Oil leak: cleaning and diagnosis help needed
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Arkay, May 26, 2026.
  1. Arkay
    Arkay Junior Member
    39
    Mountain View
    2014 Prius Plug-in
    2014 Plugin Prius:
    While changing the oil today, I noticed that the area was covered in oil. There were no oil drips on the floor so it is not "yet" a major problem.
    The oil leak was from above the pan and filter area, BUT below the belt.
    I think it is the oil pressure switch, but I have an almost 100% track record of my first guess being wrong :) .
    Here are a few questions:
    1. How can I clean that area? What is the easiest way to clean it?
    I was thinking of spraying a simple degreaser in that area and then washing it off. Anything particularly wrong with that approach? Apart from the engine needing to be cold!!!
    2. How do I diagnose the problem? I was thinking of using an engine UV dye + black light. Do I also need a borescope?
    3. Assuming it is the oil pressure switch, how do I get to it? The manual says I can get to it by removing the front right wheel.
    4. Could it be timing chain cover seepage?
    Thank you!!!
  2. ASRDogman
    ASRDogman Senior Member
    7,998
    4,061
    "...but I have an almost 100% track record of my first guess being wrong"
    Even a broken clock is correct twice a day!
    There are no oil drips because there is a pan under the engine.
    Gunk the engine, then hose it off. Drive the car making sure the engine runs for 10 minutes or so
    to dry it off. Then check from the top down.
    Valve cover gasket, oil pressure switch, timing chain cover or common areas for oil leaks.
    What belt are you talking about?
    It is possible the oil filter housing wasn't tightened enough, or the "O" ring was installed in the wrong
    slot on the filter housing, and air is blowing the oil everywhere.
    Cleaning the area completely, then checking often is the only way to find the leak.
    Danno5060, Arkay and Brian1954 like this.
  3. Mendel Leisk
    42,210
    I’d spray brake cleaner, wipe with a rag.
    Arkay likes this.
  4. Arkay
    Arkay Junior Member
    39
    Mountain View
    2014 Prius Plug-in
    > It is possible the oil filter housing wasn't tightened enough, or the "O" ring was installed in the wrong... :)
    Noooo, I am obviously perfect and never made any mistakes... Frankly speaking, that seems much more likely than Toyota making a defective part.
    I'll start with gunk. For any specific areas that didn't get cleaned, I can use brake cleaner while working on them.
    ASRDogman likes this.
  5. Arkay
    Arkay Junior Member
    39
    Mountain View
    2014 Prius Plug-in
    Any advice on timimg chain tensioner oil leak?
    After cleaning the car engine area as well as could, I found oil around the timing chain tensioner. There was no oil around the oil pressure switch. I cleaned the tensioner area again with Simple Green, just to make sure that it is not left-over oil from before. I know I cleaned it earlier and passed my hand around that area as there was no oil earlier.
    I'll be more sure after this round of cleaning. I did run my hand over the upper part of the engine in that area to make sure oil didn't drip down from above; nothing coming from above.
    I am definitely batting at 100% on swinging and missing with my first guess: I had guessed it was the oil pressure switch and I even have it in my Amazon checkout, ready to go :)
    I am probably going to work on it this weekend. Any advice will help.
  6. ASRDogman
    7,998
    4,061
    So it is NOT the tensioner leaking?
    Perhaps the valve cover? If everything is clean, you'll soon find it.
    It may be a slow leak and take a while to seep out.
  7. Arkay
    Arkay Junior Member
    39
    Mountain View
    2014 Prius Plug-in
    I have oil around the tensioner with the two bolts and the two 10 mm nuts.
    I am now going through the process of verifying my findings a third time.
    For the life of me I can’t seem to be able to put the 2014 plugin into maintenance mode.
    Yeah, I know I should have posted this in the plugin forum but I made a mistake.
  8. ASRDogman
    7,998
    4,061
    Why would you want to run it on maintenance mode?
    Just drive it around the block and make sure the engine runs to operating temp.
    Then check it.
  9. Arkay
    Arkay Junior Member
    39
    Mountain View
    2014 Prius Plug-in
    My apologies for writing disjointed trains of thoughts.
    Maintenance mode: I’m checking out how to do this before I start working on the repair. The maintenance mode is required once I’ve reinstalled the part and before i rotate the crankshaft.
