Remove front seats for amp
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Tatsuya, Jun 15, 2026.
  1. Tatsuya
    Tatsuya Junior Member
    Toronto
    2024 Prius Prime
    SE
    I'd like to remove the front seats to install a small Kicker amp. Does anyone know what kind of tool is needed to remove the front seats? I think a Torx wrench is needed, but not sure (or what size). Thx.
  2. Hammersmith
    Hammersmith Senior Member
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It is Torx. I want to say T50, but it could be T45 or T40. Sorry I can't narrow it down better. I've had to use all three sizes and I can't remember which size went with which component.
    If you get the repair manual from scorched, you should be able to find the size and the torque spec in there.
    Tatsuya likes this.
  3. notspam3
    notspam3 Member
    134
    71
    Toronto
    2024 Prius Prime
    XSE Premium
    If you can't figure out a fastener you probably shouldn't be removing and re-installing a safety item, especially when the only tools in your toolbox are a hammer and duct tape
  4. ChapmanF
    18,976
    Tatsuya likes this.
  5. Tatsuya
    Toronto
    2024 Prius Prime
    SE
    Darn. Sounds like a lot of work. I was hoping to move the dashcam battery (currently under driver's side seat) to beneath the passenger seat and install the amps/loc/fusedistrobox (currently in the trunk) to the driver side seat area. I wonder if I can just unplug the 12v battery, remove the seats, install the amps, reinstall the seats, then plug the 12v battery back in and it won't trigger any recalibration errors. Thoughts?
  6. Hammersmith
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I've had both front seats out. No issues. Just make sure to disconnect the 12V battery and wait for the system to discharge since there are air bags in the seats.
    I want to say there's more open room on the drivers side because that's where the JBL amp goes on the upper trim cars. I think the passenger side has more room dedicated to the rear seat floor vents. But if your dashcam battery isn't that big, it might not be a problem.
    Tatsuya likes this.
  7. ChapmanF
    18,976
    The OCS works using four strain gauges near the four supported corners of the seat, and is used to make sure the airbag will inflate with the right amount of force safe for an adult male, adult female, or child detected as being there, and in what position on the seat.
    Because the seat rail bolt holes and mounting locations aren't, like, precision machined, having them off and retightening them is pretty sure to change the readings of those strain gauges. You don't necessarily find out you have 'issues' or 'no issues' by looking for codes. If you get codes, that's great, 'cause it means you know about an issue right away. Otherwise you find out from what happens to the passenger when the airbag goes off.
    Best to just go ahead and recalibrate after the work.
  8. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Is this guy hallucinating? The occupant detection sensor is in the cushion and has nothing to do with the rails. (RTFM!)
    I've had my seats out many times as well.. The bolts are T50s and they need to be torqued to 27ft/lb. There's no need to calibrate anything unless the seat is disassembled.
  9. ChapmanF
    18,976
    Might you be thinking of the "belt-warning occupant detection sensor"? That's in the cushion, and is a simple yes/no sensor for the seat belt warning, and doesn't have any calibration.
    I was talking about the "occupant classification system", which has the more challenging job of determining what size and type of human, or non-human, is occupying the seat, for use in adjusting the airbag inflation force. The "occupant classification system" uses the four strain-gauge sensors located as shown:
    Note: both images above are from a gen 3 manual. It may be possible that Toyota radically changed how the OCS works in gen 5. I'm open to being shown wrong by someone posting the corresponding details from the gen 5 repair manual.
    That's the advice that's hard to beat. ;)
    (Again, from gen 3 manual; any changes found in the gen 5 manual would be welcome.)
