Weather Stripping wear. Known issue?
Discussion in 'Gen 5 Prius Main Forum' started by schja01, Jun 18, 2026.
  1. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    1500 miles and got a note on my rear door recall worksheet that driver side weatherstripping was torn. I hadn’t noticed it but it is indeed worn. See photo. Anyone else have this happen. I’m ultra careful getting and out of the car. Would this be a warrantee covered item? Any suggestions appreciated. J
  2. Paul Gregory
    Paul Gregory Senior Member
    2,338
    612
    Alberta
    2024 Prius Prime
    XSE
    I noticed mine wearing excessively in the first month I owned the car. It consists of a low quality rubber, which is quite susceptible to wear.
  3. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Have you done anything to mitigate further wear? I put a piece of clear shipping tape over the “wound” but that seems amateurish.
  4. mingc
    mingc Member
    104
    74
    Portland, OR
    2023 Prius
    XLE AWD-e
    I had the same tear, same place. From the interwebs, I gather this is pretty common. I don't know what I was thinking, waited too long, and could not get it warranted.
  5. Jerry G
    Jerry G Junior Member
    Brooklyn,ny
    I had same issue. Dealership refused this as a warranty issue. I haven’t done anything to try to fix it yet. The dealership said they could put new one on for a charge.
  6. Hammersmith
    Hammersmith Senior Member
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    If anyone decides to replace theirs, please do it yourself and don't pay a dealership to do it for you. I can't think of many things easier to do on a car. Significantly easier than an oil change. <5min.
    I'd be tempted to order from Japan on this. $33 per seal before S&H from Impex Japan. $70-$80 per seal all-in from US dealerships during good sales.
    FR - 62311-47060
    FL - 62312-47060
    RR - 62331-47060
    RL - 62332-47060
    Trollbait, mva, mingc and 2 others like this.
  7. VelvetFoot
    VelvetFoot Senior Member
    1,407
    545
    New York State
    2026 Prius
    Don't see it on my '26 with 13,000 miles...yet.
  8. dicknose
    dicknose New Member
    Toronto
    2024 Prius Prime
    XSE Premium
    I've got some minor wear on my driver side. Consider turning off the setting that slides the seat back when you turn off the car, this may help with rubbing against it.
  9. Blackat
    Blackat Active Member
    486
    355
    Colorado
    2023 Prius
    Limited AWD-e
    I put some black cloth tape over it
  10. VelvetFoot
    1,407
    545
    New York State
    2026 Prius
  11. GcinFl
    GcinFl Junior Member
    47
    2024 Prius
    VelvetFoot likes this.
  12. Hammersmith
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I took a look at mine and have an idea as to why it's happening. Mine(3y/36k) is also failing, though the tear isn't as long yet as the OP's pic. I think it's happening because of how the door seal interacts with the plastic door card.
    The door card is made up of textured plastic. The failure point in the seal seems to start where the seal comes in contact with the vertical right angle in the door card. I think the rubber seal gets flattened as the door closes, and the edge of the squashed seal just barely brushes the vertical portion of the textured plastic. Over time and hundreds of openings and closings, I think the plastic acts as a sandpaper and abrades the edge of the seal until it wears a slit into it.
    Assuming Toyota doesn't step in, I see four solutions:
    1. Ignore it. It doesn't compromise the car in any way, so you could just ignore it if you wanted to.
    2. Replace the seal every 2-5 years depending on wear rate. (I fully understand why this isn't really appealing to anyone.)
    3. Make sure to keep both the seal and door card clean and protected with some sort of coating that leaves a slickness that reduces friction. This should slow the rate of deterioration. I'm probably going to order a new seal eventually and then do this one from then on.
    4. Sand away the texture from this portion of the door card. Start with something like 60 grit, then go through the grits up to 200-400. Once the plastic is nice and smooth, coat it with a protectant that makes it as slick as possible. This will probably solve the problem the best, but it's also destructive and non-reversable. I don't think I'm going to do it, but maybe someone else would.
    Trollbait and schja01 like this.
  13. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    What is a door card? Tnx.
    ed: I see what you are talking about.
    ed2: My car has south of 1500 miles on it and is 18 mos old. I've probably gotten in/out of it 200 times. The service tech says they think it's due to the cramped cabin people are rubbing against it while entering/exiting. I've been watching closely and that's not what's happening in my situation. FWIW ChatGPT says there is a decent chance Toyota whould warranty the repair if I pursued it with Toyota Customer Experience.
    #13 schja01, Jun 29, 2026
  14. Hammersmith
    2,462
    2,522
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I strongly suggest that anyone seeing the same issue go to a dealership and have it documented. That's what I just did. I'm just outside my 3y/36k, so I didn't go in expecting or even asking for it to be covered, but we can't expect Toyota to do something about it if they don't know it's happening.
    The more people that show up with torn seals in exactly the same place, the more likely they are to update the part and maybe even do a recall on it.
    Ask them politely to take a photo or three of the tear and send the info up the chain to Toyota.
    <insert Starship Troopers gif>
    "I've done my part."
    :D
    SM-S901U ?
    mingc likes this.
  15. Scott_R
    Scott_R Member
    449
    25
    Long Island
    2024 Prius Prime
    Mine wore through as well; had it replaced at the first scheduled service (dealer did it under warranty).
    schja01 likes this.
  16. Gen5604
    Gen5604 Junior Member
    Washington
    2024 Prius Prime
    XSE
    My 2024 Prime had the same problem 3 months after I purchased it in Feb 2024, and the dealer replaced it at no charge.
    The replacement seal felt thicker by enough that I could tell by just touching it.
    No problem as of today, 2 years later.