  10. bisco
    52,730
    you're better off here. same engine, and no one reads the plug in forum anymore
    Arkay likes this.
  11. Arkay
    Arkay Junior Member
    39
    Mountain View
    2014 Prius Plug-in
    I see no oil leaks around the timing chain tensioner, the oil filter, or the oil pressure switch. Since the oil leak is low, I am thinking I should not be in a hurry. However, I should keep on trying to find the root cause.
    @ASRDogman, you mentioned: Valve cover gasket, oil pressure switch, timing chain cover or common areas for oil leaks.
    Any simple instructions or trying to find where the oil leak is coming from? I don't know enough about the engine layout. Thank you.
  12. ASRDogman
    7,998
    4,061
    I gunk everything, front, back, sides, top and bottom. Then I hose it off.
    You should remove the bottom cover so you can see where oil drip to the ground, if that much
    oil leaks.
    Then I drive the car for 5-10 miles to get it hot and give it a chance to start to leak. Then I search.
    Using a mirror to see the hidden areas. Anyplace surfaces mate. And switches. Is there a rubber
    cover over the oil pressure switch? If so, you need to remove it. If it's dry, it's not leaking.
    Where is it wet? What area?
  13. rjparker
    10,917
    6,852
    Timing chain cover is common in that area. Its a big job to reseal the cover, almost everything it takes to do a head gasket. Might wait for that hg day and kill two birds with one stone.
    Unless you're a pro mechanic, replaced the head gasket but end up with a timing cover leak. He used uv dye to diagnose and then jumped in and tore it down again. While videoing it for the peanut gallery.
    May 2026 Nutzaboutbolts timing chain cover
    Arkay likes this.
  14. Arkay
    Arkay Junior Member
    39
    Mountain View
    2014 Prius Plug-in
    So, I took out the bottom cover and cleaned everything. As usual, the actual effort took less than 5 minutes. Most of my AM was spent on trying to find my 10mm socket :)
    It turns out that the leak is from the crankshaft position sensor. That means I hold a 100% track record of misdiagnosing a car issue at first glance.
    I had also put in a UV dye. (will add the photograph when I crawl back under). The leak is definitely coming from the crankshaft position sensor.
    Have aordered the part https://www.amazon.com/DEVMO-90919-A5004-90919-05070-90919-05081-Crankshaft/dp/B09NP3BFS1
    T
    hank you all for the help.
  15. ASRDogman
    7,998
    4,061
    No, you're not. There were several things it could have been.
    But at least you were smart enough to search for the leak correctly.
    And you have found where the leak is. THAT is a correct diagnoses! (y)
    But, you failed on getting a cheap chinese copy part. IT IS NOT WORTH THE MONEY!!!!
    Or the pain of having to replace it with the original part, and JUST replace the "O" ring!!!!
    So JUST get the "O" ring and use the OEM part. You can go to a parts store and get that "O" Ring.
  16. Arkay
    Arkay Junior Member
    39
    Mountain View
    2014 Prius Plug-in
    Thank you. I think the problem is fixed. Here is what I did:
    1. Looked for the o-ring for the Crankshaft Position Sensor from Toyota. Turns out all the references for the o-ring for this part were Google hallucinations, giving me a different part.
    The Toyota parts guy in Palo Alto sat down with me, compared the o-rings, and we realized that Google lied to me.
    2. Auto parts store O-Ring: Went to Kragen (O'Reilly's) and they had a similar O-ring, a bit thicker, though. Used that.
    Result: I saw a smidgen of oil after driving 12 miles. Could have been due to residual oil somewhere
    I was taking no chances.
    3. Installed a new Toyota (Denso) part. Test drove it; no leak. Reinstalled the bottom plastic cover. 1 bolt is missing, and I have an extra push tab left over :)
    4. Drove around 100 miles over the weekend. There doesn't seem to be a leak, but I did see almost a trace of oil. I cleaned it up all over again. Will check weekly.
    It has been a fun project. The most important thing I learned was that starting with a super clean engine area is crucial.
    About the missing bolt: I believe it is an M6 bolt, 20mm long, with a 10mm hex head and washers. Not in a hurry; will pick it up from Toyota when I am near there on a weekend.
  17. ASRDogman
    7,998
    4,061
    Told ya about those cheap chinese parts! (y):whistle:
    Don't ever waste your time with google.
    There are just some things that are best gotten at the dealership......
    Glad you have gotten it fixed!
