Crazy auto braking
Discussion in 'Gen 5 Prius Main Forum' started by Templeton, Jul 2, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,708
    2,659
    Paramount CA
    How does the car detect the door when the sensors are disabled?
  2. Templeton
    Templeton Active Member
    371
    131
    usa
    2024 Prius Prime
    SE
    I can clarify this by (1) the parking brake indication coming up on the dash, (2) the car stops dead even though it is in D or R, (3) I hear the parking brake motor running when the brake kicks in, and (4) the car will not move again unless I manually press the parking brake switch to release the parking brake.
  3. Templeton
    371
    131
    usa
    2024 Prius Prime
    SE
    I have no idea.
    I don't know which sensors are disabled, but the car computer knows the door is open (indication is visible on dash) and manually disabling PKSB does nothing regarding this issue: i.e., the parking brake still kicks in when moving the car a couple of feet with a door ajar, even when PKSB is off.
    #23 Templeton, Jul 2, 2026
    2023p likes this.
  4. Gokhan
    6,708
    2,659
    Paramount CA
    The backup camera is not fed into the computer.
    Is this what you did?
    Enabling/Disabling the
    Parking Support Brake
    The Parking Support Brake
    function can be enabled/disabled
    through a customize setting.
    (ï‚®P.540)
    When the PKSB (Parking Support
    Brake) is disabled, the driving
    assist information indicator
    (ï‚®P.84) illuminates, and a message
    is displayed on the multiinformation
    display.
    If the PKSB (Parking Support
    Brake) is switched to OFF (disabled),
    the system will not be reenabled
    until ON (enabled) is
    selected again from the customize
    setting (ï‚®P.540).
    (It remains off even if the power
    switch is turned to ON again
    after the power switch has been
    turned off.)
    2023p likes this.
  5. Templeton
    371
    131
    usa
    2024 Prius Prime
    SE
    Thanks, but not sure what the rear camera has to do with this, as this is not about obstacles front or rear. It is about trying to move the car forward or backward a few feet without the driver's door 100% full closed.
    To answer your question, yes, I disabled PKSB.
    Then I immediately (and also after shutting of the car and restarting it) tried to move the car forward a foot or two. The car moved a few inches and then the parking brake kicked in to stop the car dead.
    This is the automatic action that I am trying to disable. But I have no idea which system controls it.
  6. PriusCamper
    PriusCamper Senior Member
    13,420
    5,418
    Pacific Northwest, USA
    You can apologize all you want, but the loved ones of those squirrels are never going to forgive you, nor will I...
    PrimeDan likes this.
  7. LRO
    LRO Member
    88
    92
    United States
    2024 Prius Prime
    XSE Premium
    Rollaway Protection
    Section 5-2 Of Owner's Manual - "Driving Procedures" speaks to the conditions of why the parking brake is engaging:
    Parking Brake Automatic Lock Function
    The parking brake will be set automatically under the following conditions:
    1. The brake pedal is not depressed
    2. The driver's door is open
    3. The driver's seat belt is not fastened
    4. The shift position is in a position other than P or N
    5. The malfunction indicator lamp and brake system warning light are not illuminated
    Here's the likely reason this feature is baked in:
    "When Consumer Reports began subtracting points from the Overall Score of vehicles that lacked rollaway protection, it pushed the industry to do better. Now, all new vehicles with electronic shifters come with it—a big win for consumers. Some of these vehicles shift automatically into Park if the door is opened, and others apply the electronic parking brake. Either way, these systems prevent rollaway." ....
    Even so, our testing showed that several older models lacked this important safety feature. For example, the 2020 Toyota Prius .... models lacked rollaway protection, but the automakers added it the following year after CR reduced their Overall Scores."
    Trollbait, RandyPete, Gokhan and 2 others like this.
  8. Templeton
    371
    131
    usa
    2024 Prius Prime
    SE
    Good info, thanks. But any idea if this feature can be turned off?
  9. LRO
    LRO Member
    88
    92
    United States
    2024 Prius Prime
    XSE Premium
    I don't think it's an option that can be turned off. Can it be defeated might be what you're looking to do. Given that it's not TSS sensor related logic it's not anything to be found in the software menus. Perhaps if I had a need to have my door open to visually inch forward or back to a very specific spot and do that repeatedly a number of times to apply tire shine, I might fasten the seat-belt behind me and get on with it.
  10. Hammersmith
    Hammersmith Senior Member
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Just buckle your seat belt. Or if that interferes with whatever you're trying to do, buckle it before you sit down and then sit on it. You can move freely in forward and reverse with the door open as long as the seat belt is buckled(I just tested it).
  11. Gokhan
    6,708
    2,659
    Paramount CA
    Or trade in for a Gen 3 Prius if you dislike technology that much.
    Last night, somehow my BSM in my 2021 Limited PHEV was turned off on the freeway. I panicked and had to go through the settings menu while driving to turn it back on.
  12. Templeton
    371
    131
    usa
    2024 Prius Prime
    SE
    Thanks, l will try this.
    I am really not trying to do anything especially crazy. But we have 2 toyota phevs and we frequently have to play musical chairs on our small driveway as we use, park, and charge our cars (with a charging cable of limited length).
    And, me clearly being a lazy guy, l often can't be bothered to fully close my driver doors as l repeatedly get in and out of our cars to move them around. So l was wondering if there was an easy workaround. But sounds like l gotta buckle the belt or close the door ...
