Gen2 OBD2 app review
Discussion in 'Gen 2 Prius Technical Discussion' started by mr_guy_mann, Apr 25, 2022.
  1. trsandy2000
    trsandy2000 Junior Member
    29
    What does PID stand for? I've seen it many times but without any info on it. Sorry. I'm new and I'm trying to get as much info as I can before I buy scanners and cables to try and diagnose the problem I have with my '07 Prius.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    Parameter ID, I believe.
    otatrant likes this.
  3. trsandy2000
    29
  4. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    (How) did you forward this to the developer to correct?
    How do the other scanner measure pump rpm (likely same PID) could help this lone polish soul.
    #264 priumium, Nov 22, 2025
  5. ChapmanF
    18,982
    For any PID, a scan tool has to know several things:
    • The network address of the ECU that should be asked for the value
    • The parameter ID to send to the ECU when asking (the ECU's response may include values for more than one parameter if they fit in the width of a response)
    • The offset and width in bits of the value in question, in case it's just one of several values in the response
    • The arithmetic that needs to be performed on the raw response value to get a displayable value in some recognizable measurement unit, and
    • The name of the measurement unit you end up with after doing the right arithmetic.
    I haven't tried out Car Scanner myself, but you can make some guesses about what might be wrong based on the exact behavior you see. Does it show a number for pump RPM that just never changes, no matter what the pump is doing? Then maybe the parameter ID or even ECU address is wrong, or the bitfield offset/width are pointing to the wrong place in the response.
    Does it give a value that changes, but the changes don't seem to have anything to do with what the pump is doing? Again, then, maybe the wrong address or PID or bitfield.
    Does it give a value that repeatably changes, and changes when you expect it to as the pump RPM changes, but seems like a bogus number for RPM? Then maybe the arithmetic formula is wrong (though this also could happen if the bitfield offset/width are wrong, picking up some but not all of the response value).
    So, a bunch of details go into properly retrieving and displaying a PID. Toyota doesn't freely publish those details; they are built into Techstream, and the non-free scantool vendors can get the details from Toyota by paying a license fee.
    Everybody building free alternatives has to laboriously reverse-engineer those details one way or another, which is hard, and easy to get wrong. Somewhere on PriusChat there's a big XLS spreadsheet with all the successfully-reverse-engineered gen 3 PID details, but last time I checked, these water pump PIDs weren't there, suggesting no one had succeeded yet, and that's probably why the Car Scanner dev hasn't got it either. If anybody does work out the details that are right, they can be passed along to the Car Scanner dev and should also get added to that spreadsheet so others can benefit.
    priumium likes this.
  6. rjparker
    11,040
    6,920
    In the app
  7. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    That these pid details are withheld are the definition of why Europe in my mind rightfully condemn this concept.
    Why would anyone want Toyota to force me to hack techstream?
    Right to repair and analyze OR entice reverse engineering - for the win?
    #267 priumium, Nov 29, 2025
  8. ChapmanF
    18,982
    A little holiday spirit, if you please. Lawyers have boat payments too, y'know.
  9. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    I love pleasing. But…. Holiday spirit should include sharing, right?
    Toyoda, deliver to us what is requested by... us non-revenue-creating-after-market-nerds.
    Pleeeeease! :LOL:
  10. pasadena_commut
    pasadena_commut Senior Member
    3,033
    942
    Southern California
    Twenty years ago if a tail light went out one would replace the $5 bulb.
    In many modern cars it is a single unit which cannot be serviced. The only option is to replace the entire unit for hundreds of dollars.
    Same principle applied all over the car.
    The trend line is clearly towards less and less serviceable cars, and the only thing that is likely to turn that ship around would be laws banning the practice. Are those likely? Not in the US. Even if one somehow passed the current Supreme Court would rule that these were an unconstitutional infringement on the corporations' free speech, or some such nonsense.[/QUOTE]
    #270 pasadena_commut, Nov 29, 2025
  11. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    Not everyone lives in the US fortunately and hence are not bound by this social structure of prioritizing corporate profits over citizens rights.
    But I think and hope them US courts will be smarter than governments and stay on the people’s side.
    The main bad concept here is indeed that corporations in the US have been given the same rights as humans.
