Rattling Engine at Shut down
Discussion in 'Gen 3 Prius Technical Discussion' started by theJoePrius, Aug 12, 2020.
  1. theJoePrius
    theJoePrius New Member
    Anapolis Md
    My engine makes this ratting noise that sounds like a metallic object left flapping around inside when I turn the engine off.
    The background story is that my hybrid system on my 2013 Prius is down ...;) again after a fail HV battery rebuild project. So at this time the HV battery is not charging or discharging and the whole car is running on the gasoline engine only. my obd2 code are P0A80 and P3024.
    P0A80 is a familiar code that I get when battery cells fail, but this P3024 started showing up at the same time as the rattling issue.
    I know I have to address the HV battery issues, but I don't know if the rattling issue is related to hybrid system not functioning or if it a completely different issue. Are the motor generators MG1 and MG2 responsible for bringing the gasoline engine to a quite and smooth stop?
    my second question is whether it is safe to drive it on gasoline engine only.
    Ismael car likes this.
    52,690
    1) the engine won't start with a failed hybrid battery
    2) the rattling is probably a clogged egr circuit. how many miles on her?
  3. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    That is the safest way to drive the vehicle. the car won’t even start without a working HV bat so you won’t have to be in the car nor harm pedestrians or other vehicles or yourself.
    #3 Grit, Aug 12, 2020
  4. theJoePrius
    Anapolis Md
    Thanks for replying,
    It has 160k.
    I read quite a bit about that egr circuit issue, and given my mileage it's quite possible. I'm still a little hesitant on that route because my symptoms are not quite the same as others. Most people seem to experience rattling when slowing down while driving or while idling. In theses cases a constricted egr circuit seems to be preventing the pressure threshold in the intake manifold to be made.
    Mine only rattles when I push the button to shut the car off, it feels like something is spinning freely before coming to a rattling stop.
    Unless I'm mistaking my understanding of the egr system, it should have no role during the shutdown process.
    My engine rpm gets up and my idle is very laud though, I've seen a couple people mention the same issue, but not clear if it is related to the egr or the HV battery issue.
    #4 theJoePrius, Aug 18, 2020
  5. theJoePrius
    Anapolis Md
    Well it is starting and driving, except it's not charging or discharging the HV battery. I am just not sure how far it can go in this condition.
  6. Mendel Leisk
    42,179
    With those miles (and symptoms) could well be both, hybrid battery getting out of balance and EGR clogging. Check the battery wit dr Prius and a Carista Bluetooth adapter. For the EGR start by checking condition of the pipe between EGR valve and intake manifold. @NutzAboutBolts has a video on the latter, linked in pinned thread at top of maintenance forum.
    NutzAboutBolts likes this.
  7. bisco
    52,690
    at how many miles/years did your oem battery quit?
  8. ttou68
    ttou68 Active Member
    351
    211
    If you're planning on keeping it, your will need to do that maintenance soon or later.. I would suggest to go ahead and clean EGR system, PCV, and change the spark plugs... it's time for both if you haven't already...
    PriusGuy32 likes this.
  9. Ismael car
    Ismael car New Member
    Tulsa Oklahoma
    Sorry I’m a little late to this but I have this exact same issue and it’s also a 2013 but I just bought a new 12v battery about a month and a half ago. Could it still be the battery? Can any mechanic look at it and kind of know or will I have to take it to the dealer and then have a look at it? It will probably be an arm and a leg just to look at. But if anyone can reply to thank I would gladly appreciate it
