2019 Prius Slow Coolant Leak
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JeffPGH, Jun 25, 2026 at 3:51 PM.
  1. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    A couple years ago my Prius was leaking coolant. I took it to the dealership and paid them for diagnostics and they said I needed a $1500 Catalytic Converter. My buddy said that was a known issue and he did the bypass for me. A couple months ago my coolant started leaking again. I found out about the TSB from September 2019 (T-SB-0135-19) on the NHTSA government website about the coolant leak issue and called Toyota Corporate and complained and managed to get them to replace the pipe under warranty even though it was over the mileage for the warranty. I thought that would fix the issue but later on that day the coolant reservoir was empty. I put some coolant in and took it in the next morning. The looked it over and said everything was fine and there was probably air in the line. However, after I left I had to put coolant in around every 4-5 days. I took it back and they did a pressure test and they said it passed. They tried swapping the caps between the two different coolant reservoirs. It was fine for about a week then I had to put coolant in again. I ordered a new coolant cap just to try it to see if it might help and they said it would be here tomorrow. I had them change the spark plugs when they had it the other day for the coolant pressure test and they sent me a photo of them. It did look like one of them was a lot whiter than the others but I mentioned it and they didn’t seem concerned. One suggestion I saw online was to get an inexpensive block tester kit (chemical fluid test) to check the coolant reservoir for the presence of exhaust gases. I haven’t tried that yet. I’m not getting any check engine codes or smoke coming out of the exhaust. They said since they replaced the entire heat exchanger pipe with the new part in the TSB that probably isn’t the issue. Since there aren’t any check engine codes I could probably just keep running it and checking the coolant to make sure it isn’t low but I’d rather find the problem and solve it if possible. I did notice when I use the funnel to pour in coolant it seems to leak out the top a little bit by the plastic piece that sticks out with the little black end on it. I think that’s the overflow but I’m not sure. I might not be using the correct funnel.
    Does anyone have any ideas on what else to check?
    #1 JeffPGH, Jun 25, 2026 at 3:51 PM
    52,706
    is that dried coolant all over everything?
  3. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    It spilled when I was trying to pour it in with the funnel. I need to try to rinse it off.
  4. Brian1954
    Brian1954 Senior Member
    2,614
    1,035
    South Central PA, USA
    It looks like dried coolant all over the plastic reservoir. To troubleshoot, you need to monitor the engine coolant temperature. Watching the coolant temperature will tell you if the coolant is getting hotter than it should be.
    My theory is the engine water pump is going bad. The pump is not pumping enough coolant through the engine to keep it cool. The coolant heats up too much and creates enough pressure in the system that some coolant is released past the reservoir cap and out that little overflow nipple. This is common behavior for the Gen 3 Prius when the pump is going bad. I have not seen many reports for the Gen 4. Try putting a rag around the reservoir overflow to see if that is where the coolant is being released from.
    bisco and BiomedO1 like this.
  5. BiomedO1
    4,457
    2,348
    Left Coast
    ^ Yep; coolant splash in that area would indicate that it's boiling out. Kinda obvious to any experienced mechanic. Assuming the dealership did the pressure test correctly, (that's a BIG if) - since he should've noticed that "right off" - it's probably the electric ENGINE water pump not spinning fast enough to keep the coolant from boiling out - but fast enough not to trip the temp lamp at 248+F. Swapping coolant reservoir caps? They should've been inspected and a missing sealing ring would cause leaks and not allow the system to properly pressurize.
    You can still have a head gasket issue; if that leak test was performed with the engine warm or hot. The aluminum would expand and seal the leak - that's why we say to pay attention to early cold morning startup misfires that disappears after a few minutes.
    Good Luck.....
  6. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    Thank you for all the suggestions. As I mentioned the dried coolant was from when it spilled when I was pouring it in… I need to wipe it off and see if more coolant dries on it. I left the car there overnight so I think they did the pressure test after it sat all night.
    I found an option to monitor the coolant temperature using my Blue Driver OBD II port adapter. What temperature ranges should I be looking for to determine if it is an issue with the water pump? I”m sitting here at the airport and it is currently at 178 degrees Fahrenheit.
    #6 JeffPGH, Jun 26, 2026 at 11:41 AM
  7. bisco
    52,706
    it is interesting how polished the third spark plug is. maybe a borescope of the piston top to see if it's scrubbed
  8. BiomedO1
    4,457
    2,348
    Left Coast
    around 180F-195F nominal. you may touch upon 200F while crossing over steep mountain ranges.
  9. Brian1954
    2,614
    1,035
    Cruising on the highway should be about 195F. Going up hills on highway usually will not go above 202F. Just drive the car and keep an eye on the temperature.
    How many miles on the car, and how long have you owned it?
  10. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    Today I got a smaller funnel so the coolant wouldn’t spill when I put it in, I cleaned off the old coolant from the outside of the reservoir, and put the new coolant cap on. I’ll easily be able to tell if coolant is escaping from there now. The dried coolant in the pics was from the coolant I spilled when pouring it in because I had the wrong funnel.
    So far I don’t think the temp has gone above 200 so I doubt it is overheating but I’ve only checked it randomly throughout the day.
    I have 344,537 miles on it. It is a 2019 and I bought it new in December 2019. It has been the lowest maintenance car I have ever had. It’s just bugging me that the coolant is still leaking even after they replaced the whole heat exchanger/cat pipe. The dealership basically gave up on figuring it out at this point I think.
    I don’t even have the spark plugs because the dealership changed them and I don’t know much about doing a borescope of the piston top. I asked them to send me the pic of the spark plugs because I didn’t think they had been changed in a really long time, if at all, and I wanted to see what they looked like to see if one of them was really clean or anything like that. Judging by the picture they sent me I was wondering if the coolant leaking in and cleaning the one spark plug.
    I’m not a mechanic and don’t really have much experience working on cars. But overall the car is still running really well and if I can figure out why the coolant seems to be running low that would be fantastic. I might see if I can do the gas test myself. I saw a video of a test someone did on YouTube where they took out the spark plugs and put sheets of paper over the engine and tried to start it to see if coolant would come out and hit the paper to see if there was a leak and it did.
    At least there are no check engine lights and my Blue Driver OBD II reader said there are no misfires recorded in the computer.
    Brian1954 likes this.
  11. BiomedO1
    4,457
    2,348
    Left Coast
    At 344K miles; I would suspect and intermittent electronic coolant pump that hangs-up every once in a while.
    If you truly don't see any leaks anywhere; yet your coolant keeps going down - start tracking it. How much are you losing every refuel or x-amount of miles; so you can top-off before blowing something up. Use your Trip-A and Trip-B to keep track. I would take the car to another shop for another coolant pressure test, because the dealership obvious didn't do the test correctly. You can have a leak in your cabin heater core, coolant would dump out with the water accumulated by your AC core. There should be a slight sweet coolant smell when operating your HVAC system with the window all the way up and recirculating the cabin air. The dealership could've installed a defective EGHE that already had a leak. You can bypass the new unit; if the leak stops; you've got your answer.
    Good Luck......
