Harsh start after a few days without engine use
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by p3p5p, Jul 5, 2026.
  1. p3p5p
    p3p5p New Member
    24
    2025 Prius Plug-in
    XSE
    Hi folks,
    I purchased a 2025 PHEV XSE a few months ago with 5000 miles on it, now have 7000 miles. I've really been enjoying it. However, I've noticed that if I don't use the engine for about 5+ days, the first engine start will be "harsh". It's still quick, it runs perfectly after the first quarter second, but the initial spin-up feels like it shakes the car. This isn't the case on subsequent warm starts, or on cold starts the next day. I should note that it's summer here, so these harsh starts are occurring even in hot weather.
    I don't recall this happening on my gen3, though of course that one used the engine on every trip, so the engine was in regular use unless I was out of town for the week or something. With my PHEV all it takes is a week of normal EV commuting followed by a longer weekend trip to notice the effect.
    Has anyone else noticed this? Obviously I've got plenty of engine warranty left, but want to make sure my engine isn't self-destructing!
  2. Hammersmith
    Hammersmith Senior Member
    2,495
    2,554
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    This is only a guess, but my first thought is that it's oil pressure related. When an engine stops, there are check valves to prevent all the oil from falling back into the oil pan. That means there's effectively full oil pressure immediately on the next start. But no system like this is perfect, so if you let the engine go long enough between starts, the oil will manage to leak past/through the check valves and the engine won't have full oil for those first tenths of a second on that next start.
    There will still be a film of oil on all surfaces, so excessive wear shouldn't be a major issue, but it will take that bit of time to refill all the oil galleys and get up to full pressure. Also, the variable valve timing on the exhaust camshaft is controlled by oil pressure, so maybe that's contributing to that first half second of engine roughness.
    Hopefully other PHEV owners can say whether this is typical behavior or abnormal. I'm leaning towards typical, but I'm a HEV owner and can't recreate the issue reliably.
    The other thought that comes to mind is rust related, but I really really doubt that's the case.
    Honestly, I'd try to make sure to run the ICE about once a week for 15 minutes or so. It's just best practice to keep everything well-lubricated and to get the oil temp up high enough to burn off any water or gas contamination. This is doubly true in winter(the M20A and A25A engines have known issues with moisture buildup in the oil(from condensation) when they're not allowed to get to full temp in winter). It's also a bit helpful to not let gas just sit in the fuel injection system for weeks at a time. Not a big big deal, but flushing newer fuel through the system every week or so decreases the likelihood of a problem down the road.
    Now I'm just some internet hack, so absolutely do not take my thoughts as gospel. But I am repeating the once a week advice from someone with over a decade of working on tens of thousands of Toyotas and Lexuses.
  3. Mendel Leisk
    42,364
    You typically let the car run through the battery capacity, on weekdays? Then on the weekends, the same, and the engine just kicks in due to longer trips, depleted charge? Or you purposely start the car like a regular hybrid?
  4. cablesm
    cablesm Junior Member
    [removed]
    #4 cablesm, Jul 6, 2026
  5. p3p5p
    p3p5p New Member
    24
    2025 Prius Plug-in
    XSE
    Yes, during the week, I commute ~17 miles per day and stay within my EV range. On the weekend, I sometimes have longer trips. However, I notice the “harsh starts” whether it starts after depleting the EV range, or whether I start it myself by selecting HV mode.
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,354
    982
    Monument, Colorado USA
    Yes, I've noticed my engine sounding a bit different when she starts up after sitting for a while....I don't like it, either!! But she's going on 70,000 and the oil still looks pretty clean after 5,000 miles so that's a good sign.
    Because I take my Prius to work (a 40-mile commute) I don't like the idea of the engine having to run hard right away so I've learned that, when I turn on the car in the garage, if I tap the gas pedal a little it will cause the gas engine to come on....I like to get it a little warm before going 60 mph on her.
