Why doesn't the app indicate 12V battery level?
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, Jun 15, 2026 at 3:02 PM.
  1. ChapmanF
    18,889
    If even one time. I've been left once or twice staring at a jump pack that read 100% a moment ago now reading 0% in less time than it took me to step from the engine bay to the door and reach in and try to start the car.
    In my gen 3, I've now taken to disconnecting the battery cable (easy in gen 3, it's right there in the underhood fusebox) if I think the battery might be that drained, then making the car READY with the booster pack, then plugging the battery back in.
    That's harder in gen 1 or 2, with no easy up-front way to disconnect the battery, have to get in the hatch. I don't know the story with the newer generations.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,309
    606
    Alberta
    2024 Prius Prime
    XSE
    My workaround, for now, after I've driven it on a short trip, is to let the car run for an hour until it shuts off on it's own. This way, I'm more assured that the battery is at full charge.
  3. LRO
    LRO Junior Member
    65
    79
    United States
    2024 Prius Prime
    XSE Premium
    No doubt you've done all this but for others reading this thread and having doubts about their vehicles cellular connectivity (and has the initially free or subscription Drive Connect service) ...
    Try using the "Hey Toyota" voice assistant liberally and ask how is the weather in "Moose Jaw". That'd certainly kick the vehicles cellular electronics into action whenever you have the feeling you're in a less than ideal location. The absence or speed of the reply might be quite telling.
    And, maybe if you ever want to ratchet up Toyota's interest/involvement from their side with 12-v battery issues use the SOS button to summon their roadside assistance for a jump start. Of course, when you have your own booster you can cancel that request. But, if you do have time, let them incur some expense. At a minimum, it serves as another data point for you to assess whether the SOS conversation over the vehicles cellular connection at that moment sounds good and clear and connected. And, Toyota will no doubt have a record of when and where you called from. (and it seems from reply #8 that the cellular connection can possibly work even when there isn't enough power to start the vehicle ... that would be appropriate for an SOS service)
    Finally, I found a couple pages from the Service Manual indicating that their Techstream system does log things related to the Data Connect Module (DCM). You'll see in the "System Operation Status Example" that it'll log occurrence time, whether roaming was on or off, if the vehicle was in a service area or not and what the strength of the cellular signal received by the vehicle was. No doubt, they can pull a report to coincide with the blocks of time you know you've had problems within recent history.
    And, if desired, the best do-it-yourself log of when a 12-v battery might be experiencing drain or charging can be had with a bluetooth 12-v battery monitor that in my case records the voltage every 2 minutes 24x7. I've learned what happens when the DCM is involved or that darn EVAP pump kicks in for 10 minutes in the middle of the night when I haven't been near the car for hours. It all leads to discovery and learning and understanding.
  4. Paul Gregory
    2,309
    606
    Alberta
    2024 Prius Prime
    XSE
    There's something to be said for redundancy, but I can't see using the built-in features, when the Google apps work just fine.
  5. LRO
    LRO Junior Member
    65
    79
    United States
    2024 Prius Prime
    XSE Premium
    Huh? OK, I understand.
    I only mentioned those Toyota apps and services because they absolutely will use the vehicles cellular connection and lend some real test to your belief about cellular connectivity being why your 12-v battery drains. It was not about advocating to use those terrible Toyota apps in any other way (I sure don't). But, unless your phone and Google Apps are using the vehicles cellular connection (which it wouldn't) then you wouldn't have a helpful way to gain insight into your beliefs. It's entirely possible your phone and vehicle are using two completely different networks or frequencies too. Here in the US at least Toyota publishes that they partner exclusively with AT&T and I found nothing about what network(s) they use in Canada.
    I'm just here on priuschat to learn and from time to time I'll comment if I think I have something to offer. Sorry I missed the mark entirely and strayed from the subject now that I look back at that. I have the same vehicle and that got me off track.
    Best of luck and hope you eventually get your problem identified or some less than painful workaround created.
    The dilemma of your situation reminds me of these two movie lines ...
    "Let's work the problem, people. Let's not make things worse by guessing." - Apollo 13
    "You're gonna need a bigger boat" - Jaws
  6. Paul Gregory
    2,309
    606
    Alberta
    2024 Prius Prime
    XSE
    This is really getting annoying. Where I currently live, there is no place to plug in my battery maintainer. Every time I want to use the car, I'm greeted with the message, "system disabled." The battery voltage is too low to start the car; usually less than 9 volts. So I open the hood, attach the booster, and drive the car. You'd think that 5 minutes of driving would be enough to charge up the battery. Oh no, I have to let it run for an hour on auto shutoff to make sure.
    I can't wait until I get my VW back from the shop.
