2027 toyota prius
Discussion in 'Gen 5 Prius Main Forum' started by Gerald10, Jun 14, 2026.
  1. Gerald10
    Gerald10 Junior Member
    i have a question to the 2027 toyota prius.
    Is it true that toyota usually releases the new prius in fall? How does allocation work if you want to get one?
    Does someone know the changes they will do from the 2026 toyota prius to the 2027 toyota prius version?
    Thanks,
    Gerald
  2. Paul Gregory
    Paul Gregory Senior Member
    2,330
    610
    Alberta
    2024 Prius Prime
    XSE
    When will the market stop reacting to fuel prices? When fuel is cheap, people don't buy EVs,
    and visa-versa.
  3. bisco
    52,750
    if you want to pay msrp, go to a dealer and they can tell you when and what will be coming in, and you can reserve one.
    if you want a better price, wait until they are on the lots. although, being in the southeast, you'd have to travel.
    there likely won't be any changes
  4. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    2027 Prius plug in hybrid models are already out in Cda per Toyota.ca with the base SE over $2K more expensive than the 2026. Only few changes added vs the ‘26: dual zone climate control and dual EV charger (level 1 & 2). Comparison was only the base model trim. Would be paying $3K more OTD if getting the new 2027!
  5. Hammersmith
    Hammersmith Senior Member
    2,439
    2,502
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Dammit. Toyota's CA website also says the 2027 HEV is getting dual zone climate as well. I was okay not having it before because it was only possible on the PHEVs(Europe's had dual zone from the beginning), but now that it's going to be in the HEVs as well, my mod addiction is going to get going again. And trying to add dual zone climate to an early gen5 HEV would be really rough. But I've been feeling cocky ever since I successfully added FTCA and LCA, and adding dual zone climate would be an even bigger challange.
    Yes, I'm an idiot and I'm okay with that. lol
  6. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    depends how badly you want that dual zone climate control…I’ve got that in my CRV hybrid and barely utilize it so in essence, I use it like my Prius PHEV that only has the single zone climate control which I am fine with!
  7. Gokhan
    Gokhan Senior Member
    6,689
    2,651
    Paramount CA
    The existing Gen 4/Gen 5 OEM EVSE is also dual Level 1 & 2 (120 and 240 V), but you need to buy an aftermarket plug adapter for Level 2.
