Weather Stripping wear. Known issue?
Discussion in 'Gen 5 Prius Main Forum' started by schja01, Jun 18, 2026 at 6:42 PM.
  1. schja01
    schja01 Senior Member
    1,866
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    1500 miles and got a note on my rear door recall worksheet that driver side weatherstripping was torn. I hadn’t noticed it but it is indeed worn. See photo. Anyone else have this happen. I’m ultra careful getting and out of the car. Would this be a warrantee covered item? Any suggestions appreciated. J
  2. Paul Gregory
    Paul Gregory Senior Member
    2,318
    607
    Alberta
    2024 Prius Prime
    XSE
    I noticed mine wearing excessively in the first month I owned the car. It consists of a low quality rubber, which is quite susceptible to wear.
  3. schja01
    1,866
    1,235
    Chicagoland
    2024 Prius
    Limited AWD-e
    Have you done anything to mitigate further wear? I put a piece of clear shipping tape over the “wound” but that seems amateurish.
  4. mingc
    mingc Member
    102
    70
    Portland, OR
    2023 Prius
    XLE AWD-e
    I had the same tear, same place. From the interwebs, I gather this is pretty common. I don't know what I was thinking, waited too long, and could not get it warranted.
  5. Jerry G
    Jerry G Junior Member
    Brooklyn,ny
    I had same issue. Dealership refused this as a warranty issue. I haven’t done anything to try to fix it yet. The dealership said they could put new one on for a charge.
  6. Hammersmith
    Hammersmith Senior Member
    2,428
    2,489
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If anyone decides to replace theirs, please do it yourself and don't pay a dealership to do it for you. I can't think of many things easier to do on a car. Significantly easier than an oil change. <5min.
    I'd be tempted to order from Japan on this. $33 per seal before S&H from Impex Japan. $70-$80 per seal all-in from US dealerships during good sales.
    FR - 62311-47060
    FL - 62312-47060
    RR - 62331-47060
    RL - 62332-47060
    mva, mingc, dicknose and 1 other person like this.
  7. VelvetFoot
    VelvetFoot Senior Member
    1,397
    541
    New York State
    2026 Prius
    Don't see it on my '26 with 13,000 miles...yet.
  8. dicknose
    dicknose New Member
    Toronto
    2024 Prius Prime
    XSE Premium
    I've got some minor wear on my driver side. Consider turning off the setting that slides the seat back when you turn off the car, this may help with rubbing against it.
  9. Blackat
    Blackat Active Member
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    I put some black cloth tape over it
  10. VelvetFoot
    1,397
    541
    New York State
    2026 Prius
  11. GcinFl
    GcinFl Junior Member
    46
    2024 Prius
