2019 Prius Slow Coolant Leak
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JeffPGH, Jun 25, 2026 at 3:51 PM.
  1. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    A couple years ago my Prius was leaking coolant. I took it to the dealership and paid them for diagnostics and they said I needed a $1500 Catalytic Converter. My buddy said that was a known issue and he did the bypass for me. A couple months ago my coolant started leaking again. I found out about the TSB from September 2019 (T-SB-0135-19) on the NHTSA government website about the coolant leak issue and called Toyota Corporate and complained and managed to get them to replace the pipe under warranty even though it was over the mileage for the warranty. I thought that would fix the issue but later on that day the coolant reservoir was empty. I put some coolant in and took it in the next morning. The looked it over and said everything was fine and there was probably air in the line. However, after I left I had to put coolant in around every 4-5 days. I took it back and they did a pressure test and they said it passed. They tried swapping the caps between the two different coolant reservoirs. It was fine for about a week then I had to put coolant in again. I ordered a new coolant cap just to try it to see if it might help and they said it would be here tomorrow. I had them change the spark plugs when they had it the other day for the coolant pressure test and they sent me a photo of them. It did look like one of them was a lot whiter than the others but I mentioned it and they didn’t seem concerned. One suggestion I saw online was to get an inexpensive block tester kit (chemical fluid test) to check the coolant reservoir for the presence of exhaust gases. I haven’t tried that yet. I’m not getting any check engine codes or smoke coming out of the exhaust. They said since they replaced the entire heat exchanger pipe with the new part in the TSB that probably isn’t the issue. Since there aren’t any check engine codes I could probably just keep running it and checking the coolant to make sure it isn’t low but I’d rather find the problem and solve it if possible. I did notice when I use the funnel to pour in coolant it seems to leak out the top a little bit by the plastic piece that sticks out with the little black end on it. I think that’s the overflow but I’m not sure. I might not be using the correct funnel.
    Does anyone have any ideas on what else to check?
    #1 JeffPGH, Jun 25, 2026 at 3:51 PM
    52,720
    is that dried coolant all over everything?
  3. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    It spilled when I was trying to pour it in with the funnel. I need to try to rinse it off.
  4. Brian1954
    Brian1954 Senior Member
    2,617
    1,037
    South Central PA, USA
    It looks like dried coolant all over the plastic reservoir. To troubleshoot, you need to monitor the engine coolant temperature. Watching the coolant temperature will tell you if the coolant is getting hotter than it should be.
    My theory is the engine water pump is going bad. The pump is not pumping enough coolant through the engine to keep it cool. The coolant heats up too much and creates enough pressure in the system that some coolant is released past the reservoir cap and out that little overflow nipple. This is common behavior for the Gen 3 Prius when the pump is going bad. I have not seen many reports for the Gen 4. Try putting a rag around the reservoir overflow to see if that is where the coolant is being released from.
    bisco and BiomedO1 like this.
  5. BiomedO1
    4,459
    2,349
    Left Coast
    ^ Yep; coolant splash in that area would indicate that it's boiling out. Kinda obvious to any experienced mechanic. Assuming the dealership did the pressure test correctly, (that's a BIG if) - since he should've noticed that "right off" - it's probably the electric ENGINE water pump not spinning fast enough to keep the coolant from boiling out - but fast enough not to trip the temp lamp at 248+F. Swapping coolant reservoir caps? They should've been inspected and a missing sealing ring would cause leaks and not allow the system to properly pressurize.
    You can still have a head gasket issue; if that leak test was performed with the engine warm or hot. The aluminum would expand and seal the leak - that's why we say to pay attention to early cold morning startup misfires that disappears after a few minutes.
    Good Luck.....
  6. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    Thank you for all the suggestions. As I mentioned the dried coolant was from when it spilled when I was pouring it in… I need to wipe it off and see if more coolant dries on it. I left the car there overnight so I think they did the pressure test after it sat all night.
