Crazy auto braking
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Jul 2, 2026 at 10:31 AM.
  1. Gokhan
    Gokhan Senior Member
    6,686
    2,651
    Paramount CA
    How does the car detect the door when the sensors are disabled?
  2. Templeton
    Templeton Active Member
    358
    127
    usa
    2024 Prius Prime
    SE
    I can clarify this by (1) the parking brake indication coming up on the dash, (2) the car stops dead even though it is in D or R, (3) I hear the parking brake motor running when the brake kicks in, and (4) the car will not move again unless I manually press the parking brake switch to release the parking brake.
  3. Templeton
    358
    127
    usa
    2024 Prius Prime
    SE
    I have no idea.
    I don't know which sensors are disabled, but the car computer knows the door is open (indication is visible on dash) and manually disabling PKSB does nothing regarding this issue: i.e., the parking brake still kicks in when moving the car a couple of feet with a door ajar, even when PKSB is off.
    #23 Templeton, Jul 2, 2026 at 4:33 PM
  4. Gokhan
    6,686
    2,651
    Paramount CA
    The backup camera is not fed into the computer.
    Is this what you did?
    Enabling/Disabling the
    Parking Support Brake
    The Parking Support Brake
    function can be enabled/disabled
    through a customize setting.
    (P.540)
    When the PKSB (Parking Support
    Brake) is disabled, the driving
    assist information indicator
    (P.84) illuminates, and a message
    is displayed on the multiinformation
    display.
    If the PKSB (Parking Support
    Brake) is switched to OFF (disabled),
    the system will not be reenabled
    until ON (enabled) is
    selected again from the customize
    setting (P.540).
    (It remains off even if the power
    switch is turned to ON again
    after the power switch has been
    turned off.)
  5. Templeton
    358
    127
    usa
    2024 Prius Prime
    SE
    Thanks, but not sure what the rear camera has to do with this, as this is not about obstacles front or rear. It is about trying to move the car forward or backward a few feet without the driver's door 100% full closed.
    To answer your question, yes, I disabled PKSB.
    Then I immediately (and also after shutting of the car and restarting it) tried to move the car forward a foot or two. The car moved a few inches and then the parking brake kicked in to stop the car dead.
    This is the automatic action that I am trying to disable. But I have no idea which system controls it.
  6. PriusCamper
    PriusCamper Senior Member
    13,372
    5,404
    Pacific Northwest, USA
    You can apologize all you want, but the loved ones of those squirrels are never going to forgive you, nor will I...
    PrimeDan likes this.
  7. LRO
    LRO Junior Member
    74
    87
    United States
    2024 Prius Prime
    XSE Premium
    Rollaway Protection
    Section 5-2 Of Owner's Manual - "Driving Procedures" speaks to the conditions of why the parking brake is engaging:
    Parking Brake Automatic Lock Function
    The parking brake will be set automatically under the following conditions:
    1. The brake pedal is not depressed
    2. The driver's door is open
    3. The driver's seat belt is not fastened
    4. The shift position is in a position other than P or N
    5. The malfunction indicator lamp and brake system warning light are not illuminated
    Here's the likely reason this feature is baked in:
    "When Consumer Reports began subtracting points from the Overall Score of vehicles that lacked rollaway protection, it pushed the industry to do better. Now, all new vehicles with electronic shifters come with it—a big win for consumers. Some of these vehicles shift automatically into Park if the door is opened, and others apply the electronic parking brake. Either way, these systems prevent rollaway." ....
    Even so, our testing showed that several older models lacked this important safety feature. For example, the 2020 Toyota Prius .... models lacked rollaway protection, but the automakers added it the following year after CR reduced their Overall Scores."
    Gokhan, Brian1954 and Templeton like this.
  8. Templeton
    358
    127
    usa
    2024 Prius Prime
    SE
    Good info, thanks. But any idea if this feature can be turned off?
  9. LRO
    LRO Junior Member
    74
    87
    United States
    2024 Prius Prime
    XSE Premium
    I don't think it's an option that can be turned off. Can it be defeated might be what you're looking to do. Given that it's not TSS sensor related logic it's not anything to be found in the software menus. Perhaps if I had a need to have my door open to visually inch forward or back to a very specific spot and do that repeatedly a number of times to apply tire shine, I might fasten the seat-belt behind me and get on with it.
  10. Hammersmith
    Hammersmith Senior Member
    2,435
    2,498
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just buckle your seat belt. Or if that interferes with whatever you're trying to do, buckle it before you sit down and then sit on it. You can move freely in forward and reverse with the door open as long as the seat belt is buckled(I just tested it).
    PrimeDan and LRO like this.
  11. Gokhan
    6,686
    2,651
    Paramount CA
    Or trade in for a Gen 3 Prius if you dislike technology that much.
    Last night, somehow my BSM in my 2021 Limited PHEV was turned off on the freeway. I panicked and had to go through the settings menu while driving to turn it back on.
