2012 Prius - Mysterious Driver-Side "Clunk
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Braulio, Jul 20, 2026 at 1:44 PM.
  1. Braulio
    Braulio New Member
    Yesterday
    Hey everyone,
    I’m chasing down a frustrating clunking sound on my 2012 Prius and could really use some expert eyes on this.
    The Symptom:
    I am getting a distinct, back-and-forth "clunk" or "knock" from the driver's side of the engine bay. It isn't a continuous rattle—it's usually just 1 or 2 random clunks that happen right at the exact split-second the gas engine cycles on while the car is idling/stopped. To my ears, it sounds like it is coming directly from the rear transmission mount area.
    What I’ve Already Replaced/Done:
    Main Transmission Mount (Driver Side, behind inverter): Replaced yesterday.
    Rear Transmission Mount: Brand new. Replaced 2 weeks ago
    Lower Torque Strut Mount: Inspected, rubber looks solid with no cracks.
    EGR System & Intake Manifold: Completely torn down and cleaned out recently to clear all passages.
    Sway Bar End Links: Checked and verified tight.
    Because it's a transient thud right when the engine catches, I thought it might be a bad passenger side engine mount, since it's the only one I haven't checked, I did a visual inspect on it and it doesn't appear to be collapsed.
    Given that the driver-side and rear mounts are brand new and torqued down, what could be causing a localized clunk near the rear mount just as the engine kicks over?
    Could a weak passenger mount still cause enough pivot/leverage to twist the drivetrain and slam against the new rear mount? Or should I be looking into subframe/exhaust clearance, loose bracket bolts, or something internal like the flywheel damper assembly?
    Appreciate any insights or similar experiences!
  2. Brian1954
    Brian1954 Senior Member
    2,666
    1,066
    South Central PA, USA
    How many miles on the car?
    My guess is the damper plate assembly.
  3. Braulio
    Braulio New Member
    Yesterday
    62k miles
    #3 Braulio, Jul 20, 2026 at 9:59 PM
