1. Christian Muise
    Christian Muise New Member
    Yesterday
    Ontario, Canada
    2020 Prius Prime
    Could use an assist on this one. It's been progressively getting worse for over a year now, and dealership maintains that everything's fine -- pads and rotors seem fine. We can book in a $300 brake inspection, but I'd like to go into it informed. I have a video of the phenomenon*, but can't post due to being a new user. If anyone has a pointer to common "does your car sound like this? here's why!" videos, I'd be very grateful! I guess I can (hopefully?) DM the video link as well.
    Some details:
    - happening almost always when coming to a stop
    - slow rolling stop makes it worse. as does stopping on an incline
    - the second set of squeaks is after putting it in park and taking the foot off the brake (no wheel motion)
    - mechanic said pads and rotors are in great condition (service 1 done today)
    - we don't drive a lot: 47k on the car at this point
    Anything else worth mentioning?
    * Why is it so hard to find example brake sounds + diagnoses online!!
  2. JC91006
    JC91006 Senior Member
    16,936
    8,646
    You might just have bad/cheap brake pads. Have you replaced them before or are they the originals?
    Toyota sells inferior brake pads now using the Toyota name. If you replaced them recently with the "cheap" variety, you would get brake noises when you brake
  3. ChapmanF
    18,978
    Please do post a recording link as soon as you've made a few more posts so you can.
  4. Christian Muise
    Yesterday
    Ontario, Canada
    2020 Prius Prime
    Thanks! As far as we can tell, original brake pads on the car. They replaced the back ones in 2023 (I guess it was an issue that we "didn't drive enough"?), but the inspection (visual only) yesterday indicated that rotors and pads looked entirely fine.
    Sound is only on the front, and the fact that it also happens when releasing the brake while at a stop makes me think that it isn't about somthing rubbing against the wheel/rotor.
    (will find some more opportunities to post so I can get this link in!)
  5. BiomedO1
    4,544
    2,391
    Left Coast
    How do you KNOW it's the brakes?
    Has anyone taken a test drive with you, so you can point out the issue your having?
    Is it repeatable and consistent?
    You've told the service advisor there's a braking noise - they are only going to look at the brakes.
    IMHO; throwing a recording of a noise into the void is only going to give you a bunch of guesses. Go to a local tire and brake store for a free evaluation of your issue or pay for one. At least they can see, feel, smell, and hear the issue - rather than people giving you a wild guess online.....
    Good Luck....
  6. ChapmanF
    18,978
    There are certain brake sounds that are very distinctive, in the earlier generations at least. I might be guessing a bit for gen 4 given the changes to the brake hydraulics, or I might not, depending on the sound. What you get from a local tire and brake store could also involve guessing.
  7. Mendel Leisk
    42,296
    Maybe with a few more posts you'll get permissions. Do be aware: you can't directly upload video to this site; you'll need to upload to YouTube or similar (and create account there if needed), then provide a link here.
  8. Robert21PrimeLTD
    104
    46
    South of Nashville
    I suggest a stationary test if you can.
    Park on level ground with the everything in the vehicle off and the parking brake off. Use wheel chocks if needed to keep the vehicle from moving. (1) jack up the car so that one of the wheels is off of the ground and there is a space between the bottom of the tire and the ground. (2) move/turn the wheel jacked up with your hands to spin the wheel slowly and listen for any noises. There may be a small rubbing sound as the brake pads rub against the rotor. This is a normal sound. (3) Repeat for the other 3 wheels.
    This should give you a good idea if one of the rotors is warped or one of the calipers is creating the excess noise. FYI, a small stone or pebble can get caught between the rotor and the brake pads too and make a noise. If needed find a friend who is car-smart to listen with you, Good luck.
  9. Mendel Leisk
    42,296
    You've got to know your audience. "service 1" is a unique to Toyota Canada description. It's essentially just the tire rotation service, and if he's not rushed he might glance at the brakes. More info, and I do think Google AI is "optimistic":
    https://share.google/aimode/CAw1ejfNK1e4m4nsm