    I found an option to monitor the coolant temperature using my Blue Driver OBD II port adapter. What temperature ranges should I be looking for to determine if it is an issue with the water pump? I”m sitting here at the airport and it is currently at 178 degrees Fahrenheit.
    #6 JeffPGH, Jun 26, 2026 at 11:41 AM
  7. bisco
    52,720
    it is interesting how polished the third spark plug is. maybe a borescope of the piston top to see if it's scrubbed
  8. BiomedO1
    4,459
    2,349
    Left Coast
    around 180F-195F nominal. you may touch upon 200F while crossing over steep mountain ranges.
  9. Brian1954
    2,617
    1,037
    Cruising on the highway should be about 195F. Going up hills on highway usually will not go above 202F. Just drive the car and keep an eye on the temperature.
    How many miles on the car, and how long have you owned it?
  10. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    Today I got a smaller funnel so the coolant wouldn’t spill when I put it in, I cleaned off the old coolant from the outside of the reservoir, and put the new coolant cap on. I’ll easily be able to tell if coolant is escaping from there now. The dried coolant in the pics was from the coolant I spilled when pouring it in because I had the wrong funnel.
    So far I don’t think the temp has gone above 200 so I doubt it is overheating but I’ve only checked it randomly throughout the day.
    I have 344,537 miles on it. It is a 2019 and I bought it new in December 2019. It has been the lowest maintenance car I have ever had. It’s just bugging me that the coolant is still leaking even after they replaced the whole heat exchanger/cat pipe. The dealership basically gave up on figuring it out at this point I think.
    I don’t even have the spark plugs because the dealership changed them and I don’t know much about doing a borescope of the piston top. I asked them to send me the pic of the spark plugs because I didn’t think they had been changed in a really long time, if at all, and I wanted to see what they looked like to see if one of them was really clean or anything like that. Judging by the picture they sent me I was wondering if the coolant leaking in and cleaning the one spark plug.
    I’m not a mechanic and don’t really have much experience working on cars. But overall the car is still running really well and if I can figure out why the coolant seems to be running low that would be fantastic. I might see if I can do the gas test myself. I saw a video of a test someone did on YouTube where they took out the spark plugs and put sheets of paper over the engine and tried to start it to see if coolant would come out and hit the paper to see if there was a leak and it did.
    At least there are no check engine lights and my Blue Driver OBD II reader said there are no misfires recorded in the computer.
    bisco and Brian1954 like this.
  11. BiomedO1
    4,459
    2,349
    Left Coast
    At 344K miles; I would suspect and intermittent electronic coolant pump that hangs-up every once in a while.
    If you truly don't see any leaks anywhere; yet your coolant keeps going down - start tracking it. How much are you losing every refuel or x-amount of miles; so you can top-off before blowing something up. Use your Trip-A and Trip-B to keep track. I would take the car to another shop for another coolant pressure test, because the dealership obvious didn't do the test correctly. You can have a leak in your cabin heater core, coolant would dump out with the water accumulated by your AC core. There should be a slight sweet coolant smell when operating your HVAC system with the window all the way up and recirculating the cabin air. The dealership could've installed a defective EGHE that already had a leak. You can bypass the new unit; if the leak stops; you've got your answer.
    Good Luck......
  12. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    Thanks for the info. I started tracking the miles this morning when I topped it off. I’m going to keep checking it every morning after it cools down overnight and record everything in my notes.
    I haven’t noticed a sweet smell but I also had a small febreeze air fresher clipped to the air vent so I just took it off the vent.
    I might take it to another shop to get checked out. Doing the bypass again is a good idea to see if it is the new part. It looks like if it is the cabin heater core that’s a pretty labor intensive expensive fix. Hopefully that’s not it.
  13. Brian1954
    2,617
    1,037
    A pressure test of the system is a very easy thing to do and hard to do incorrectly. A pressure test can be okay, but a pump that hangs up every once in a while will cause the coolant to overheat and be forced out the overflow nipple on the reservoir.
    #13 Brian1954, Jun 27, 2026 at 1:25 PM
    BiomedO1 likes this.
