Why doesn't the app indicate 12V battery level?
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, Jun 15, 2026.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    Perhaps you shouldn't have declared that you are "99% sure,"
    because the facts prove you wrong on every point (100% wrong).
  2. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    I will try one last time.
    Your secondary 12v battery was not isolated from the car's 12v battery because you had the cut-out voltage set higher the than the cut-in voltage. The battery-isolator did not work properly to protect the car's 12v battery.
    The car's 12v battery was drained down so many times that the battery was ruined and will no longer hold a charge. No amount of charging is going to restore the energy capacity in that battery. Why can't you understand that.
    If you don't believe me, you can do an experiment to prove that the battery is not good. Remove the secondary battery. Install the Bluetooth battery monitor on the car's 12v battery. Disconnect the negative cable from the battery. Fully charge the battery, then remove the charger. Let the surface charge of the battery come down for four hours. Note the battery voltage at that point. Then, monitor the battery voltage over the next three days. The battery voltage for a good battery should not drop more than 0.2 volts. I think that you will find that your battery drops much more than 0.2 volts. Are you willing to try this?
    #42 Brian1954, Jun 23, 2026
  3. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    Well, my car is still draining the battery every single day. I can't wait for my other car to get repaired, so I can park my Prius with the battery maintainer plugged in. Unfortunately, it's nothing 3 dealers can fix, or even Brian1954 has the answer for.
  4. ChapmanF
    18,993
    Do you have results to share from following the procedure suggested in #42?
  5. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    Why should I follow advice that bears no connection to reality?
    Just because someone portends to have all the answers, it doesn't mean they actually have a clue.
  6. ChapmanF
    18,993
    Following advice whose connection to reality isn't apparent to you occasionally results in learning something.
    fuzzy1 and Brian1954 like this.
  7. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    I have a much stronger connection to reality, as someone who's lived it,
    compared to someone who lives the fantasy of having all the answers.
    Mostly derived from selectively ignoring the ones that contradict reality..
  8. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    I find it very revealing that some people always need to be heard, even when their "answers" are total nonsense.
    The best advice: when you don't know what you're talking about, keep your mouth shut.
  9. ChapmanF
    18,993
    All the same, back when you were convinced your Prius had an AGM battery, and people suggested you just go look, you seemed sure there was no reason to do that, all the way from post #66 on page 4 of a thread through post #150 on page 8 of the same thread, until finally (#153) you did look, and you learned something. It would have been possible to learn that sooner by ignoring people less.
    Likewise, back when you thought the battery state sensor assembly was part of the battery itself, you went four pages of that thread, from post #42 through post #107, selectively ignoring what you had the opportunity to learn.
    Those are just a couple examples of past times your selective ignoring greatly prolonged the time needed for you to learn something. It seems to be more of a pattern than a one-off.
    Gokhan, KMO, fuzzy1 and 2 others like this.
  10. Brian1954
    2,668
    1,066
    I definitely do not have all the answers. I did have the correct answer when you asked the question "Why would they use a 4A fuse on a 5A charger?" pertaining to why the 4 amp fuse blew when using your NOCO Genius 5 amp charger.
    I tried one last time to help you with the 12v battery problem. I guess that you prefer to live in your own reality.
    #50 Brian1954, Jun 28, 2026
    LRO likes this.
  11. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    You can't win this little tussle by continuing to misrepresent the facts the way you have.
  12. Brian1954
    2,668
    1,066
    What do you think I was trying to win? I was only trying to help you like a lot of other people have tried to do over the past two years.
    All I can say is, you can lead a horse to water, but you can't make it drink.
    #52 Brian1954, Jun 28, 2026
  13. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    Except that there's no water to drink. I've explained the facts in exhausting detail, yet they continue to be ignored.
    I can only assume it's for reasons of online combat. Nothing else makes any sense.
  14. Brian1954
    2,668
    1,066
    I guess the horse will die of thrist.
    #54 Brian1954, Jun 28, 2026
  15. rjparker
    11,046
    6,922
    I suspect he drinks plenty.
  16. PriusV17
    PriusV17 Active Member
    440
    207
    CA
    2017 Prius v wagon
    I think you answered your own question. Since you moved to your new residence, your car seems to have difficulty connecting to the network to relay info and that is causing the 12v battery to drain.
    If you want to check the 12v status you can buy these car adapters with USB 12v meter.
    AI response to disable Toyota connect feature:
    I'm using Jack's Sodium Ion 12v battery and his app can show exactly how much amp is being drained even when the car is off. This is after the car has been sitting for one week without use on this 12v pack.
  17. Paul Gregory
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    I have been using such a socket voltmeter since day one.
    I can only assume that disconnecting parts of the system causes the same slew of problems I experienced when the battery had gone completely dead. It took me a week to get things back to normal. I am hesitant to risk the same thing again.
    I will be quite happy to park my car where I can use the battery maintainer, once my other car is out of the shop.
  18. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    What you can also do is ask your dealer if there is a Toyota Technical Service Bulletin for your model regarding the 12v battery drain. If it's not a recall they won't do any work for you. So you would have to ask them to verify if a Service Bulletin exists and if a software update can be done.
    This video is saying dealers are part of the scam by deliberately withholding that information.
  19. Gokhan
    Gokhan Senior Member
    6,709
    2,660
    Paramount CA
    The OP has an adjustable battery isolator, an auxiliary 12-V LFP battery, and a drink cooler connected to it. I told him several times that the way he set it up and adjusted the limit voltages would constantly drain the main 12-V battery and result in the need for a jump-start every day, but he lashed out at me every time. So, this is not extraordinary but entirely expected.
    Brian1954 likes this.