  7. BiomedO1
    BiomedO1 Senior Member
    4,635
    2,433
    Left Coast
    You can experience "harsh starts" depending on how deep your on the gas pedal during transitions from EV to HV. I prefer to regulate mine and manually switch over to HV; once I'm on the highway, up to traffic speed and off the pedal. My transitions are quiet smooth, but this is also a gen4 with only a 25 mile EV range. Once the engine is warmed up for the first time; I only notice the transitions through pedal feel and slight lost of power; in ECO mode. I understand that if you keep your car in normal or sports mode, you would feel less power loss and a more responsive pedal; at the cost of lower mpg.
    Good Luck.....
  8. p3p5p
    p3p5p New Member
    24
    2025 Prius Plug-in
    XSE
    It’s harsh even when there’s no load, such as while stationary.
    Also, if you monitor the engine, it turns out it will almost never load the engine for 45 seconds or so once it starts, unless you’re accelerating pretty hard. So even cruising on the highway, if it switches to HV, the engine won’t do much of anything for a little while except “idle” at 1300 rpm.
  9. p3p5p
    p3p5p New Member
    24
    2025 Prius Plug-in
    XSE
    I guess what would be really helpful is if someone with a gen5 PHEV, who also goes 5+ days without engine use, could tell me if they’ve noticed similar :)
  10. LOW-ETS
    LOW-ETS New Member
    Thursday
    Toronto
    2026 Prius Plug-in
    SE
    You definitely are NOT alone in this experience.
    I have the exact same issue; albeit mine is a 2026 Prius. Similar to one of the previous responders to this thread; it appears to be oil pressure related. The intake valves on the m20a-FXS are electronically controlled; the exhaust valves are NOT. They are oil controlled. Similar to you; I experience a very rough engine start condition if I’ve driven the vehicle in electric mode for several days prior to the rough-start.
    When I attempt to start the car in hybrid mode after several days of electric only drive-mode; there is a very definitive rattle, rough start and poor start condition. Now, it only lasts about a half-second or so - but, like you, it’s definitely present. I’m suspecting that after several days of electric vehicle operation, the oil pressure required to control the timing of the exhaust value; is simply not sufficient at start-up [despite the timing chain to accurately and precisely time the intake and exhaust valve to the crankshaft in a start condition]. Once the pressure builds, in that half-second or so of startup, the timing returns to its optimal configuration and the noise/vibration/harness immediately disappears. Like you, every subsequent start the same day; is perfectly fine. Even the following morning, it’s fine. That observation [i.e.,every subsequent start the same day; is perfectly fine] tends to eliminate some hardware condition inside the cylinder head [i.e., cam phaser, timing motor, etc] and leads me to believe this is oil pressure bleed-through.
    Unlike the m20-FKS, the FXS in our generation, also appears to have higher compression; and I think some of that too contributes to the rattle condition - there appears to be a very brief moment of poor air/fuel calibration. I’ve left my son’s non-hybrid 2020 Corolla [with the m20-FKS] for more than a week; just sitting in the garage - that vehicle runs a nearly identical engine [including most of the exhaust/intake components] except it’s the Otto Cycle [non-hydrid]. Zero rattle on startup. Zero. But, the FKS does not have to contend with much more aggressive overlap between the exhaust and intake value like the Atkinson engine and the much higher compression.
    So I’m suspecting that this is very similar to the old Camry/Highlander cam phaser rattle - except in this case; it’s simply oil pressure and not premature cam phase failure.
    What can you do about it - I’m not entirely sure how to prevent it. What I have confirmed is this; i can replicate the rattle and rough start nearly every-time I drive the vehicle in electric mode for two days or more. And maybe; maybe - i should just start the engine every two days; run it to NOT [normal operating temperature] and then cut back to electric vehicle mode.
    I apologize if there are errors and omissions; it’s just an observation that I hope could help someone. I absolutely could be wrong in my explanation. Have a great day everyone.
  11. BiomedO1
    4,635
    2,433
    Left Coast
    That's the way it's designed to work; that's why I do a manual switch-over. If there's an emergency where you need to power-out of getting hit and the transition happens at the same time - your S.O.L..:( A manual switchover in clear traffic will give you that 45 sec. switchover; so there's no surprises.o_O
