Rattling Engine at Shut down
Discussion in 'Gen 3 Prius Technical Discussion' started by theJoePrius, Aug 12, 2020.
  1. theJoePrius
    theJoePrius New Member
    Anapolis Md
    My engine makes this ratting noise that sounds like a metallic object left flapping around inside when I turn the engine off.
    The background story is that my hybrid system on my 2013 Prius is down ...;) again after a fail HV battery rebuild project. So at this time the HV battery is not charging or discharging and the whole car is running on the gasoline engine only. my obd2 code are P0A80 and P3024.
    P0A80 is a familiar code that I get when battery cells fail, but this P3024 started showing up at the same time as the rattling issue.
    I know I have to address the HV battery issues, but I don't know if the rattling issue is related to hybrid system not functioning or if it a completely different issue. Are the motor generators MG1 and MG2 responsible for bringing the gasoline engine to a quite and smooth stop?
    my second question is whether it is safe to drive it on gasoline engine only.
    Ismael car likes this.
    52,891
    1) the engine won't start with a failed hybrid battery
    2) the rattling is probably a clogged egr circuit. how many miles on her?
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    That is the safest way to drive the vehicle. the car won’t even start without a working HV bat so you won’t have to be in the car nor harm pedestrians or other vehicles or yourself.
    #3 Grit, Aug 12, 2020
  4. theJoePrius
    Anapolis Md
    Thanks for replying,
    It has 160k.
    I read quite a bit about that egr circuit issue, and given my mileage it's quite possible. I'm still a little hesitant on that route because my symptoms are not quite the same as others. Most people seem to experience rattling when slowing down while driving or while idling. In theses cases a constricted egr circuit seems to be preventing the pressure threshold in the intake manifold to be made.
    Mine only rattles when I push the button to shut the car off, it feels like something is spinning freely before coming to a rattling stop.
    Unless I'm mistaking my understanding of the egr system, it should have no role during the shutdown process.
    My engine rpm gets up and my idle is very laud though, I've seen a couple people mention the same issue, but not clear if it is related to the egr or the HV battery issue.
    #4 theJoePrius, Aug 18, 2020
  5. theJoePrius
    Anapolis Md
    Well it is starting and driving, except it's not charging or discharging the HV battery. I am just not sure how far it can go in this condition.
  6. Mendel Leisk
    42,369
    With those miles (and symptoms) could well be both, hybrid battery getting out of balance and EGR clogging. Check the battery wit dr Prius and a Carista Bluetooth adapter. For the EGR start by checking condition of the pipe between EGR valve and intake manifold. @NutzAboutBolts has a video on the latter, linked in pinned thread at top of maintenance forum.
    NutzAboutBolts likes this.
  7. bisco
    52,891
    at how many miles/years did your oem battery quit?
  8. ttou68
    ttou68 Active Member
    351
    211
    If you're planning on keeping it, your will need to do that maintenance soon or later.. I would suggest to go ahead and clean EGR system, PCV, and change the spark plugs... it's time for both if you haven't already...
    PriusGuy32 likes this.
  9. Ismael car
    Ismael car New Member
    Tulsa Oklahoma
    Sorry I’m a little late to this but I have this exact same issue and it’s also a 2013 but I just bought a new 12v battery about a month and a half ago. Could it still be the battery? Can any mechanic look at it and kind of know or will I have to take it to the dealer and then have a look at it? It will probably be an arm and a leg just to look at. But if anyone can reply to thank I would gladly appreciate it
  10. viciousthinker
    viciousthinker Junior Member
    32
    Houston tx
    theJoePrius, did you ever figure out what was causing this co dition? My car is doing e aptly the same thing, specifically when shutting down when in 'limp mode'... it sounds like something spinning that c I concludes with a rattling clatter sound... no rattles whatsoever when starting or driving, only at shutdown whe ICE is running..?
  11. Hybrid Battery Exchange
    83
    94
    Gresham, OR
    I've seen this on many 3rd gen Prius with a bad hybrid battery. The hybrid system uses the generator motor to quickly spin down the gas engine, with a very weak hybrid battery it doesn't do this and the engine takes 2 to 3 seconds to spin down.
  12. viciousthinker
    32
    Houston tx
    rattling stop when ICE spins down when car is shut down, especially when in LIMP mode denotes a failing CVT input damper plate, i'm in the same boat...getting the multitude of things together i'm going to need to fix it currently, hoping to tackle before it fails altogether. do you also experience an odd 'thrumming' or vibration when at highway speeds? any bucking or lurching from a standstill yet, almost like a level of resistance between the ICE and the drivetrain? if not then yours isn't too far gone yet... this is the culprit, it unfortunately resides between the transaxle and ICE, and requires access to replace.
    the book says to drop both engine and transaxle to replace, but that requires the disconnection and removal of axles, etc... it is apparently possible to use two transmission jack's (the rolling kind that allow sideways movement), one under ICE, one under transaxle, support both and remove mounts, lower just enough to separate the two from each other (series of bolts going around periphery) and crack open just enough to push transaxle sideways to gain just enough access to remove the 6 bolts and swap damper plate. alternately, using a hoist to bring the ICE up and out can be utilized.
    the damper plate has 4 springs integrated into it, over time these springs can stretch and become loose, and fail altogether hence the rattle you hear when the ICE comes to a stop rotation-wise.
    apparently this has been a rare issue w/ these cars, but i'm thinking as the car gets older we might be seeing this particular failure become more commonplace.
  13. Mendel Leisk
    42,369
    Those fail for a reason? Coolant in the cylinders?
    What's the miles? Has EGR been cleaned? If so, how and when?
  14. viciousthinker
    32
    Houston tx
    still no coolant in cylinders, no steam cleaning of any piston tops, no death rattle and no coolant loss... to be honest I've been expecting it forever at this point, I have a box set aside w/ a new FelPro headgasket, a complete timing kit, headbolts and an engineers straightedge ready and waiting as I've felt like it has to be coming at some point, but i got the car at140k 5 years ago and it is at 280k+ as of today,and I've never once heard the damper plate slamming back and forth on this particular car... I also was under the impression the headgasket/EGR death rattle would be responsible, but that hasn't proven true for mine... I certainly noticed when one of the springs snapped on mine though, was like a super loud pop sound. I am not looking forward to the job of replacing it in the current Houston heat.
    Oh, PS... EGR was cleaned about 30k-35k ago, from the intake all the way back.
  15. Mendel Leisk
    42,369
    That was the first EGR cleaning you did? Likely the car’s first? How was the carbon? Was there any flow on the small EGR passage in intake manifold, at cylinder one (left end, when facing engine bay from front of car).
  16. viciousthinker
    32
    Houston tx
    No, second EGR cleaning... first time around was around 160k, semi clogged that time around, but not sealed over in the cooler, but that first time i did it the intskr was pretty gunked up. this last time around it was minimal buildup, none of the small canals in the intake were sealed over yet but I did have a small puddle of oil at the lowest plane of the intake... this third-gen has been really kind to me so far in terms of engine compared to my first third-gen (now known as the parts car), although its hybrid battery issues are becoming taxing.
    the damping plate issue never causes me any noise or rattle at startup, the violence is all saved for shutdown, the racket that ensues when the engine is going from its running state to shutdown is alarming, it sounds like a roll of nickels in a dryer, albeit for only like 3-5 seconds.
