2027 toyota prius
Discussion in 'Gen 5 Prius Main Forum' started by Gerald10, Jun 14, 2026.
  1. Gerald10
    Gerald10 Junior Member
    38
    i have a question to the 2027 toyota prius.
    Is it true that toyota usually releases the new prius in fall? How does allocation work if you want to get one?
    Does someone know the changes they will do from the 2026 toyota prius to the 2027 toyota prius version?
    Thanks,
    Gerald
  2. Paul Gregory
    Paul Gregory Senior Member
    2,339
    614
    Alberta
    2024 Prius Prime
    XSE
    When will the market stop reacting to fuel prices? When fuel is cheap, people don't buy EVs,
    and visa-versa.
    52,817
    if you want to pay msrp, go to a dealer and they can tell you when and what will be coming in, and you can reserve one.
    if you want a better price, wait until they are on the lots. although, being in the southeast, you'd have to travel.
    there likely won't be any changes
  4. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    2027 Prius plug in hybrid models are already out in Cda per Toyota.ca with the base SE over $2K more expensive than the 2026. Only few changes added vs the ‘26: dual zone climate control and dual EV charger (level 1 & 2). Comparison was only the base model trim. Would be paying $3K more OTD if getting the new 2027!
  5. Hammersmith
    Hammersmith Senior Member
    2,473
    2,535
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Dammit. Toyota's CA website also says the 2027 HEV is getting dual zone climate as well. I was okay not having it before because it was only possible on the PHEVs(Europe's had dual zone from the beginning), but now that it's going to be in the HEVs as well, my mod addiction is going to get going again. And trying to add dual zone climate to an early gen5 HEV would be really rough. But I've been feeling cocky ever since I successfully added FTCA and LCA, and adding dual zone climate would be an even bigger challange.
    Yes, I'm an idiot and I'm okay with that. lol
  6. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    depends how badly you want that dual zone climate control…I’ve got that in my CRV hybrid and barely utilize it so in essence, I use it like my Prius PHEV that only has the single zone climate control which I am fine with!
    GcinFl likes this.
  7. Gokhan
    Gokhan Senior Member
    6,712
    2,661
    Paramount CA
    The existing Gen 4/Gen 5 OEM EVSE is also dual Level 1 & 2 (120 and 240 V), but you need to buy an aftermarket plug adapter for Level 2.
  8. bisco
    52,817
    it only took toyota 15 years to provide L2 oem without mods
  9. Gokhan
    6,712
    2,661
    Paramount CA
    The new OEM EVSE is basically the old one with a plug adapter. Why didn't they include a plug adapter before? Because that is Toyota, always as conservative as they can be.
  10. Hammersmith
    2,473
    2,535
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, I would almost never use the dual zones, but it's more of the challenge of doing something no one else would do(for good reason).
    Back in late 2022/early 2023 when I was researching the gen5 to decide exactly what I wanted, I made a mental list of all the subtle variations around the world. Then I sorted them into things I wanted and didn't want. And then whether they were possible or not. And finally how much they would cost to add and how difficult the process would be. I learned that Europe got the dual zone, but it was impossible to add to a HEV at the time because the A/C boxes were incompatible between the HEV and PHEV. But now that's going to change.
    But oh my god the work. I'd have to pull the dash again, but this time I'd also have to pull the structural metal dash bar and the instrument wiring harness. And I'd have to take the car to a shop to have the refrigerant pulled before I started. Then swap the A/C boxes, put everything back together, including a new A/C control assembly and probably a new A/C amplifier assembly, and then have the system recharged with refrigerant. And only then would I know if the 2023 US HEV could talk to the newer components. If not, I'd get to do everything all over again to convert it back. Fun.
    For cost reasons, I'd probably wait until a 2027 HEV ended up in a salvage yard.
    On the positive side, I've currently got a free TIS subscription until they realize their mistake. I had to reset my password(Toyota makes you do it every 90 days or so), and now I've got basic TIS access(repair manuals and wiring diagrams but no diagnostic access). I figure the access will disappear in a day or so, but it's nice to have it just as this 2027 dual zone climate thing came up. :)
  11. ColoradoBoo
    ColoradoBoo Senior Member
    1,346
    972
    Monument, Colorado USA
    When you're checking out the new Prius, you may also want to have a look at the Corolla Hybrids. We have both and, to be honest, I prefer driving the Corolla....gets same MPGs but has nicer seats and is easier to get in/out of. Neither came with a spare tire, though, so I've added them in the trunk.
    Also check out the Crown...I got to check out one in our grocery store parking lot (a rose gold color) and I really want one.
    Like our cars, the Crown doesn't come with a spare....that's very dumb, Toyota....give us the OPTION, don't just take it away from us.