  14. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    I’m due for a coolant flush in a few weeks. I think I’ll have them check the engine water pump then. If it’s only hanging up occasionally I don’t know if they’ll be able to tell that just by looking at it.
  15. BiomedO1
    4,459
    2,349
    Left Coast
    This wouldn't be the first time I've seen a shop claimed to have performed a test and charged for it - but didn't do it.
    My old Acura had an intermittent diode in the alternator, so the battery icon on my dash lit up like every 15 minutes then go off when it cooled down. Took it to the dealership, because I was still barely under warranty. They claimed I just had a bad battery and that they tested my alternator and it was fine. I said fine; I'll pay for a new battery; (I was outside the battery warranty), but your going to reverse the charges - if your diagnosed is wrong. I got maybe 3 block before the battery lamp relit - spun around and dragged the service writer and service manager out to my car. They both claimed that the technician did an output test on my alternator and I said lets got talk to him. My first question was, I want to see the test equipment you used to check the output on my alternator, what was the amp output, and at what RPM. The technician stammered and stated he doesn't have it with him right now. I stated that I see 6 technicians in this repair bay, who has this supposed diagnostic box and does the dealership provide that equipment or are you suppose have your own test equipment. Then I asked the crowd; would you like to use the amp meter I have in my trunk? I believe it was factory calibrated last month; because the equipment I work on; requires traceable annual calibrations to cover us legally.
    They replaced my alternator and reversed the charges for the battery replacement. At first, they wanted to put my old battery back in - but I said you treated my old battery like a defective unit - It's probably damaged now that you dropped, kicked, and threw other cores on top of it. I told them to chalk this up to a cheap educational experience, since I'm not going to call BBB, BAR, or Acura corporate on this incident.
    YMMV .
  16. rjparker
    10,908
    6,848
    1. Exhaust heat exchanger again. A bypass hose is less than $10.
    2. Head gasket caused by previous overheating. Borescope test. Requires quality borescope on cold engine with manually pressurized coolant system.
    Don't assume any mechanic has the tool or knowledge.
    Car Care Nut HG Borescope at 660s
    South Main Auto
    Excellent Borescope Footage at 6:50
    One thing is for sure - losing coolant needs urgent priority attention AND resolution or you will end up with a hg leak on any engine.
    Less likely - heater core leak, usually would have wet carpets. Pressure relief - pretty obvious as well.
    Finally, traditional hg tests such as combustion gas in coolant or coolant pressure tests are conclusive if they are positive for a hg leak but not conclusive if they are negative.
    #16 rjparker, Jun 28, 2026 at 10:16 AM
  17. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    Thank you for all the great information. I think I might try the bypass for a few weeks and see if it is leaking. If it isn’t then I should be able to get the dealership to replace the heat excavator for free since they just recently replaced it.
    Are you familiar with the paper test? I was thinking that might be easy to do to confirm if coolant was leaking in and cleaning the one spark plug. Here is a link to the video.
  18. rjparker
    10,908
    6,848
    That is another conclusive if positive but not conclusive if negative. It requires a big leak.
    Ideally a hg leak is easier to repair if its small.
  19. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    image.jpg FYI Yesterday I filled it to full after it sat all night, I drove 226 miles yesterday, let it sit all night last night, and this morning it is below the low line again. I’m going to top it off again. I don’t see any signs of it leaking out of the reservoir. I thought about turning off the A/C before getting home and then putting cardboard under the car to see if it would catch any coolant leaks but it was raining last night. I think the best thing would be to try the bypass to confirm if it is leaking or not after that. I probably won’t be able to do that until sometime this week. I used repairpal to find a couple local repair shops. What are some good questions to ask to try to confirm they have the right tools before taking it there? I don’t think the engine ever did overheat so that is good. I have been very good about checking the coolant.
  20. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    I just took a video of the Prius starting up after sitting all night. It was really quiet at first then after a few seconds I hit the gas and it did shake for a couple seconds then smoothed out.
