Changing Oil in With Minimal Equipment.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by richard1540, Jun 12, 2026 at 3:31 AM.
  1. richard1540
    richard1540 Junior Member
    24
    Australia
    i-Tech
    I have a Gen 3 2011 with the original oil filter set-up. I want to start to change the oil and filter myself. I’ve always done it myself with other cars but with this Prius it’s impossible to get underneath.
    I’m travelling around and will be for the foreseeable future so can’t buy any equipment apart from the oil filter tool.
    If i manage to borrow a pair of ramps, does it matter if the car’s front is higher? What about if it was parked so that it was higher on one side- like parked on a highish gutter and i lay down in the gutter. If it was doable, which side should be the high side?
    As an aside my car goes so much better with synthetic 0W-20 oil rather than semi synthetic 5W-30. I’m in Australia and Toyota dealers seem to use the 5W-30 by default. A lot of mechanics don’t stock the lighter oil although that seems to changing somewhat with the proliferation of Toyota hybrids.
  2. ASRDogman
    ASRDogman Senior Member
    7,966
    4,046
    I drive the passenger(right) side wheel on a ramp. It is plenty of room to access the
    filter housing and drain plug.
    You could always jack up that side and use a jack stand, it won't take up much space like
    the ramp would.
    It moves the oil closer to the drain plug so you'll get most of the oil out.
  3. BiomedO1
    4,432
    2,331
    Left Coast
    Don't buy any aggressive ramps - you won't get it pass your air dam. The cheap plastic rhino ramps work great; no scraping.
    Change your oil and put in 3.5 quarts then drive it off the ramps. Double check fill level on a flat level surface. Then check for leaks.
    Simple....
  4. ASRDogman
    7,966
    4,046
    "I’m travelling around and will be for the foreseeable future so can’t buy any equipment apart from the oil filter tool."
    I use a 2x4, about 18inched long in front of the wheel, it raises just enough to get the wheel on the ramp without
    the trim touching the ramp.
    But since he doesn't want to carry a ramp around, that's why I said to jack it up and use a jack stand for support.
  5. Mendel Leisk
    42,163
    Ramps’ll work. If anything, having the front raised drains the oil more completely, the oil pan drain bolt being at the trailing edge.
    There’s a link in my signature with some oil change tips. (On a phone turn it landscape to see signatures)
    #5 Mendel Leisk, Jun 12, 2026 at 9:34 AM
  6. Tombukt2
    13,738
    2,486
    All you have to do is pull up on a friend's curb. Put passenger side up on the curb and go to work it should take 18 minutes with Walmart tools. the HOA lady shouldn't be able to make it up to the side of your vehicle before you start rolling the car off the curb ask me how I know this .
    frodoz737 likes this.
  7. CR94
    CR94 Senior Member
    2,793
    1,227
    Northwestern S.C.
    If you use ramps on a not-too-steep hill with the car facing downhill, the car will end up nearer level than if you use the ramps on a level patch. As Mendel says, it's ok for the front end of the car to be a little higher than the rear.
    Much like ASRD, I place short pieces of 2× wood just behind the ramps to keep the body from hitting the ramp.
    You can change the oil (but not filter) a lot easier and neater by pumping it out through the dipstick tube. That method can't get as much oil out as using the drain plug on some cars, but it can on a Prius.
  8. ASRDogman
    7,966
    4,046
    "You can change the oil (but not filter)"
    "I" can change the filter. Easily. I only right(passenger)wheel.
  9. Mendel Leisk
    42,163
    When I do oil changes I’ve got the front raised a lot: seems like the more it’s tilted the more oil drains. If I put in the specd 4.2 liters (with filter change) I’m an eighth to three sixteenths below top mark, needs another cup or so to bring it to top mark, if I bother.
  10. ChapmanF
    18,864
    You kind of incompletely quoted "You can change the oil (but not filter) a lot easier and neater by pumping it out through the dipstick tube."
    If you had an easy way to change the filter with that method, it would be worth posting.
    I think it takes a very powerful pump to suck the old filter out through the dipstick tube. Probably even less practical if you've switched to spin-on filters. And I'm still not seeing how to install the new one.
  11. rjparker
    10,849
    6,814
    Dogman seems to be saying he takes the right front wheel off to access the filter without having to struggle underneath the car.
    Some shops use a Mityvac Venturi vacuum extractor through the dipstick on every other 5k and replace the filter every 10k. Honda basically advocates this method.
    It can take time to vacuum it up because the dipstick tube only allows a small hose to be inserted.
  12. ASRDogman
    7,966
    4,046
    Well crap.. I need to read better before posting...
    I meant to type: I only RAISE the right(passenger)wheel.
    I can EASILY reach the oil filter housing and drain plug. Easy to change.
    Remember, the man doesn't want to buy a bunch of equipment, and likely doesn't have the
    room. To having a ramp in the car would likely be a pain. So a jack and jack stand would be
    less space.
  13. douglasjre
    douglasjre Senior Member
    2,236
    744
    Null, NL
    1 curb forn1 wheel
    14mm wrench
    Razor blade to cut open under covering
    Filter cup
    Rad
    Oil basin
  14. Mendel Leisk
    42,163
    Good lord.
    douglasjre likes this.
  15. rjparker
    10,849
    6,814
    The undercover helps cooling.
    The piano hinge modification
  16. TinyTim
    TinyTim Active Member
    400
    238
    Seattle
    I still want a Daytona low profile jack. Then I could do my own oil changes.
  17. ASRDogman
    7,966
    4,046
    I was going to get one of those.... But the ramp/wood block works well.
  18. Mendel Leisk
    42,163
    Even if you can roll it all the way back to the front jacking point (virtually the whole jack will be under there), there's a good chance the handle will be banging the underside before it starts lifting. a pre-raise of a few inches (say with low rise ramps) is more-or-less mandatory.
  19. TinyTim
    400
    238
    Seattle
    I probably will not remember what you said when I go to my Toyota dealer to have my oil changed next week. $45.95 including complimentary soda and cookies. I do not have a Daytona jack, I said I wanted one.
  20. CR94
    CR94 Senior Member
    2,793
    1,227
    Northwestern S.C.
    I had a better idea.
    Cut off the flap through the "hinge," then reattach it with six screws and two sheet-metal straps. To change the filter, remove two of the screws and the push-pins to take it off, completely out of the way, so the car doesn't have to be jacked up needlessly high for the flap to clear the ground.