    It will be a long battle…
    God bless the EU? Never heard about it.
    #271 priumium, Nov 29, 2025
  12. pasadena_commut
    3,033
    942
    Southern California
    Bought an AP200 recently and finally had a chance to try it today. Installed the software on a second hand Pixel 7a phone which does not currently have a phone number or data but can communicate through our home WiFi. The installation instructions in the package were not particularly helpful, and the pictures of what the app screen was supposed to look like in the manual (inside the App) didn't agree with what it finally looked like. In the end figured out that it wanted to be in communication with both the dongle and the WiFi to set it up. That is, first it wanted a VCI connection (over bluetooth I guess), then on going to "Diagnose" it needed to use the WiFi to download the EOBD and the Toyota specific package. Sadly the driveway is just outside the range of the WiFi, so I ended up standing next to a window on the lawn, midway between the car and the router, with a phone in my hand, like some deranged peeping Tom. Anyway, once those two extra software packages were installed it was able to connect to the car and run the full scan over all the ECUs, which only turned up the sun sensor error. Looking at live data it mostly made sense. For some reason the app was reporting the 12V battery as 13.9V while the voltmeter plugged into the dash was reading 14.1V. I don't recall Techstream doing that. I know the voltmeter reads the same as at the jump point or on the battery posts when the car is in Ready (which it was).
    Not a fan of the dongle LED. It faces down and towards the pedals, so to see what color it is I had to stick my hand down there and observe the light reflected off my fingers.
    The AP200 has a bunch of service options, including the brake procedure. However, while it would show the HV Pack fan speed I didn't see any way to change the speed. That's a useful test to verify that the fan isn't failing.
  13. ChapmanF
    18,982
    I think the car's J1962 connector just snaps in to a rectangular cutout in that dash trim piece, so you might be able to pop that out and snap it in the other way, and then the LED on the dongle would face up. (And the next time you went in to a dealer, the dealer tech would try a few times to plug in their tool the usual way and wonder why it wasn't going.)
  14. pasadena_commut
    3,033
    942
    Southern California
    Or I could just tape a piece of aluminum foil to extend below the LED and reflect the light in the desired direction.
  15. priumium
    priumium Member
    335
    81
    Sweden
    2013 Prius Plug-in
    I also have been very annoyed by the limited range (of BTLE in my case on three vlink icar pro dongles). So I now sometimes use the Remote Desktop/Windows app from my iPad over home wifi to a techstream18 installed on old Macs (bootcamp) with a miniVCI. Works lovely for many hundred meters (mesh) and I recommend.
    Oh the first world problems never stops. Me like.
    Remember to lock down the firewall to prevent techstream from reaching any internets if not genuin...
    #275 priumium, Dec 4, 2025
  16. Michael Loveroot
    Michael Loveroot Junior Member
    28
    Nashville, TN
    I see a lot of people recommending Autel Maxi scanner and app, but on iOS, all the apps are no longer being updated for 2+ years and they are all rated terribly (below 3 stars).
    Am I missing something?
  17. Tombukt2
    13,830
    2,510
    Yeah iOS is really supported in the car world the whole lot except for stereos. So most kids hacking n cracking all lost keys etc are doing it on android it's supports all that semi criminal activity. Apple do not . People in the iOS world generally can afford to pay the people in the Android world to do that kind of work that they need to get done and not involve themselves in it at all it seems like if eyes are open wen looking at this tooling.
  18. Leadfoot J. McCoalroller
    8,278
    7,784
    Pennsylvania
    2018 Prius c
    There are other apps that get more frequent updates, work with cheaper hardware interfaces and gather higher star ratings, but so far they can only communicate with a small subset of the systems in a typical Prius. They are great for certain problems, but completely useless for others.
    So far, the Autel setup is the only one that can talk to everything in a Prius and works with iOS.
    If you're missing something, it's the same thing the rest of us are missing: competition in high quality diagnostic apps that work with iOS.
  19. rjparker
    11,040
    6,920
    Pine Hollow's best value in bidirectional scanners (Launch and Autel based).
    These come closer to a full scanner like Techstream and have better graphical trending than the hacked Techstrean and the cheaper all ecu versions.
    Amazon Prime days discounts end today.
