Harsh start after a few days without engine use
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by p3p5p, Jul 5, 2026 at 11:03 PM.
  1. p3p5p
    p3p5p New Member
    2025 Prius Plug-in
    XSE
    Hi folks,
    I purchased a 2025 PHEV XSE a few months ago with 5000 miles on it, now have 7000 miles. I've really been enjoying it. However, I've noticed that if I don't use the engine for about 5+ days, the first engine start will be "harsh". It's still quick, it runs perfectly after the first quarter second, but the initial spin-up feels like it shakes the car. This isn't the case on subsequent warm starts, or on cold starts the next day. I should note that it's summer here, so these harsh starts are occurring even in hot weather.
    I don't recall this happening on my gen3, though of course that one used the engine on every trip, so the engine was in regular use unless I was out of town for the week or something. With my PHEV all it takes is a week of normal EV commuting followed by a longer weekend trip to notice the effect.
    Has anyone else noticed this? Obviously I've got plenty of engine warranty left, but want to make sure my engine isn't self-destructing!
  2. Hammersmith
    Hammersmith Senior Member
    2,441
    2,502
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This is only a guess, but my first thought is that it's oil pressure related. When an engine stops, there are check valves to prevent all the oil from falling back into the oil pan. That means there's effectively full oil pressure immediately on the next start. But no system like this is perfect, so if you let the engine go long enough between starts, the oil will manage to leak past/through the check valves and the engine won't have full oil for those first tenths of a second on that next start.
    There will still be a film of oil on all surfaces, so excessive wear shouldn't be a major issue, but it will take that bit of time to refill all the oil galleys and get up to full pressure. Also, the variable valve timing on the exhaust camshaft is controlled by oil pressure, so maybe that's contributing to that first half second of engine roughness.
    Hopefully other PHEV owners can say whether this is typical behavior or abnormal. I'm leaning towards typical, but I'm a HEV owner and can't recreate the issue reliably.
    The other thought that comes to mind is rust related, but I really really doubt that's the case.
    Honestly, I'd try to make sure to run the ICE about once a week for 15 minutes or so. It's just best practice to keep everything well-lubricated and to get the oil temp up high enough to burn off any water or gas contamination. This is doubly true in winter(the M20A and A25A engines have known issues with moisture buildup in the oil(from condensation) when they're not allowed to get to full temp in winter). It's also a bit helpful to not let gas just sit in the fuel injection system for weeks at a time. Not a big big deal, but flushing newer fuel through the system every week or so decreases the likelihood of a problem down the road.
    Now I'm just some internet hack, so absolutely do not take my thoughts as gospel. But I am repeating the once a week advice from someone with over a decade of working on tens of thousands of Toyotas and Lexuses.
  3. Mendel Leisk
    42,242
    You typically let the car run through the battery capacity, on weekdays? Then on the weekends, the same, and the engine just kicks in due to longer trips, depleted charge? Or you purposely start the car like a regular hybrid?
  4. cablesm
    cablesm Junior Member
    [removed]
    #4 cablesm, Jul 6, 2026 at 9:48 AM
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,331
    952
    Monument, Colorado USA
    Yes, I've noticed my engine sounding a bit different when she starts up after sitting for a while....I don't like it, either!! But she's going on 70,000 and the oil still looks pretty clean after 5,000 miles so that's a good sign.
    Because I take my Prius to work (a 40-mile commute) I don't like the idea of the engine having to run hard right away so I've learned that, when I turn on the car in the garage, if I tap the gas pedal a little it will cause the gas engine to come on....I like to get it a little warm before going 60 mph on her.
