2019 Prius Slow Coolant Leak
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JeffPGH, Jun 25, 2026.
  1. rjparker
    11,011
    6,901
    No. It might cost a little mpg. Toyota design it to open on high exhaust pressure alone when high rpms are being used.
    There is no single root cause of gen3 head gasket failures unless you want to blame the engine design and testing team when it was adapted from a Corolla for use in a hybrid. It worked fine in a conventional Corolla which even had the egr system. The Corolla also had low tension rings which lead to excessive oil burning as did Camry and Rav4s but Corollas did not blow head gaskets without overheating.
    It's clear Toyota quickly knew they had problems using the Corolla engine in a thermal cycling hybrid with an Atkinson cycle camshaft. Five years later a redesigned 1.8L solved the hg problems for gen4 which is why many have embraced using parts of a gen4 in a gen3 car, eg a Frankengine. Hybrid Pit now sells a rebuilt gen4 block, a modified head gasket and a gen3 head topped with a gen4 cam carrier. But most older gen3s are not worth using their most expensive option when fully rebuilt and moderately improved gen3 engines are available for less.
    #41 rjparker, Jul 2, 2026
  2. JeffPGH
    JeffPGH New Member
    Pittsburgh, PA
    2019 Prius
    I put the UV Dye in and drove around for a while. I took a look as best I could without being able to lift it into the air. I didn’t see any obvious signs of leaking. That doesn’t seem like a good sign.
  3. bisco
    52,784
    could the new cat be leaking?
  4. JeffPGH
    JeffPGH New Member
    Pittsburgh, PA
    2019 Prius
    I was wrong on my last message and I tried to erase it but could only edit it. I thought it drained overnight but it is actually pretty close to full. It was hard to see with the UV Dye in it until I put a flashlight on it. Might be the new cat. Not sure. Probably gonna need to take out the spark plugs and see if any dye went in there.
    Coolant Leak Tracking
    • 6/26/26 Put on new cap
    • 6/27/26 344542 Coolant was a little below the Low line. Topped it off to Full after it sat all night.
    • 6/28/26 344768 (226 miles) Coolant was about 1.5 inches below full line…. It was below the low line. Topped it up to full
    • 6/29/26 344934 (166 miles) Coolant was right at the Low line. Topped it up to full.
    • 6/30/26 345168 (234 miles) coolant was halfway between the Full and Low line. Topped it up to the Full line.
    • 7/01/26 345414 (246 miles) coolant was almost at the bottom of the reservoir. Put the Prius in maintenance mode to keep the engine running and did the block test. It stayed blue. I put the tester by the exhaust pipe and confirmed that it started turning green. Let it cool down and topped it up to the Full line.
    • 7/02/26 345624 (210 miles). Coolant was down near the bottom of the reservoir again. Topped it off to the full line. Planning on putting UV Dye in it tomorrow.
    • 7/03/26 345800 (176 miles). Coolant at the bottom of reservoir again. Put in UV dye and topped off to full.
    • 7/04/26 345981 (181 miles). Coolant near the full line.
  5. C Clay
    C Clay Member
    393
    78
    Lexington, KY
    2019 Prius
    L Eco
    Not intending to highjack thread- but wondering if @JeffPGH notices same thing- when I put coolant in the car in the morning, I hear a gurgling as if the coolant level is going to go down incrementally if I were to give it a minute, but it doesn’t appear to. Why is it that the right corner will appear as if it has no fluid but yet the left corner and the rear right clearly show that there is half way up the volume of the tank it would seem.
  6. a2058
    a2058 Junior Member
    59
    24
    Westchester, NY
    2019 Prius
    XLE AWD-e
    My 2019 Awde developed similar issue. I was adding coolant daily to top off for months, and then I saw that I would blow white smoke out the exhaust typically during acceleration on uphill drives. I did the bottom side bypass and locked the bypass valve to open position. The coolant level has not changed ever since. Try looking in the rear view mirror, during an uphill acceleration…
  7. JeffPGH
    JeffPGH New Member
    Pittsburgh, PA
    2019 Prius
    Here is what my mechanic said today:
    “So we got a look at your car. We have a list of things we found, but more importantly, the head gasket is blown and pumping coolant into at least one of the cylinders. Between the exhaust smelling like coolant on startup from coolant leaking into the cylinder, and the coolant bottle smelling like raw combustion gasses, it's the head gasket. We see a lot of older Subarus come in exhibiting the same exact symptoms. I got a rough estimate to do the job, which is about $3750. I didn't know if you would even want to consider it at that point, but if that's not out of the question, I can email you a full itemized estimate to do the job as well as the few other things he found.”
  8. BiomedO1
    4,527
    2,380
    Left Coast
    Everything that you've stated could also be an EGHE leak too. What tests was performed to verify it's a head gasket issue? Do you have a P0300 code stored? Guesses can cost you $3750 with no resolution to your current problem. The big elephant in the room is that your NOT working on a Subaru and it's a totally different engine design, so I don't see the relevance here. It sounds like your just trying to talk yourself into spending $3750 on a guess.....
    Your car, your money - do whatever you like.....
  9. rjparker
    11,011
    6,901
    You can't keep losing coolant every day or you will be stranded a hundred miles from home.
    Assuming the engine overheated prior to the first exhaust heat exchanger repair, the current shop is probably right. With your level of coolant loss, and assuming he can smell gasses in the reservoir, he should be able to see coolant in the cylinder or at least view a "steam cleaned" piston. Or get a positive combustion gas in coolant test.
    Is this the same guy who did the earlier borescope test?
    This is the most compelling hg symptom you have observed and reported. Do you think you missed this on other occasions when you said the engine ran fine?
    I still think an exhaust heat exchanger bypass (post 6) is SO easy and cheap - even as a diagnostic to absolutely rule out this possibility.
    Overall, if it is a hg, your dealer was truly negligent if not grossly incompetent with their negative borescope test while missing something as obvious as combustion gasses in the coolant reservoir.
    The next question is what exactly will the current shop do for $3750 to guarantee a hg repair will work on this engine which has been run hard with this fault.
    #49 rjparker, Jul 16, 2026 at 12:24 AM
    BiomedO1 likes this.
  10. Mendel Leisk
    42,271
    Protracted neglect of a leaking exhaust heat recover (EHR) system can lead to a blown head gasket: when you're constantly obligated to check and top up the coolant engine may run dry in between your checks, and overheat.
    There IS a TSB for the EHR system leakage, very prevalent with 4th gen, especially the earlier years. Dealership should have got on that right away, instead of all this malarkey.
    For a Toyota dealership service advisor to suggest stop-leak is preposterous. I would get in touch with Toyota USA.
  11. rjparker
    11,011
    6,901
    In post 1 the op reports the exhaust heat exchanger was replaced recently after a bypass proved it was the source of coolant loss two years ago. However further coolant loss began immediately which is when the dealer did a negative borescope and pressure test. At that point they suggested stop leak.
    Obviously the dealer continually misdiagnosed the hg which resulted in a new exhaust heat exchanger. The bypass had been in place for two years.
    #51 rjparker, Jul 16, 2026 at 12:31 PM
  12. Mendel Leisk
    42,271
    Ah, ok. Maybe the replacement leaked too?