  13. KH111
    KH111 Member
    89
    45
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    I agree that some of the safety features can be irritating at times, but I kinda like the "rollaway" protection. I'm a retired airline pilot and years ago while sitting at the gate in Philadelphia and waiting to board our pax a runaway unmanned ramp worker's truck hit us in the tail section at about 20mph causing an estimated 1 million dollars in damage to the underside of our fuselage. Apparently in a hurry the ramper stopped the truck at a gate a few hundred yards from us and jumped out, thinking he slammed the transmission into "Park" but hit "Reverse" instead. He watched (actually ran) helplessly after the truck as he saw his career crash into our aircraft. Fortunately he missed our "bag smashers" loading our aft cargo compartment who saw the whole thing and jumped out of the way. Rollaway protection would have been nice that day.
    KH
    Gokhan likes this.
  14. Gokhan
    6,708
    2,659
    Paramount CA
  15. RobotBastard
    RobotBastard Junior Member
    30
    Connecticut
    2024 Prius
    Also, actor Anton Yelchin ("Chekov" in the Star Trek movie remakes) was killed when his jeep had a rollaway incident (wasn't actually in Park, he opened the door and got out, and it ran him over)
  16. Templeton
    371
    131
    usa
    2024 Prius Prime
    SE
    I am totally on board with you regarding safety and aviation safety too. But I am puzzled by the applicability of "rollaway" protection. Sure, I think rollaway protection seems like a good thing, but I do not understand how it applies in my case. Because, in my case, I am actively trying to drive my vehicle while I am in the driver's seat. I do not start moving until I am seated and I am actively controlling the car for the entire time. Then, when I am finished moving, I apply the brake, park the car, and exit the vehicle.
    My problem is that my gen5 automatically jams on the parking brake while I am actively driving the car (with my driver door closed, but not 100% closed) at 0.5 mph on my driveway. This is the auto braking function that seems unnecessary and is also tediously annoying to me as I often move and then park our cars on our driveway for access and for charging. So, how exactly does rollaway protection apply to this case?
    Also, slightly related, in life and in aviation, it is well known that spurious warnings are extremely dangerous, as they encourage people (like, say, pilots in a cockpit) to begin ignoring other warning indications. Which is a perfect description of my gen5's "front cross traffic alert" (FCTA) system. It goes off constantly nearly every time I safely take a right or a left turn at most any uncontrolled intersection with cross traffic. The dash and warning chime are a constant annoyance which is now training me to ignore it which is not a good situation for safety.
    I thought that toyota engineers were smart, but clearly they missed the boat on this one.
  17. Hammersmith
    2,462
    2,523
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    See, I find it just the opposite. I added FCTA about three months ago to my 2023 HEV that I've had since new. I was a tiny bit concerned about adding it because of some people complaining about it, but I've come to feel like those concerns are totally overblown. I don't mind at all when it goes off. It's a very pleasant chime, and it only happens when the vehicle is in motion. If you're at a complete stop, it doesn't trigger. When I hear the chime and I see cross traffic, my brain just treats it as a confirmation of what I'm seeing and I don't find it annoying. It hasn't happened to me yet, but if I hear the chime and DON'T see cross traffic, I hope I'll go on higher alert until I see what triggered it.
    I decided to push forward with the mod after a near collision last year where I would've been 100% at fault. It was a freak set of circumstances involving two vehicles of similar shape and color as well as one of them being obscured by the A-pillar at exactly the wrong time. But it wouldn't have come so close to happening if I had had FCTA at the time.
  18. Templeton
    371
    131
    usa
    2024 Prius Prime
    SE
    While I respect your view, in systems design, it is an accepted fact that spurious warnings are quite dangerous. In aviation, they have caused very serious accidents.
    Also, to clarify, I do not find the sound of my gen5's FCTA chime to be annoying or problematic. No, I far more find the spurious nature of its incredibly frequent warnings to be highly problematic. In this case, "spurious warnings" are frequent warnings that warn of an event or a condition that is not hazardous and/or is being fully and safely managed by the operator. Such a situation (frequent spurious warnings) essentially force a vehicle operator to begin ignoring these (and then other) warnings.
    It kind of becomes a case of 'the boy who cried wolf'. Because, when the warning is finally real, nobody pays attention.
  19. LRO
    LRO Member
    88
    92
    United States
    2024 Prius Prime
    XSE Premium
    I'm intrigued in hearing ideas of how Toyota could have implemented rollaway protections in a manner other than what they chose?
    It's no doubt a difficult task to figure out a driver's intent when the door is open and moving and the vehicle is not in P or N.
    Even with my foot on the brake, my Prius gives me a never-ending audio alert and a "Shift to P before exiting vehicle" message on the MID display if I'm in Ready mode and I open the drivers door and am not in P or N. Obviously that's Toyota's passive step 1 attempt to avoid any possible unintended situation.
    So with warnings like that not enough it seems the industry chooses between Auto-Park (Tesla and others) and Auto-Brake. Seems in both methods the vehicle can actually be moving a bit before they kick-in the protection.
    Since I don't believe our Prius has any occupant sensors in the drivers seat (like the passenger seat does) or universally offers the "much-loved" driver-facing camera to know if a driver is seated I wonder what else could they base a decision on?
    And FYI for all ...
    The National HighwayTraffic Safety Administration (NHTSA) in 2022 issued a 5-year report of Fatality And Injury Statistics in Non-Traffic Crashes (i.e. those that occur off public roadways). In that reporting period of 2016-2020 they estimated in the USA there were 718 rollaway vehicle deaths and 9,554 injuries which were "unintended with no driver in control". Can only imagine the numbers of vehicles and properties damaged where there were no injuries of any kind.
    #39 LRO, Jul 8, 2026
  20. Templeton
    371
    131
    usa
    2024 Prius Prime
    SE
    I think the easiest way would likely be an occupant sensor for the driver's seat.