    Ahmed, The Car Care Nut, really like his Crown he did a review on...
  12. Hammersmith
    2,473
    2,535
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Tiny quibbles:
    The car in the video is the Crown SIGNIA, not the regular Crown. The regular crown is a sedan(mostly), while the Signia is basically a station wagon(touring for you European folks). The regular Crown is nice if you want the sedan form, but I'd probably stay away from the top trim Platinum that uses the T24A turbo-4 with the Hybrid Max system. Lots of power, but crappy mpg and you have to do even more frequent oil changes if you want max reliability(4-5m/3-4k). Plus you give up the super reliable eCVT for an 8-speed automatic. The Signia only comes with the A25A + standard hybrid eCVT, so no worries there.
    And just the general FYI that you actually can add a factory spare to both the Crown and Crown Signia if you really want it. It's about $1,300 best-case for the full Signia conversion, so it's definitely an ouch, but the option exists. (The Signia would be my next choice if I needed more room, which is why I heavily researched it. I think it's a great car.)
    I think you can also do a factory spare conversion for the FWD Corolla hybrid sedan, but not the AWD version.
    ColoradoBoo likes this.
  13. Gokhan
    6,712
    2,661
    Paramount CA
    You are three years away from your Gen 6 upgrade! Still lots of mods to go with!
  14. Hammersmith
    2,473
    2,535
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The plan has always been to hold on to this one for 10 years or more. That's how I've justified the cost of the mods so far. Do them early to get the most use out of them. :)
    I honestly see myself going EV for my next car. I need a small/mid Toyota 4-door AWD hatchback on a car platform(not SUV/CUV) that has most/all of the Toyota options(360 camera, ventilated seats, etc.) and at least 325 miles of range in the top trim. The day Toyota comes out with that vehicle is the day I start cleaning up my Prius for trade. lol
    Blackat and Gokhan like this.
  15. Prodigyplace
    12,711
    11,848
    Central Virginia
    FWIW all Camry trims come with a spare tire and, I believe, dual zone climate. At least, my 2025 Camry XLE has that.
  16. RobotBastard
    RobotBastard Junior Member
    30
    Connecticut
    2024 Prius
    One of the things that occurred to me while woolgathering was that if Toyota wanted to have a reason to keep selling the Prius, "it was Toyota's first hybrid, and now it's Toyota's first EV" is right there on the table...
  17. ezthrilla
    ezthrilla Junior Member
    Arcadia, CA
    Model Year 2027 Prius is now available in the Toyota USA website!
    Gokhan and Tekz like this.
  18. Hammersmith
    2,473
    2,535
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Changes for 2027:
    1. Black paint color has been switched from Midnight Black Metallic/Attitude Black Mica(218) to Inked/Neutral Black(229)
    2. Engine horsepower increased from 150hp to 156hp on HEV and from 149hp to 152hp on PHEV. Torque is unchanged.
    3. Some changes to the Brake Hold function and the addition of Brake Force Control to the Smooth Stop function.
    4. Dual zone climate control.
    That's it. If there are any other changes, they're so minor that Toyota isn't including them in the New Car Features document.
    The model year switchover is happening this month, so 2027s should start hitting lots in late July or more likely sometime in August(normally takes almost two months for cars to get from the factory in Japan to dealer lots in the US).
    (I'm probably wrong, but I wonder if the hp increase is just due to the change in oil from 0W16 to 0W8. I think the oil change technically happened early in the 2026 model year, so maybe they held off on the official rerating until 2027?)
    Gokhan likes this.
  19. Winston Smith
    Winston Smith Active Member
    456
    330
    OH
    2024 Prius
    LE AWD-e
    I just changed oil with Toyota 0w16. It drains from the bottle so quickly.
    I remember changing the oil in an old VW and waiting for the 10w30 to drain. It took a while.
  20. Gokhan
    6,712
    2,661
    Paramount CA
    From 0W-16 to 0W-8, you would gain only a fraction of a percent of a horsepower increase. I doubt you could even get 1%. 4% increase in the HEV is huge. They must have made some physical change and/or a software update for the engine.
    I think the three-coat white is the best Gen 5 color. It is luxurious and looks great on the Gen 5. I don’t like the gray and not so much the dark blue either. Silver makes the car look older. The three-coat red is a premium color, too, and it’s alright. However, the same red looked better on Gen 4 than it does on Gen 5. Black looks good, but Gen 5 (or Gen 4) isn’t that good-looking a car to benefit from it, and it hides the car's features. I wonder if the new Inked black looks better than the old Midnight black. It seems to be shinier, which is good. Yellow is for those who like yellow.
    #20 Gokhan, Jul 17, 2026
