the Toyota hierarchy to see what remedy they would enforce.
  4. Gokhan
    6,707
    2,658
    Paramount CA
  5. Gokhan
    6,707
    2,658
    Paramount CA
    I talked to the manager, and they will inspect it. If it is indeed my car with the oversized oil drain bolt, they will replace the oil pan for free because I have been taking it there exclusively for an oil change every 5,000 miles.
  6. Mr.Vanvandenburg
    1,359
    651
    2020 Prius Prime
    They stripped it and hope the story ended well.
    Gokhan likes this.
